SanDisk Sansa e270 MP3 Player Logo
Posted on Nov 06, 2008
Problem can only get sound from one side of headphones
Anonymous
Level 1:
  • Contributor 80 Answers
  • Posted on Nov 06, 2008
Anonymous
Contributor
Level 1:
Answers
80
Questions
26
Helped
24788
Points
78
Unfortunately you will have to call the company in order for them to fix this issue
hope it helps ^.^
My laptop plays sound out of both my speakers and headphones.
It sounds like that port is set to mono, go to properties and check that.
I plugged in my headphones and it only plays sounds on one side.
there is a head phone jack in the front and the back. have you tried them both?
6helpful
My skullcandy agent headphones are only working on the left side,,,,,its blank on the left side
Sounds like there may be a problem with the cord.
Try plugging in your headphones and playing some music and moving the cord around. If the sound cuts in and out then you have a lose connection and will need to replace your headphones.
No sound coming from the "right" side of the headphone?? did I deactivate something??
Sounds like the connection for the right channel is interrupted somewhere- check at the point where the cable enters the actual headphones. sounds like you might need new headphones if yours don't have a removable cable.
3helpful
Bose headphones only working on one side
You might want to look at my Tip on replacing plug/cable on headphones, it might solve your problem.
Headphones only have left channel on Denon AVR-588 Receiver
Hi peroty,
Two suggestions for you.
1. If you look at the headphone jack connecton do you see one or two black O-rings or black lines on the jack. If you only see one they are Mono headphones and you would only get sound out of the left side. If there are two black lines they are stereo headphones and you should get sound on both the left & right sides.
2. If after checking the headphone jack connection and there are two black lines on it then I would suggest try a different pair of headphones to see if a different set of headphones works fine.
If a different pair of headphones works properly the original headphones may be bad. If neither set of headphones work properly it may be the reciever that may need to be repaired.
I hope it's not the receiver, but let me know if you have questions.
Matt @ OneCall
www.onecall.com
twitter.com/onecalldotcom
2answers
Only Hearing Sounds on One Side of Headphones
your headphones are bad sounds like cheak out the new seinhezer hd280 pros ok 99 bucks best they make
No sound
Are the lights on the side on? If not try the little switch on the side of the in line remote, also they need to be plugged into the soundcard&USB.
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
