Question about Linksys Wireless-G Broadband Router
Linksys wireless-g broadband router
When all of the wires are installed properly I can not get the internet on my desk top. When I disconnect the wireless router the desk top gets the internet.
  • Jannette Amandy May 11, 2010
    1. Make sure that your modem is connected to the Internet port of the router
    2. What are the lights that are lit on the router?
    3. Who is your Internet service provider?
    Scholar:
  • 132 Answers
1. On your computer, open IE and type 192.168.1.1.
2. By default there is no username and the password is admin.
3. Once you're in, set Internet connection type to what your ISP requires to have. If you have cable ISP usually it is just set to Automatic configuration-DHCP. If you have DSL ISP, it usually uses PPPoE.
4. But verify it with your ISP.
5. Whatever changes you do on that page, do not forget to click "Save Settings" which can be found at the bottom of the page.
Posted on Nov 08, 2008
How can I get the router IP of my Linksys 2.4GHz broadband router?
The Linksys G router gives you both wired and wireless connections over a broadband Internet connect to create a local area network. The Linksys router is compatible with wireless G and B devices, through the 2.4-GHz wireless band. The wireless speed is at 54 megabytes per second and you can get 100 megabytes per second with a wired connection. You have to set up the wireless configuration on the Linksys before using it on your network.
Plug the router's power cable into an electrical outlet. Attach an Ethernet cable into the Internet port on the back of the router. Connect the other end into your broadband modem. Connect your computer to the Linksys G using another Ethernet cable. This Ethernet cable can go into any of the wired router ports. Open your Internet browser. Type "192.168.1.1" in the address bar and hit "Enter." This is your router's IP address and the home of its Web configuration page. Click "Wireless." Click "Manual." Alter your SSID, also known as your network name. You can change this name to any value that you want. You can also change the wireless channel if you are in an area with many wireless connections that may interfere. Click "Save Changes." Click "Wireless Security." Choose an encryption method to encrypt your wireless transmissions. WPA or WPA2 are common security protocols you can use in wireless networks. Input a network key, also known as the network password. Click "Save Changes."
Setting Up WPA Wireless Security on a Linksys Wireless Router http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&vw=1&articleid=3696 Wireless G-Broadband Router support http://homesupport.cisco.com/en-us/wireless/lbc/WRT54G b> b> Changing the Wireless Network's Name (SSID) on a Linksys Router http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&vw=1&articleid=4037
Mar 27, 2013 | Linksys Wireless-G Broadband Router
My WRT54GC router suddenly stop passing internet through it after 4 years of uninteruped service. But all the LED s are on as they should be. I can not get either wired (my desk top) or wireless (lap top)...
Has your modem been hard reset recently? if so, it may require that you bridge the modem out to work with the router- ESP. if you use Verizon DSL. If so, contact your ISP, and ask for assistance in bridging out the modem.
Oct 03, 2010 | Linksys WRT54GC Compact Wireless-G...
Have Linksys Wireless-G 2.4 GHZ 54Mbps Broadband router. Bought a new desk top computer and it won't let me install the CD. Linksys tech support was unable to assist because the warranty had expired. I was...
Hi there, you don't need to install from the disk. Make sure your modem connects to your router and then the computer's LAN port is connected to the LAN port of the router. Open internet explorer and in the address line type 192.168.1.1 this will connect you to the router's setup. On older Linksys routers the default username is blank and the default password is "admin." On newer Linksys routers, both the default username and the default password are set to "admin." You then can find the wireless setup to configure your router. Make sure if you use a WEP code you use the same code from your computer's wireless adaptor. Good Luck...
Nov 12, 2009 | Linksys Wireless-G Broadband Router
Linksys rouder suddenly stoped alowing other computers net access
I would recommend upgrading the router firmware, if you have not done this already.
Download the firmware file from the Linksys website:
http://www.linksysbycisco.com/US/en/support/
Typically, the upgrade is done by pointing your web browser at the IP address of the Linksys router. Linksys should provide specific instructions at the site above.
Nov 01, 2009 | Linksys Wireless-G Broadband Router
Have linksys router and adapter .blank paper image no icons
Not necessary ... U can simply uninstall and install the adapter from device manager ...
Sep 23, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
Setting Up a Wireless Network
You can still use your existing Linksys router with your cable modem. In fact the router your have is designed to work with DSL/Cable Broadband connections.
1. Make sure to properly connec the devices in your network. Modem will be connected to the Internet port of the router. Then, laptop will be connected to one of the 4 Ethernet ports of the router. For initial setup of your router with modem, you need to hardwire laptop to the router.
2. Press and hold reset at the back of the router for about 15 seconds.
3. After 15 seconds turn off the router and then turn off the modem. Wait for a minute.
4. Power on modem and wait for the lights to be ready.
5. When modem lights are on, turn on router.
6. There should be 4 lights on. Power should be steady green. Internet, WLAN and Ethernet port.
7. Checked if you have Internet connectivity on your laptop while it is wired to the router.
8. If Internet is working, disconnect laptop from wired connection to the router and check available wireless network that laptop can detect.
9. The default wireless network name that the Linksys router broadcasts is "linksys". Connect to it which is an unsecured wireless network.
10. Once you are successfully connected, check Internet.
Hope this helps!
Nov 16, 2008 | Linksys Wireless-G Broadband Router
Routers
You can get a regular wireless G broadband router (WRT54G) But you must also check if your sprint modem has an ethernet port so that you will be able to connect the router to it.
Jun 29, 2008 | Linksys Wireless-G Broadband Router
Router works with wire not wireless
there are lots of thing ht can be done like enviroment chek
wep key config ,firewall setting, go one by one minimize the firewall then try to ping it
to to network connection set it up again
this time with proper wep key and in enviroment make sure ur router is not near a carpet or microwave or any plant
May 22, 2008 | Linksys Wireless-G Broadband Router
Installation broadband router linksys WRT54G v5
In your internet explorer address bar, type in the ip address of 192.168.1.1 and see if it asks you for a password.
If that isn't it, try 192.168.1.245.
The default password is admin. No username.
Also, go to www.linksys.com and they have free chat support and can walk you through this issue.
Apr 30, 2008 | Linksys WRT54GL Wireless-G 54Mbps...
Linksys Wireless-G Broadband Router Logo
67 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
