Toshiba CF36G55 36" TV it's been working great!! then pic is about 3" wide still have sound just a very bright line going across screen and about 3" of pic.....
  • 579 Answers
SOURCE: Tube TV - one thin horizontal line of bright light
Vertical defection failure. Common failure. Pretty easy to repair ($50-75?). However, my general rule of thumb is not to waste any more money on TVs over 10 years old. Too much other stuff in there ready to fail as well.
Posted on Jan 24, 2008
SOURCE: Please Help Fix My TV - Toshiba 36" Model No. CF36G55
No, in answer to your question, I have not solved this problem! I am waiting to hear from someone on your site.
Thank you.
Posted on Apr 13, 2008
  • 718 Answers
SOURCE: insignia ns32lcd no picture just lots of vertical colored lines
Usually this problem is caused by the connections for the LCD Controller(TCON). If you disconnect and re-connect the cable until it works correctly it will usually solve this problem.
Posted on Feb 23, 2009
  • 75 Answers
SOURCE: TV: bright line across black screen for several hours.
vertical problem need to check for bad solder joints on vertical ic would be helpfull if we had the model number o f yur set. also could be bad capasistors in vertical section.
Posted on Mar 09, 2009
micromend
  • 748 Answers
SOURCE: Toshiba Satellite P105-S6124 Screen lines
Are these lines on the screen during the whole boot process? If so then the screen cpu and/or the video cpu has gone bad. Connect an external monitor. If the picture is clear, no lines, then the problem is the LCD screen. If the lines appear on the external monitor during the boot process then the mother board will need replacement.
Good Luck
Posted on Mar 22, 2009
TV is older and has had a great picture through the years. It has now developed blue vertical lines all the way across the screen every 3/4".
Those are retrace lines from too bright a picture. If you can't get them to go away with the brightness control then a repair is necessary
Jun 22, 2015 | Sony KDS-R60XBR1 60" Projection HDTV
I HAVE A PANASONIC 50" PLASMA TV IT HAS A HORIZONTAL 3 TO 4" WIDE LINE ACROSS THE SCREEN HOW DO I REPAIR IT MYSELF
sounds lie a couple bad drive Ics on the buffer boards. You can get replacement buffer boards and free technical assistance from www.tvrepairworld.com
Nov 28, 2012 | Panasonic TH-50PX50U 50 in. Plasma HDTV
No Picture On Screen
it sounds to me like your tube has gone , go to your local tv repair shop and order a new tube its quite cheap to do so and they should be able to get it you quite fast.
Mar 10, 2009 | Mitsubishi VS-60601 60" Rear Projection...
Toshiba 62hm15a- bright flashes
my toshiba 62HM15A has bright and dark flashes.
Sep 30, 2008 | Toshiba 62HM15 62" Television
No picture only sound, Toshiba 36A 36" TV tube type
my friend if you open the tv carefully look to see if the tube itself has light, or if you have high voltage i coulbe many different things.wish luck!!
caypianan@yahoo.com
Aug 10, 2008 | Toshiba 36A50 36" TV
APPROXIMATELY 3" GRAY LINE ACROSS THE TOP OF MY TV
Do you happen to have a cable box? (reset cable box also by unpluging it). is that line also showing on dvd player on different input?
Jul 01, 2008 | Toshiba 50HM67 50" HDTV
Toshiba 27
you just say horizontal lines / and across a top of your television.I expect your trouble is the vertical line of your television . sound ok? try trouble the vertical section the check the resistor?
Apr 19, 2008 | Televison & Video
White horizontal, zig-zagging lines
Sounds like the flyback transformer is bad. couple of 100 dollars if it is that
Dec 03, 2007 | Televison & Video
Thin horizontal line across picture
I really dont understand the problem Could we see a picture of this please?
Jun 14, 2006 | Toshiba 35A44 35" TV
Sony big screen
is the pic bright red or dim with no video and small faint red lines??? if the picture is there then it sounds like the red screen on the High voltage block may be turned up a bit to high. Was somebody tring to focus the pic latly>> need more info please>
May 05, 2006 | Sony KP-57HW40 57" Rear Projection...
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
Electro Med Services...
