Question about Acer Computers & Internet
I just recieved the replacement hard drive from acer how do I remove the existing on on the 5315 I have removed the keyboard before on my dells to add ram is it similar for the aspire
  • cesar930 Nov 06, 2008
    Thanks I was looking for the physical location on the Laptop since I had no manuals. I found it and replaced the existing HDD. I am waiting for the window vista disk they were supposed to ship from Acer so I can re-install the operating system. I did not look for the jumpers before I installed it I toolk it for granted that there was no other options since it was a laptop. Was I wrong with that assumption.
    Scholar:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 89 Answers
This is a HDD replacement i assume. As long as you have the cd of your operating system amd know how to install it, then replacing the HDD drive goes like this: After unpacking check and verify that the jumper setting is set to master. There might be documentation that came with the product that tells you how it's set. If you look at the back part of the HDD where the data and power is connected, you'll see eight pins with a jumper connector that connecting 2 pins. Just verify that it's set to master, but usually it's already set. There should be a little diagram on the product label of the part that shows which position the jumper is to be set. In your case, if it's going to be the only HDD installed on the pc, the setting should be as master. By looking at the diagram, it shows what position the jumper is positioned and with which pins. It's easy, now once that's verified, it's now time to disconnect the old one. First, unplug the pc and open the case. Observe how the old HDD installed, and what connectors. You'll probably need a philip screwdriver, but you'l need to disconnect the wires which will only consist of a data cable and power. Keep in mind that it's important to handle this part carefully. Don't drop, shake, or shock it because the flying heads that read/write data to/from the hard disk has a tolerance less than the thickness of hair. Once the new HDD is installed, power it up eand enter the BIOS and make sure that it's detected. And as the pc is powered up, listen in for the operation of the HDD. It' will make an obvious noise when it receives power, and that's just to assure it's operating. From this point, you'll be in the process of installing your OS. Along with the Windows cd, change the boot order, priority, sequence, or whatever and make the cd-rom boot first in the sequence. Once done, you can press ESC, and then F10 to exit. It should restart and initiate post. You'll see a question "boot to cd...". once you see that, press enter to begin setup. I hope this explains and helps you with the problem.
Posted on Nov 06, 2008
How to remove the back off an acer 5532 laptop
Which back do you mean? The cover that hides the Ram/Hard Drive etc... or would you like to disassemble the Machine?
Since you didn't mention the specific task you would like to do, I am unable to give you the specific instruction. Please check out the following tutorials:
1. How to disassemble and replace the keyboard
2. How to replace Ram
3. How to disassemble
If you need further help, let me know with more details.
Good Luck.
Thanks for using FixYa.
Jan 11, 2011 | Acer Aspire 5315 Notebook
How to change hard drive in acer 5315
This picture is from the 5315 User's Guide:
Number 5 is the hard drive compartment cover. Remove the two screws at the right with a small Phillips screwdriver and pop the cover loose, using the notch at the top. The hard drive is plugged into a connector under the cover. Slide the drive forward to release it from the connector and lift it out of the computer. Place the new drive into the compartment, slide it back into its connector, replace the cover and you've done it. All that's left is to reinstall Windows or restore the factory image.
Thanks for using Fixya, and good luck with the repair!
Nov 29, 2010 | Acer Aspire 5315 Notebook
Hi my acer aspire 5315 will not boot up, i turn it on i get nothing but the little cursor in the top right hand corner...can anyone help please thank u in advance
That is probably because some important boot files are missing. What you can try is to take out the hard drive and move it to another acer aspire 5315 computer. To take out the hard drive, remove ALL electrical components (power cable, battery, etc.), open the computer's hard drive bay, and take it out VERY carefully. Make sure you do not cut the cables. That could damage the hard drive. Then, you remove the hard drive on the other acer aspire 5315 computer using the same instructions above. Then, you can identify the missing boot files (they will be in a hidden drive called System Reserved), copy them onto your computer's hidden System Reserved drive (if it's missing you'll have to create one manually), and put it back in the other acer aspire 5315 computer. Make sure that you put the wires where they were when you removed them, otherwise the hard drive might not work. Then, try turning on the computer again.
Nov 14, 2010 | Acer Aspire 5315 Notebook
Acer 5315 will not boot. Also will not work in safe mode
turn off laptop , remove cables and battery then press and hold power button for 8 secs. Reinsert cables and battery then turn on the pc. Observe if there is power on the laptop by checking the keyboard if there is light on it. You may check it at the upper portion of your keyboard. If it still wont boot, you may have a bad memory or hard drive. Normally if it is a system problem, your unit won't turn on. Consult ACER for possible repair of your laptop
Oct 20, 2010 | Acer Aspire 5315 Notebook
How do I remove acer aspire 9810 keyboard,I have removed the base cover and screen assembly but I cant fugure out how to remove the keyboard Thanks in advance Peter
to remove the keyboard, remove the screws at the back of your laptop. Then remove the Hard drive, then remove the Optical drive then remove the video card, and then power supply. Then remove the fan from the motherboard and you may remove the screws on top of the keyboard. Finally you may replace the keyboard.
Jul 15, 2010 | Acer Aspire 9810 Notebook
Is there diagram to show where the hard drive is acer 5315 if so can i replace it sata 160gb to replace the 1gb
The hard drive on this model is located on the left side of the laptop, underneath the memory card reader.
Oct 21, 2009 | Acer Aspire 5315 Notebook
Keyboard broken, how can a install new keboard?
Keyboards can be purchase from places like ebay etc.... don't have to spend loads of money on new. once you do purchase a keyboard all you need to do is unscrew around four screws to be able to replace your old keyboard with the good one. The screws that need to be removed normally have a 'K' next to them which stands for Keyboard.
If this has helped you then please rate me!
Sep 01, 2009 | Acer Aspire 5315 Notebook
Computers & Internet Logo
83 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
