Question about Hitachi 50UX57B 50" Rear Projection Television
TV won't power up. I herd a popping noise and now the TV won't turn on.
    Sergeant:
  • 337 Answers
A popping sound can be a good thing because it will be easy to identify a blown up or degraded component,if you are familiar with tv service you might spot the bad part fast just by looking at it and then change it,sometimes you actually have to check a component with a meter to tell is gone bad,check the main fuse ,it should be close to were the power cord comes in,if is black you will have bad components ahead and you will need the assistance of a servicer,if you are not too familiar be safe and call for help.Let Us know how it goes.
Posted on Oct 10, 2006
  • Omar Urrutia
    Omar Urrutia Oct 11, 2006
    Rating the response is important to the person helping you
Tv won,t come on makes beeping noise
Try unplugging from outlet for fifteen seconds. Press the power button for a few seconds "before" plugging back in. Now plug back into the wall outlet and try turning it on to see if this reset the TV's settings.
Sep 28, 2014 | Emerson Televison & Video
Starting
GET YOUR BATTERY LOAD TESTED ,SOUNDS LIKE ITS BAD
Jan 20, 2013 | 2008 Moto Morini Corsaro 1200 Veloce
My atc fuse would keep blowing I put a bigger fuse it didn't blow that but I herd a zap noise from my TCCM now my 4x4 won't work 1999 jimmy
What you have done? You Just damage the TCCM and that's why you will not manage to shift 4x4. Why this happened? Because you had shortage somewhere and you receive blown ATC fuse.You put a bigger fuse in capacity where the was stronger to blown and the fault moved to the tccm system which was not protected and blown.Ask for an expert to check and see whether the fault is easy to get fixed.
Jan 02, 2013 | 1999 GMC Jimmy
Popping noise and now won't power up. Red and green indicator lights blink on front of tv.
start by checking the power supply in the set and if not able to do that consider taking it to a shop for an estimate.
Jun 16, 2012 | Toshiba 52HL167 52 in. LCD HDTV
Kenmordryer ,replaced heatelament cross teminals wiers turn on herd pop won;t turn on
first check for 240volts at the incoming power,then depending the kenmore number (as in who produced it for sears) if its a 110.xxxxxxxx its a whirlpool, then unplug it and remove 9 hex screws on the back and test the thermal fuse,it has 2 terminals and is 1" long by 1/4" wide and is white in color,it should show 0 ohms,otherwise bypass it for testing by jumping c(touching wires together) and plugging it back in,if it then heats replace this thermal fuse,make sure vents are clean and free of lint as this will overheat dryer and cause thermal fuse to open
Feb 08, 2012 | Dryers
I went to turn on my Samsung a little bit ago, which was working earlier today, and now it won't turn on and is making a clicking noise. The noise does not stop until 10 seconds after I unplug it...
The tv power supply board it got short and already dead some how,tv have clicking noises mean ur tv power supply board are not stable and not regulating high voltages to the rest of the tv other boards.The tv power supply board that the board where the a/c power cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv power supply board for the replacement.
Aug 13, 2011 | Samsung LN46A650 46 in. LCD HDTV
I have a rca m50wh72s dlp tv was watching the tv one day and then herd a loud pop noise and the tv went black i try to turn it on it makes a funny rubbing noise like plastic on plastic and then the power...
Sounds like the color wheel or lamp I would check the lamp first to insure thats its not broken as they can make a pop when they fail sometime (Breaking) then I would check the color wheel you will be able to tell if the color wheel arear has the noise coming from it. If you need more assistance let me know.
Jun 13, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a 32 inch lcd magnavox tv. when i try to turn on the tv it goes right back off within 2 to 3 seconds. its fairly new tv like 3 yrs old. any idea?
Check your power supply. Take it apart and see if the compositors are all in good shape. If they are popped, puckered or oozing stuff out of them then you are going to have to replace your power supply. It also could be a bad inverter. Is there a buzzing noise before it shuts down? Has been doing it for a while and now won't come on at all now?
May 28, 2011 | Philips Televison & Video
Have a vizio 42plasma about 4yrs old. a lil bit ago i started to get red an green flashes thru the pic then the other day i herd a pop an the screen went black. when i turn it on now the pic/image comes...
The main tv Tuner signal board is dead.That the board,where the incomming broadcasting signal cable plug into it.Try website like Ebay.com to buy a refurbish tv Tuner signal board for the replacement.
Feb 26, 2011 | Vizio P2 42 in. HD-Ready Plasma Television
Hitachi 50UX57B 50" Rear Projection Television Logo
83 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
