Question about Kenwood KAC-9102D Car Audio Amplifier
Kenwood 9102d wont power on
I currently have two kenwood 9102d amplifiers. I bought one of them a few days ago, and while driving the amplifier stopped working. I took at look at the amp at my next stop and the ground wire came unhooked... but when i tried to turn the amp back on i wasnt receiving any power. I hooked up the other amplifier that worked perfectly fine when i got home and everything was ok, so the problem is not with wiring or my vehicle... is there something that could have happened when the ground wire fell out? I talked to Mr Tunes (an audio store) and a professional told me that something was wrong with the power source in the amplifier. Any help would be great thx
    Problem Solver:
  • 7 Answers
YOu might have burned out the inner fuse. Better yet the source connect...
Posted on Nov 06, 2008
To bridge a Kenwood KAC-9102D
Hello laurogleal,
The Kenwood KAC-9102D is a mono amp. There is no bridging. Having two sets of terminals is just a more convenient way of connecting two subwoofers. The amp is stable down to 2 ohms impedance, so it is safe to run 2 4 ohm loads in parallel.
Hope this helps.
Apr 28, 2009 | Kenwood KAC-9102D Car Audio Amplifier
My amp cuts out when i raise the sub gain
Then the power wires going to the amp are not heavy enough to keep power to the amp.Or other causes can be the wires going to the sub are either loose or touching.Check all wiring for tightness and wires not touching..If all that checks out then try a different size wire to positive and ground wire Hope this works for you..Have a great day
Apr 01, 2009 | Kenwood KAC-9102D Car Audio Amplifier
Amp powers on no sound out of sub tested sub on sterio and it works tested rcas fine
test ohms on speakers with volt meter and make sure they match what you bought! subs are blown!
Feb 26, 2009 | Kenwood KAC-9102D Car Audio Amplifier
Kenwood steroe wont turn back on after few days of working
check the fuse on the back of the radio, as well as the circuit fuse sending power to the radio
Jan 14, 2009 | Kenwood Excelon KAC-X541 88W x 4 Car...
Install my Kenwood KAC-9102D in my 2006 Acura RSX Type S
You will probably need to use a Line Output Converter (LOC). They're available at virtually any shop that sells car audio.
Many times, the outputs of the OEM amplifier will have significant DC voltage on them. This could damage the input circuits on the kenwood amplifier.
Let me know if you have any other questions.
Aug 24, 2008 | Kenwood KAC-9102D Car Audio Amplifier
Car audio
Make sure that you are running the engine every time that the stereo is playing or you'll deplete your battery's voltage. Also, make sure your alternator can supply the amount of current necessary to produce that kind of power. Amps X Volts = Watts is the formula you use to calculate this demand.
Jul 24, 2008 | Kenwood KAC-9102D Car Audio Amplifier
Amp goes into protection
First change the wire,and disconnect the subwoofers to check if the amplifier turn on without going in to protection mode,if the amplifier go to protection mode you gotta change the Audio amplifiers IC's because they are in short circuit.And if don't go in to protection put one speaker at a time to check if one of them are damaged.Good luck.
Jun 02, 2008 | Kenwood KAC-9102D Car Audio Amplifier
Powers up- and turns off!
If they go in to protection mode the audio amplifiers IC's are damaged and you gotta to change him.Good luck
May 23, 2008 | Kenwood KAC-9102D Car Audio Amplifier
Will it work together
put a the amp the max charge permitted, and y you have a preamp you can makeit work.
Feb 10, 2007 | Kenwood KAC-9102D Car Audio Amplifier
Kenwood KAC-9102D Car Audio Amplifier Logo
144 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
