Question about Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum
Hoover Steam Vac clean water tank valve leaks
My Hoover Steam Vac clean water tank valve leaks as soon as I fill the clean water tank up. I can hold the tank in the air over the sink and see a stream of water running out the valve. The rubber seal looks in great shape and still very pliable, but my guess is that it's leaking inside the tank where the valve must have a rubber seal I can't see from the outside. I've activated the valve by hand many times and it springs down into the shut position nicely. I opened the valve and shook the tank with warm water in it with the hope of dislodging anything that might be stuck in the valve. None of this has helped. Is there a way to take the valve out of the tank and clean or replace it? Thanks.
  • 4 more comments
  • Mark Randall Nov 06, 2008
    This solution addresses a lot of places where water could be leaking after the clean water tank is installed in the Steam Vac machine. However, in this case, the clean water tank leaks just holding it over the sink (not installed in the steam vac). Closer inspection reveals small cracks in the tank around the clean water rubber seal on the bottom of the plastic tank. It is evident that the tank can't handle the stress around the rubber valve. So now my question becomes: Is there a way to take the rubber (spring loaded) valve out of the tank and replace it? Also, what type of plastic is the tank made of? Perhaps I can use a plastic epoxy and repair it. Thanks
  • Mark Randall Nov 19, 2008
    Caramel4
    You were right on the money. The plastic tank is so thin where this valve is inserted that it will crack eventually. No matter how careful you treat it, it will crack just from the pressure put on it when properly installed in the SteamVac. Someone ought to start a class-action against Hoover on this. I've done a lot of experimenting with epoxies and cements to try and repair it so that it won't crack again. (Because buying a new tank won't really solve the problem. Before long it will crack too.) The best solution I've found so far is to use AquaSeal, which is made to repair Urethane and waders. This stuff sticks to the plastic tank and WILL NOT LET GO when it's dry. Can't even scrape it off with a razor. It also sticks to the rubber valve very well. It's messy and hard to work with in such a small space, so first remove the hard black plastic base of the tank. It snaps onto the clear tank and can be carefully removed. Then carefully remove the valve. Put some AquaSeal inside the hole around the edge making certain to cover all cracks and thin plastic areas that might crack soon. Use a wet finger to get it smoothed into place properly. Then reinsert the valve and put more AquaSeal around the outside of the hole. By the way, the hard plastic center of the valve will come out of the soft rubber part, which will make replacing the valve easier. If the tank has cracked enough that pieces have fallen out around the hole you might have to use a large fender washer to fill the gap; file the hole out of the washer and grind the edges off of it so that the valve fits through it and the washer doesn't interfere with the movement of the rubber skirt when it is compressed. AuqaSeal sticks to the metal washer, but not nearly as well as to the plastic and rubber. If all of that seems like a lot of work . . . it is. The next easier thing might be to buy a new tank and before installing it, reinforce the area around the valve with AuqaSeal. If you're not handy at this type of stuff, or don't have time to monkey with it, just plan on buying new tanks every few years.
  • Anonymous Jan 03, 2009
    Same exact problem. Do all Hoover products have similar issues?
    have the same problem. After installed it continues to leak enought that if I let it sit for a min. to start vacumming it has leaked enough that I can start sucking water from my carpet.
  • kilgoretr612
    kilgoretr612 Oct 24, 2012
    I have this issue also. It seems to be coming from the brushes.
  • Anonymous Mar 28, 2014
    LEAKS WHILE FILLING CLEAN TANK UP
    Brigadier General:
  • 3,614 Answers
A) make sure that there is not a place for a stair attachment. If
there is make sure air is not leaking through where the attachment goes
on because of damaged or misplaced fitting.
b) some steam vacs leave water behind them and **** up in front of
them. If you just walked forwad with the steam vac nothing would be
sucked into the tank.
c) try taking your finger off the trigger and using the steam vac. If
the tank still empties the trigger is stuck open.
d) try putting clean water in the dirty water tank only and using it on
a dry rug. If water goes somewhere from the dirty water tank you have
a leak.
e) take apart what you can and look at the parts. A good visual
inspection can solve many of these types of problem if you are careful
not to miss anything.
