Question about GE Advantium 120 Convection/Microwave Oven
Advantium 120 makes low buzzing sound all the time
Buzzing coming from the right side about 1/2 way to back. Unit continues to function perfectly and was manufactured in late 2003.
I have pulled the power and the noise resumes as soon as power is applied. The sound does not seem to change when the unit is running (can't hear buzzing over operating sound).
From what I have gathered on other posts...somone has suggested a possible stuck relay? (https://www.fixya.com/secure/support/t282530-buzzing_panel_hot)
Any ideas? I guess if I rip it apart I should be able to hear the offending component pretty easily...I just expected to read about other people having similar problems.
The control panel is not hot in any way.. I don't smell anything.
  • 1 more comment
  • mrclean92124 Nov 06, 2008
    Humming is behind the control panel on right side, but sound comes from 1/2 way to back of unit.
    ALSO, last night i noticed that when I turned on the bright light underneath and toggled from bright, to dim, to off; The buzzing tone got lower when the dim light was turned on, when the bright light was turned on the buzzing sound didn't change from the light off position.
  • mrclean92124 Nov 10, 2008
    Thank you!!! I figured power supply...I guess transformer is equivilent to powersupply in the PC world 8).
    Funny thing, wife used the convection feature and the oven got REALLY hot...the fan ran for some time to cool things down after....For two days after the stupid thing stopped humming at all.. dead quiet...now its back to humming again 8(.
    Thanks for the confirmation...This will allow me to pre-order the part or check availability before I tear it down and get it back in operation all in one day.
    Thanks.
  • jason May 11, 2010
    have you found where the hum is from?
  • 905 Answers
This is the transformer that is doing it and it may end up failing soon , and should be replaced before any other dammage is done,
Posted on Nov 06, 2008
  • 1 more comment
  • jason Nov 11, 2008
    glad to be of asistance! and thanks for the rating!
  • Jamie Dec 09, 2011
    I have the same problem. Is the solution replacing the transformer? Jamiejnewton@gmail.com
  • Bob Pavao Nov 13, 2012
    I also periodically have this problem... i leave the door open so not to hear the humming and after a day it usually clears up. I've tried pulling the plug to reset, sometimes it works. Mine is currently stuck. These units are very expensive and very troublesome. The old counter top micros never seem to fail.
GE advantium 120 convection Cafe microwave making rythmic sound when plugged in and not running. Is coming from the right side of oven Any ideas what it is and how it can be fixed?
The only cause of clunking I can think of is the turntable motor not engaging the drive spindle of the platter properly. Remove the platter and see if the noise goes away.
Nov 03, 2017 | GE Microwave Ovens
We keep getting A MESSAGE "select action 1.0lb quick defrost" which displays every 15 minutes after any function on the Advantium 120 is used.
I surmise there's a short in the Quick Defrost button on the keypad. Either the keypad has collapsed there, or some contamination has gotten in. Another possibility is a failing program memory bit in the controller chip, but a contaminated keypad seems most likely. What happens if you press and hold that button while trying to key in another instruction? Is there any change in behavior?
Oct 21, 2014 | GE Advantium 120 Convection/Microwave Oven
Oven won't shut off
One of the door switches is defective, caused by a build up of food particles or normal ware, to correct this a professional will need to identify the problem and replace it.
Mar 07, 2012 | GE Advantium 120 Convection/Microwave Oven
How low is too low over the range? What is the minimum clearance between range and microhood advantium 120?
from the bottom of your cupboard the minimum is 30 " to the glass on your stove or 2 " above the back panel of the stove heres the instructions on how to assemble the advantium if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in the future here is your link as well http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-40590.pdf
Thanks again Rick
Jan 28, 2011 | GE Advantium 120 Convection/Microwave Oven
Interior bulb needs to be replaced. What needs to be removed to gain access? Thanks
Advantium - Interior Light Operation While Microwaving
The Advantium 240 oven interior (cavity) light will illuminate anytime the door is open. However, due to the dark tint on the oven door, there is not a light on while cooking since the food would not be visible using the interior lamp.
Food may be viewed during a microwave cycle by pressing the Microwave/Oven Light pad.
One of the Upper Level Speedcook lamps will come on for 5 seconds. The Microwave/Oven Light pad can be pressed up to 5 times during a microwave cooking cycle. The limit of 5 times is to prevent excessive heat on microwave cookware from the Speedcook lamp.
The Advantium 120 oven cavity is illuminated anytime the door is opened and while the unit is in the microwave only mode. As a result it will not have the Microwave/Oven Light pad.
If the light is not operating properly, you will want to have it checked by an authorized service technician. To obtain in or out of warranty repair on Major Appliances, you may call 1-800-GE-CARES (800-432-2737) or schedule service online.
Check here
http://www.geappliances.com/search/fast/infobase/10000007.htm
Aug 25, 2010 | GE Advantium 120 Convection/Microwave Oven
Ge advantium 120 microwave oven completely dead
You have a bad cavity switch. I would guess it is the one behind the vent cover, toward the left side of unit. You would need to remove unit from wall. Remove outer housing to expose cavity switch. You can see it from vent cover, I would test all cavity switches before removing from wall. You should have a diagram of unit folded up behind vent cover towards right side of unit. This tells all workings of unit. Will also tell where all cavity switches are.
Dec 30, 2009 | GE Advantium 120 Convection/Microwave Oven
How do i adjust the power level?
Hi Cindeet,
(I just responded, but it doesn't show-up - - my apologies if this comes thru twice).
Looking at the brochure at
http://www.geappliances.com/products/introductions/advantium/downloads/advantium_brochure.pdf
on page 4, there's a control panel with the "Power/Temp" button - try pressing this, then using the knob to select the power level you want.
There's also a "Help" function - - upper right-hand side of the control panel.
Let me know how this worked for you - thanks in-advance.
Jon
Dec 23, 2008 | GE Advantium 120 Convection/Microwave Oven
Advantium 120 problem
dis connect from power alow to reset for about a minute . if not there are switches behind the door probably not making good contact make sure door is closed tightly
Jul 30, 2007 | GE Advantium 120 Convection/Microwave Oven
GE Advantium 120 Convection/Microwave Oven Logo
488 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
