Question about Brother HL-2040 Laser Printer
Embedded paper jam!
Help! I have a paper jam, paper is stuck tight as a drum. I cannot see anywhere to free it. I opened whatever can be opened, but there seems to be no access.
  • Selia Nov 06, 2008
    I found the solution myself. The Brother Laser HL 2040 install disk has a pdf of the user manual. It gives several ways to solve a paper jam. I did this: remove the ink drum (carefully) and the paper pulls out with it.
  • 4 Answers
I removed the ink drum and the jammed paper came out with it.
Posted on Nov 06, 2008
It wont print, says paper jam, yet there is no paper stuck anywhere? any suggestions?
Hi!
Try removing the cartridges and drum and clean the big grey roller as this picks up paper and if not it will show a paper jam without paper being in the machine!
Good Luck!
Jan 17, 2011 | Samsung CLP 300 Laser Printer
My printer mp145 with error e23, please help?? help....
From looking around online, it appears that E23 is a paper feed error. Do you have jammed paper anywhere inside the printer? Open all of the covers and doors, remove the toner cartridge and paper trays, and try to find the paper that it sees. If you close everything up and the printer still shows the E23 message, turn it off and turn it back on to see if it clears.
May 30, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Says paper jam but can't find any paper anywhere
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Jan 11, 2010 | Canon imageCLASS MF5750 All-In-One Laser...
Paper Jam light is on and there's no jam anywhere. What do you do?
A paper jam notification can be caused by two things. One a hard jam, paper stuck.
Two, If the paper does not reach a flag or sensor on time, the printer knows that a jam has occurred.
Most likely, you had a paper pick problem caused by dirty rollers or maybe the paper is held to tightly by the paper tray. Also a static charge on the paper can sometimes cause sheets of paper to stick together.
Don
Dec 09, 2009 | Dell 1720dn Laser Printer
Printer indicates paper jam every few pages, but there is no paper anywhere in the paper path. If I open the top cover and close it, it will print a few more pages, then indicate another paper jam
Dec 08, 2009 | Xerox Phaser 6180N Laser Printer
Alledged Paper Jam
Check underneath the toner/drums for the paper.
Oct 06, 2009 | OKI C3200n Led Printer
Says there is a paper jam but we looked everywhere and there is no paper stuck anywhere in the machine
soes it say original jam or just paper jam if the jam is in th document feeder part open the top and check the sensors where the paper goes trhough.you may have to take the toner/drum unit out to reset the jam also if there is a door on the back open and close this to reset the sensors. If there was no paper the first time check the paper tray by pulling out and then look inside where the tray sits as the poaper might be stuck there.. also check the tray in that the paper sits tight in the guides and the rollers that feed are not dirty. If turning on and off doesnt get rid of the jam there is something stuck on one of the sensors..Goood Luck A
Aug 11, 2009 | Office Equipment & Supplies
The machine says "paper jammed, open the front cover and remove jam papers" I have done this and turned it on and off, but couldn't find the jammed paper. what do i do? please help!!!!!!!!
there mat be a small scrap/piece of paper stuck in the bottom of your drum unit. pull out drum and look at the bottom right in the middle. if not there, open rear door and inspect thoroughly.
hth,
razors
Apr 08, 2009 | Brother IntelliFAX 4100 Laser Fax
E studio 16
More than likely you have bad feed tires in the tray you're pulling from or if the drum unit is stuck there probably is paper jammed up in the unit.  Replace you feed tires and check your drum separation claws when you are able to get the drum unit out.
Oct 11, 2007 | Toshiba e-STUDIO 16 Printer
OKI c5150n I get an error that the printer cannot detect the C drum unit.
It sounds like a defective drum unit. Also make sure you are using genuine oki supplies.
Jun 01, 2007 | OKI C5150n Led Printer
Brother HL-2040 Laser Printer Logo
100 people viewed this question
CheckitRight
CheckitRight
Soulvisitor
Soulvisitor
Ron Dufek
Ron Dufek
