Question about Canon Cameras
I have a Canon Power Shot s400 and am having a problem formatting the CF card. I have three different CF cards that I have been using for some time and have formatted them before but they are now not staying formatted long enough to take any pictures. I have a new fully charged battery in the camera and the camera does not want to come on at times. Can you help me??
  • 1 more comment
  • cumalong Nov 06, 2008
    I am formatting the CF card on my camera--Pearl--
  • cumalong Nov 16, 2008
    Thanks. I have put a different cf card in the camera and it is working great. Must have been the card is defiled so I will not use it again until someone can prove it undefiled, Thanks, new card and it works.---
  • Eric Pohl May 11, 2010
    Are you formatting the cards in the camera or in your computer?
  • 44 Answers
You most likely have damage in the card socket. you might be able to look into the card slot anf see if any of the contacts are bent, but most likely the socket will need to be replaced.
Posted on Nov 16, 2008
When isert flash card i get err2 sign
According with the manual:
Err 02: There is a problem with the CF card. Do one of the following: Remove and reload the CF card, use another CF card, or format the CF card.
Try formatting the CF card in the camera, if that doesn't work use a card reader to format it in your PC then format it again in the camera. If that doesn't work try a different CF card.
Keep us updated.
Mar 22, 2011 | Canon Cameras
My Canon 40d keeps saying' CF card not formatted Format card with this camera'. I tried to do that but it says ' Cannot format Change the CF card. I have 6 cards and I've tried them all with the same...
My 40d keep saying the cf card is not formatted. I used three different cards and it says the same thing. Is it anything I can do to fix this problem.
Nov 29, 2010 | Canon EOS 40D Digital Camera
I get a memory card error even though it has a card installed
http://www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_a_series/powershot_a70#ServiceAndSupport
Issue: Memory card Error
Solution: Try a different memory card and/or Reformat memory card PowerShot A70
Formatting a CF Card You should always format a new CF card or one from which you wish to erase all images and other data.
caution_a70.gifPlease note that formatting a CF card erases all data, including protected images and other file types. Please check the contents of the CF card before formatting it.
  1. Turn the power on.
  2. Press the <MENU> button and select [ tools_icon.gif(Set up)] using direction_arrow_lt.gifor direction_arrow_rt.gif.
  3. Select format_icon_a70.gif(Format) using direction_arrow_up.gifor direction_arrow_down.gifand press the <SET> button.
  4. Select [OK] using direction_arrow_lt.gifor direction_arrow_rt.gifand press the <SET> button.
    • To cancel formatting instead, select [Cancel] and press the <SET> button.
    • The capacity of the CF card displayed after formatting will be less than the rated capacity of the CF card. This is not a malfunction of the CF card or camera.
  5. Press the <MENU> button.
  • If the camera does not work properly, the inserted CF card may be malfunctioning. Reformatting the CF card may solve the problem.
  • When a non-Canon brand CF card is malfunctioning, reformatting it may solve the problem.
  • CF cards formatted in another camera, computer or peripheral device may not operate correctly. When that happens, reformat the CF card with this camera.
Aug 03, 2010 | Canon PowerShot A70 Digital Camera
Unable to format CF card
Try formatting it on your computer...make sure you are formatting "that" drive and not your C drive.
Mar 19, 2010 | Canon EOS 40D Digital Camera
Memory card capacity for my older canon digital camera
Does you camera use CF cards?
If so the may work but some of the newer high tech CF cards are made for newer cameras.
It may be worth a shot to try the 2GB card and if it does not work, sell to someone who uses those.
Jun 10, 2009 | Canon PowerShot A75 Digital Camera
Canon rebel xt error messages
error 99 can most times be remedied by taking a standard pencil eraser and carefully cleaning the gold contacts at the back of the lens and the gold maching contacts in the lens opening of the camera... BE CAREFUL not to let eraser crumbs into your camera... keep it clean... reset the battery and give it a whirl.... did it solve the 99 issue?
for the CF it refers to the cf card... here's what I've found on this:
Canon reports that this error code may appear on your digital camera’s LCD (liquid-crystal display) when there is an error reading from or writing to the inserted CF (CompactFlash) card. This error code occurs most often after a user has tried to eject a CF card before the camera has finished writing data to the card.Solution:
Canon suggests that you first try to use a different CF card. If you do not see the error message when you use the new CF card, the first card is probably damaged.
Before you take the next step, drag the files from the CF card to a location on your hard drive to back up the files. Next, you can use Windows’ ScanDisk utility to check the CF card for errors. If you use a Mac, you can use Disk Utility (in Applications\Utilities\) in OS X.
If ScanDisk or Disk Utility fails to resolve the CF card problem, insert the CF card in your camera again. Then format the CF card. On most Canon cameras, you can do this by pressing the Menu button, selecting the Format tab, highlighting Format, selecting Format, and choosing Yes. Make sure you have backed up the data on the card before you do this. Formatting the card will delete the images from the card. After you format the card in your camera, use ScanDisk or Disk Utility to check the CF card again. If you still encounter errors while using ScanDisk or Disk Utility, you should discard the CF card because it is damaged.
If the error still occurs after following the steps above, your camera may need repair. Contact Canon’s technical support for further assistance.
hope this solves your issues....
let me know
K
May 29, 2009 | Quantaray AF 70-300mm f/4.0-5.6 High Speed...
CF Card Error
Check your memory card to see if its locked!
Jan 03, 2008 | Vivitar ViviCam 3915 Digital Camera
Cf card
It's no problem at all to get them back. Please see this post for several free software that you can download. You'll need a card reader to use with them though:
http://camerarepair.blogspot.com/2007/12/recovering-those-accidentally-lost.html
Dec 25, 2007 | Canon PowerShot S400 / IXUS 400 Digital...
I'm having 3 different problems with my Canon Rebel XT
According to Canon, Error code 02 means that "There is a problem with the CF card. Try any of the following: Remove and re-insert the CF card. Format the CF card, use a different CF card."
Are both CF cards the same brand? Sometimes some brands have conflicts with the camera, you might try using two different brands.
It may not be the card, did you try on the third attempt to remove the battery and put it back in? There may be a problem with the contact points where the CF card plugs into the camera, or in the transfer system itself.
Dec 01, 2007 | Canon Rebel XT / EOS 350D Digital Camera
CF Card Error
Well there is a known problem witht eh CF memory design, i hope this is not your problem but it may be. Take your camera into a well lit area or get a small flash light. Open the memory door and peek down inside the camera and look at the pins inside the camera. Are they all uniform? does any look bent or out of place? there should be 2 uniform rows no pins should be missing or out of place. If they are you have a connection problem. This is one of the issues with this memory format and its why they have changed the design to SD. This is common with people who remove the cards alot and use a reader over time the card and the slot becomes warn and its very easy to bend pins because the card isnt sliding in smooth. If this is your problem (a few bent pins) you may have to take it in for service or try and fix it yourself. Ive read about people using a mechanical pencil. Remove the lead and the pin slips right into the top and you can carefuly move it back. Hope this helps!
Sep 14, 2005 | Canon PowerShot S400 / IXUS 400 Digital...
Cameras Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
