Question about Zephyr Savona ZSA-M90S Kitchen Hood
Flap valve and noise
1. The hood is shipped with a 6 inch round flap valve, presumably to keep outside air from blowing into the kitchen. The manual makes no mention of this part. Is installation recommended? If so, just drop it into the opening at the top of the hood? 2. The blowers make an unusual noise, hard to describe, audible at low speed only. Am wondering if there's a bad bearing, etc. Where do I take the unit to have it checked out under warranty? Live in Seattle, Washington.
  • Anonymous Jun 13, 2008
    I am instaling a Savona hood and have no idea where to attach the vent flap. There is no mention of it in the manual. I know what it is for and how it works but WHERE DOSE IT GO?
  • 833 Answers
The flapper valve is a weather valve. Usually, it is installed in such a way that the flapper is vertical and closed. The pipe is installed on the horizontal...you'll need an EL pipe. Pivots allow it to open when the fan is on. If you don't install it, wind will blow into the unit and you will be rather unhappy.
It is possible that the sound you hear is normal when opened up. With all the covers in place, it should be nearly silent.
http://www.zephyronline.com
Posted on Dec 09, 2007
If I replace a range hood should I get good updraft if I reduce a existing 8 inch pipe to 6 inches for the new range hood. The ADKY I just bought was an excellent price
according to bernolii's equation air velocity increases as pipe dia decrease's given that force(fan) remains' the same
aka it's gonna make a lot more noise !!
Apr 22, 2015 | Kitchen Ranges
How do I adjust the flame in my gas oven
You have to be careful when adjusting the flame because you can cause carbon monoxide issues. There are two adjustments. the orifice hood and the air shutter. the orifice hood when turned will adjust the flame amount and the air shutter will adjust the burning of the gas. the hood will be on the line feeding the burner usually on them safety valve and should be a 1/2 inch nut. The air shutter is the door like opening on the burner tube itself. Your flame should be a nice blue cone without any yellow and should not blow and walk off the burner.
Oct 05, 2014 | Kitchen Ranges
Under cabinet kitchen exhaust fan, when not in use, allows a very cold draft into kitchen
There is a flap that closes when it shuts off, it is gummed up with dried grease. Spray some wd4O on it ...
Jan 09, 2014 | Jenn-Air JXT5830AD Kitchen Hood
Hi, my kitchen extractor fan seems to be blowing the smells back into the kitchen and not out, it sounds like it it working ok and the fan is going round.
Check the ducting outlet is not blocked on the outside wall or if it is ducted up through a ceiling then remove the hose fron the unit and check for blockages.With the hose off run fan to see that it is indeed blowing the air correctly.The other things to check are the filters.
Hope this helps.
Mar 26, 2010 | Kitchen Ranges
Kohler Rialto flap valve leak
if so cut 1/4 inch off the bottom of round part of flat valve
Feb 23, 2009 | Kohler 3386-6 Rialto Skylight Round Front...
Venting hood to outside wall.
install ducting along with closing flap (so outside wind does not blow in) and power first !
Jan 25, 2009 | Jenn-Air JXT8142ADS Kitchen Hood
Blows cold air and produces little lint in the vent
To get a rear control LG dryer apart: Open door and remove two phillips head screws at the 5 and 7 o'clock positions. Use a putty knife to release the clips holding the top panel to the dryer front by pushing the clips in at the seam of the dryer top and front, a couple inches in from each side. Swing top back. Remove two phillips head screws at the top, allowing front panel to pull forward. Unplug drum light and door switch and drum sensor plugs, allowing front panel to be completely removed and set aside. Now, look at the burner area at the lower right. Behind the gas valve you will find a small (about dime sized) high limit thermostat on the left side of the burner cone. It has two wires attached and has a small pin in the center of it. (Only on gas models) Push the pin in.
Now, if that get's you ignition again, CORRECT VENTING ! Get rid of flexible vent material. (use only rigid aluminum vent pipe and elbows) Clean out vent pipes and outside vent hood. Outside vent hood should be the kind with a four inch flap for the opening, not a two inch flap. Tripping of the high limit thermo is almost always caused by inadequate air flow.
Dec 28, 2008 | LG DLE5977 Electric Dryer
Jenn Air broken flap on outside exhaust hood
I have the same problem. How do I get the new outside cover when I don't know a part number?
Dec 07, 2008 | Jenn-Air JXT5830AD Kitchen Hood
Jenn-Air Downdraft ducting roof Rack w/flapper
go to www.luxurymetals.com
there are many good high quality vents on the site
Oct 08, 2008 | Jenn-Air HV363 Kitchen Hood
Downdraft
I would double check that the installer used the correct vent hood outside. The correct one has a spring that keeps the outdoor flap closed when not in use. Cleaning the outdoor flap area may also help it seal a little better. Even if the right hood was installed, you might check to see there is a spring present (or signs that there was one.
I have never had air blow out the downdraft, but I do feel cold travel to the fan unit which makes the floor cold in front of the range.
Jul 12, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Zephyr Savona ZSA-M90S Kitchen Hood Logo
455 people viewed this question
Top Zephyr Kitchen Ranges Experts
Treefrog15
Treefrog15
Tom Chichester
reliableservice
Are you a Zephyr Kitchen Range Expert? Answer questions, earn points and help others