Posted on Nov 06, 2008
  • micromaster
    micromaster Nov 06, 2008
    you can use a epoxy or a sealant gasket to that.much easier to do.
Honey! It's broke. You can manuever the little black valves out, but you will only find the hole in the clean water tank. I have the EXACT same problem. My advise to you is to take the valves, caps and handle off, sell them on EBAY and then buy you a whole new clean water tank.
Posted on Nov 18, 2008
How do I cycle the valves on the bottom with the eraser end of a pencil on my hoover dual vac shampooer
The center part of the valve (stem) pushes up (spring loaded) to release liquid. If it leaks it can (and should) be replaced. Also, check the black valve seal (conical shaped ring around the outside) for cracks or splits as this can contribute to leaks. The entire valve assembly (similar to photo) should be replaced to solve both issues.
Oct 09, 2014 | Hoover SteamVac F5914-900 SpinScrub...
I have a Hoover V Steam Vac model F7412. The tank for the clean water and cleaner fluid leaked out the bottom. I purchased a new tank but something in that area is still leaking. I know it is not the...
My clean solution tank is leaking from the bottom, too. It is not a hose or a valve. The clean solution tank is leaking in-between the clear plastic walls of the solution tank & the grey plastic bottom that are connected, together. I was thinking of caulking it all around the bottom where the clear plastic sides join the grey bottom plastic. I can't get into ordering a new one (spending $) unless Hoover will send me a new one for free. Purchased at Kohl's in Massapequa, NY in June 2008. There's a one year warrantee AND the directions say to EMPTY the solution tank after each use. Which I normally do because the tank runs dry.
Aug 08, 2014 | Hoover Steam Vac Dual V w/ SpinScrub...
How much soap and water to mix for steam vac
Hi! To fill the solution and clean water tank, turn tank upside down and unscrew cap. Pour Hoover cleaning solution into tank to detergent fill line. Then fill tank completely with hot tap water. Hope this helps!
Jul 10, 2014 | Hoover F5505 SteamVac Spot Vacuum
I just bought a hoover steam vac model F5914900 and the clean water tank is leaking. I tried pressing the clean surge button and the trigger button that was suggested by someone else but it won't
Go to Hoover.com and find a local Service Station. They will replace it at no charge. MUST be a warranty location to get it free. Take your sales slip with you.
Jul 28, 2012 | Hoover SteamVac F5914-900 SpinScrub...
My Hoover steam vac dual v clean water and detergent tank leaks water before attached to the vac and during cleaning
This is a common problem with the earlier models which had a separate soap tank glued to the clean water tank. The plastic was too thin beneath the valve on the clean water side and would develop cracks. You most likely will need a new one piece tank. ( Part # 42272104)
May 21, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
Using my hoover steam vac tonight and too much water coming out. once it's turned on, water and shampoo continuously come out underneath until tanks are empty. looks to be leaking from left side bottom as...
make sure that you have filled everthing properly and the hoover steam is in a good condition. or check else is there any loose coonections in the bottom of the hoover, which makes the tank empty.
if the problem persists take it to service.
Feb 25, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
Water tank leaks
If the tank is leaking, when removed from the cleaner, it is not user serviceable.
Oct 01, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover Steam Vac V2 Deep Cleaner leaking clean water
Fill the tank and determine if the plastic is leaking, or if the valves are leaking. if the tank is cracked, it would need replaced. There is an improved design now available.
You may cycle the valves on the bottom with the eraser end of a pencil.
Sep 24, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Clean water tank leaks
Your going to have to replace it again, good thing is they completely remodeled the new one.
Aug 26, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover steam vac spin scrub leaking cleaning solution
The hose leading from the tank to the sprayer head on the bottom of the unit, or the tank is not seated properly or the tank has a hole or crack
Feb 14, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum Logo
2,961 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
