Question about Kenmore 63942 Dryer
Dryer wants to start
The dryer will start and the tub will not turn then cuts off.
  • 686 Answers
Can you turn the drum by hand? tell more plz
Posted on Mar 01, 2009
Kenmore Heavy Duty dryer model # 86873100
The drum belt is lopped through a idler wheel that has a power cut off switch that cuts the power when the belt breaks.
So I don't know why the dryer would heat up if the belt is broken?
Is the top of the dryer very hot. Check the dryer vent tube is not clogged.
Feb 22, 2014 | Frigidaire Kenmore Washer Tub to Pump Hose...
Whirlpool Gas dryer LER7646DQO. Will rotate but binding, motor labors when starting up. Heats fine. Ideas?
Check the wheels that the tub is resting on for poor lubrication. Try to lift up the tub with something you can pry with. Just enough to take the weight off the wheel, one at a time and then turn by hand the wheel and see if it/they are dragging or jammed.
If you find one or more wheels jammed or dragging, then replace it/them and you should be good to go.
While you have your dryer all twisted and partially dismantled, take a few moments and clean out the LINT DUCT all the way from the TUB to ALL THE WAY outside the home. Damp lint does not move very well and if it has been collecting for months or years you could be clogging your dryer drum wheels, and/or the belt that turns the drum and setting yourself up for a nasty fire in your dryer, that could easily burn down your home. You may have to reroute your hose if you find ANY PLACE that the hose goes up hill or has a bunch of turns in it. Make sure the Duct is level, or slightly slopped down, and keep your turns to the very minimum. Changin direction of a Lint Duct might look cool, but every turn will cut your air flow by 40 percent. Does not take long for the lint to build up, and spark a fire and then it will get really unfriendly around your dryer.
kindly,
Jim
Oct 19, 2013 | Whirlpool LEQ8000JQ Electric Dryer
The dryer in my trailor tub wont turn I have Heat but the tub wont spin.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Mar 08, 2011 | Dryers
My frigerdia model flse72gcsa dont start up the dryer juest set and the tub does turn
Dryer Repair - The
Dryer Repair - The
heatman101
Feb 01, 2011 | Dryers
Dryer hummes when you turn it on but does not rotate
This don't sound good most likely the motor is bad . OK first unplug the dryer take the belt off the motor now plug the dryer back in hit the start switch does the motor turn NOW??? If not its the motor. IF the motor does turn??? could be a weak motor OR Bad bearing in the Back of the tub.
Rotate the TUB by Hand UNPLUG THE DRYER FIRST. IF the tub Rotate freely I would say you
Have a bad Motor But if the tub is very hard to turn now your looking at a bad Bearing
GOOD LUCK HOPE THIS HELPS
Nov 21, 2010 | LG DLE5977 Electric Dryer
Dryer runs but the tub does not turn
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 07, 2010 | Frigidaire GLGR1042FS Dryer
Dryer does not start
Dryer Repair - The
Dryer Repair - The
heatman101
Jul 26, 2010 | Bosch Nexxt 500 Dryer
Motor shuts off, and resets after a few minutes dryer wont run
May be the tub support rollers, If this is problem you will have to remove the tub. Then check rollers to see if they turn free. If not replace the faulty ones. This drag on the motor will cause it to get hot.
Mar 29, 2009 | GE DBXR463EDWW Electric Dryer
Dryer runs on high heat until it cuts element off no matter what
IF THE DRYER HAS A DRY SENSOR INSIDE THE TUB CLEAN IT WITH A LITTLE ALCOHOL IF YOU HAVE OWNERS MAN CK FOR LOCATION IF NOT LOOK TOWARDS THE REAR OF THE TUB SMALL DISK SHAPED USUALLY
Dec 22, 2008 | Whirlpool GEW9878LW Electric Dryer
Kenmore 63942 Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
