My outer screen has a crack in it. i know this is just a dust cover as i can still see a good picture through the crack. where can i find a replacement for the outer screen?
The problem here is Hitachi usually if it still has it sells all three screens as a unit---expensive.
You may want to search with GOOGLE the internet as some companies sell replacement "protective" screen replacements.
I have even seen one time someone found a piece of plexi-glass and had it cut to the exact size and thickness for a replacement.
That can be done. Look to see if there is an inch or more of space between outer clear screen and inner two screens.
You need to remove the entire front screen frame with all three---remove front speaker grill (should just pull off).
Behind it at bottom of frame for screen unit is a row of 4-6 screws that secure the bottom--remove those.
The screen is secured with pop connectors and you pull out to free it from bottom and then sides--once free it should LIFT up and slide clear--be careful not to scratch inner screens! Also if you twist it you can (do not want to) pop the screens out without warning.
Here is the hard part: with frame and screens out you will find screws (quite a few) inside that use plates to anchor the inner screens in place--You have to remove them to get outer one out.
Most of the time but not always the two inner ones are taped together along all the edges so they seem to be one piece.
If you get this far make sure to note which was facing front and up direction of front one---you get it back upside down or backwards (rear screen facing front) and you will not have a proper picture.
Front screen is secured with some screws and you may have to remove them or not as the outer screen is in a slot all the way around---If no screws look for inside the frame plates in the corners with screws--that version requires you pop the frame apart a little so you can get outer screen out.
Let me know if you have questions---also important not to let dust of any kind get between inner screens as it will show.
SOURCE: Hitachi 53SDX01B Rear Projection Television - No Picture
i have a 50" r.p. Hitachi, kinda had the same problem, it would go off at different times and i't hit on the back and get it to come back on,but after awlhile i'd have to hit it more and harder to get it back on till it quit, the menu would come on and would show the video 1 ,3 and that in the corner.After paying $75 for a guy to say it wasn't worth fixing i tried myself. Not knowing what i was doing, i checked all wire plug connections. Found 2 that wasn't seated good replugged them and still didn't work then tried the bulbs, just kinda jiggled all 3 one didn't feel the same so just tapped on it alittle and it popped, i guess back into place, anyway turned on the tv and it worked. Had moved it recentlly so i don't know if that is what moved the bulb. Hope this helps, also mine is a '94 model.
SOURCE: BROKEN SCREEN
I had the same problem I had to get a UX26083 from Ued.net. now i can't install it!
SOURCE: Where Can I Buy A Replacement Screen For Hitachi 51f59a Rear Proj
Hi, I have a brand new in the box screen for a 50 inch rear projection tv. I was going to put it on ebay but if this is what you need and what I have--well we can go from there. Email me with any questions you may have. Thanks, [email protected]
SOURCE: Have Hitachi 65F59A, Screen broke
HELLO GOOD AFTERNOON WHERE CAN I GET A PLASTIC SCREEN TV FOR HITACHI 65F59A.NEED HELP PLEASE
i have seen some people post in other forums that they just remove the dust cover.. and actually get a better picture. not sure how difficult it is but if anyone has done it before please share the experience
i will try that within the next few days. it seems simple enough since im pretty tech savvy with that era of electronics. if i run into a problem i will be sure to post on here for advice. and thanks a ton!
