Question about Jenn-Air Microwave Ovens
Jenn-Air Microwave Bulb and Filters Inaccessible - Design Flaw - Help!
This microwave is designed to be flush-mounted with cabinets above and on each side, as mine is.
However, in order to change the interior light bulb and filters, it appears that you must have access to the top front of the microwave where 2 screws that hold on the top-front-panel are located. I have access to approx one-half inch of the top of the microwave, and no screws are visible.
The Jenn-Air phone tech says the unit must be "pulled out" in order to access the screws. This is not something most homeowners can do on their own, and is a serious design flaw from my perspective.
Is there a simple solution? Is inability to access those interior grease filters a safety hazard?
  • JMV8208 Nov 10, 2008
    If the unit is designed to be FLUSH, then it should not have to STICK OUT an inch or two in order to access needed screws to get to the light bulb and filters. Nor does it seem reasonable to have to UNSCREW anything to get to an area of the oven that requires frequent maintenance.
    I appreciate your expertise and your advice. It may well be on the mark for all I know. But the unit is badly designed, and your advice just doesn't give me a way to deal with this - clearly because it's impossible.
    I wouldn't advise anyone who wants a flush-mounted under-cabinet microwave to buy this one.
  • Jenn-Air Master
  • 9,098 Answers
It's not a design flaw. The microwave was incorrectly mounted.
The installation instructions (installation kit) included a template for proper alignment of the microwave on the cabinetry.
If it had been aligned with the template, the two top grill screws would be easily accessible.
The grille must be removed to access the lights and the charcoal filters, which should be changed every 6-12 months if they are used.
If they are in place and not changed regularly, critical ventilation and cooling can be affected.
Your owner's manual can be downloaded free here, and it shows you how to change the bulbs and filter.
It will have to be remounted properly.
Posted on Nov 08, 2008
  • William Miller
    William Miller Nov 16, 2008
    It can't really be flush mounted if the screws you need to access for periodic maintenance would be covered up by flush mounting.
    Check the manual, and you'll see.
  • skippf Nov 25, 2010
    I have the same problem, same issue, and the same template... it is a design flaw. Changing the light requires dropping the unit, and reinstalling it. The user manual shows a model that has a plastic vent cover. Not a motorized hinge as is the case with the flush mount model. wish there was better news Jenn-Air customers.
Hello, i'm looking to replace my light bulb in my jenn-air microwave oven modeljmc8130dds. any help would be greatly appreciated.
The lamp is inside the oven so it is necessary to remove the cabinet but be aware that dangerous voltages are exposed even with power disconnected.
Oct 22, 2016 | Jenn-Air Microwave Ovens
Tip
How to replace the bulb of a microwave oven
Replacing a Built-in Microwave Oven
  1. Step 1 Locate the cabinet above the built-in microwavemag-glass_10x10.gif oven. Find two screwed-in bolts. Unscrew the bolts while someone holds the microwave steady.
  2. Step 2 Unplug the electrical cord from the cabinet above and snake the wire down the hole towards the microwave oven. Continue having someone hold the microwave steady.
  3. Step 3 Roll microwave to left or right to set it free from the mounting bracket in the back. The microwave oven should now be unlocked from its position and can be removed completely from the area.
  4. Step 4 Install the mounting bracket on the new microwave that was included in the package.
  5. Step 5 Snake the electrical cord of the new microwave through the hole in the above cabinet. Plug in the electrical cord.
  6. Step 6 Lift the microwave and rest it to line up with the existing mounting plate on the wall. Roll it until the microwave is locked in place.
  7. Step 7 Use a screwdriver or electric drill to screw in bolts above cabinet into the microwave mounting bracket. This will keep the microwave securely and tightly in place. Your new microwave is ready to use.
on Apr 04, 2010 | Microwave Ovens
I have a old jenn air wall oven and a old jenn air microwave mounted on top. it was a countertop model. when i removed it it was plugged into the top of the oven. would that be a 110 appliance outlet?
The Jenn Air microwave that is mounted above the oven in your unit is 110v 60Hz. The socket in the upper rear right corner of the oven is a 110v 6Hz socket and is where the microwave would be plugged in. If you are going to replace the microwave, you can plug it into that socket. If you would rather not use that socket, you will have to drill a hole in the side of the cabinet holding the over/microwave to get the power cord out.
Sep 29, 2014 | Jenn-Air Microwave Ovens
My Electrolux microwave model E30mh65gps only has on spot to mount it to the cabinet.
Contact your manufacturer or dealer where you purchased the unit. You should be able to purchase mounting brackets to fit almost any design or install situation for safety and liability reasons.
Sep 19, 2012 | Electrolux E30MH65GPS Microwave Oven
I have the Jenn-Air microwave oven. It is mounted in a cabinet. How do I replace the light? Should I try to remove the microwave from the cabinet? If so, how is this done. The manual is vague on this. It...
Most microwaves are similar in design, and here is how for a GE, which will most likely apply to the Jenn Air:
http://forum.appliancepartspros.com/microwave-repair/84864-microwave-lightbulb-replacement.html
This site explains the process:
http://forum.appliancepartspros.com/microwave-repair/165-microwave-interior-light-bulb-replacement.html
To discharge the cap, you can touch an insulated screwdriver across it's terminals, but just avoid the contacts and you will be fine.
Sorry to have to relay tough news, but how this helps you repair it.
Sep 10, 2010 | Jenn-Air Microwave Ovens
Replace Microwave Light
Apparently there's a flaw in the design. My light has gone out/ been changed roughly evry 9 months. No longer under warranty and cost to have someone come in and replace is outrageous. Light bulb is located on top of the oven. You need to remove the top to get at it. Looked fairly easy.
Jan 01, 2009 | GE Advantium 120 Convection/Microwave Oven
Microwave
im not sure what a magic chef bulb is but you can check by opening the casing, the bulb is normally mounted on a fiber board and screwed on the metal part of the microwave,remove the two wires attached to it first, after unscrewing the screw, you can pull out the bulb holder and you can see if it is a replaceable bulb if it has a socket. you can use the old bulb holder , just replace the bulb. in some design, the bulb is mounted directly to the bulb holder, you have to buy the bulb mounted directly to a new bulb holder and use them all as an assembly. be sure to screw them back tight. tnx. i hope i was able to help.
Feb 08, 2008 | Microwave Ovens
JennAir microwave JMC7000ADW lightbulb replacement
their is a panel up near the top on the right hand side of the interior cabinet just remove the screws and put in a new bulb
Jan 28, 2008 | Jenn-Air JMC7000 Microwave Oven
Replace Blub GE Microwave oven Model 1540
On my Spacemaker, access for bulb replacement is on the top of the chassis, which is under the top/side cover. From a diagram I looked at, it appears that yours is similar. If so, you have to:
1. UNPLUG the microwave and then remove the three retaining screws that you'll find on shelf or cabinet above the microwave. Get help; the front of the microwave will be heavy when the screws come loose from the top.
2. Rotate the front of the microwave down a little and lift the rear up about a half-inch. At this point, it is free from the rear mounting plate. Set the microwave on a suitable work surface.
3. Remove the top/side cover piece. To do this, remove all the small screws on the top, the back, and the bottom edges on each side. Then slide cover back about an inch and lift it off.
4. In the middle section of the top of the chassis, you'll then see a cover above the location of the bulb. Lift it up to get access to the bulb.
It's a lame design for an over-the-range unit, but that's the way it is.
Here's a link to a diagram of what it looks like after you get the cover off: http://www.partselect.com/MultiModels.aspx?ModelNum=jvm1640sj&searchTerm=img_00115013i05&RefineSearch=0&imgMfg=GE
Nov 27, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
239 people viewed this question
Top Jenn-Air Microwave Ovens Experts
William Miller
William Miller
Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
