Question about Panasonic PVQ-2510 25 in. Combo
Timer circuit will not let the set come on.
When I picked this set up it came on and played. When I tried to shut it off with the remote it would not respond. Used the Off button on the set. Now I can not get it to come on at the set or with the remote. The record light and the timer lites also the program timer lite stay on all the time thye set is plugged in. the front of the set. I need to know how to disconnect the timer circuit or repair it. Thanks for any help.
  • donald morrison Oct 12, 2006
    Jomaru= unplugging it was the first thing I tried. It stayed unplugged 24 hours. Thanks for the try. I think it is a bad cap. I have an in circuit cap checker ,but don't know where to start without a schematic. When I have time I will try to check some caps and report results if I find the problem.
  • donald morrison Oct 14, 2006
    I want to thank the one person that tried to help. I have found the problem myself it was a cap. Thanks to all.
    Sergeant:
  • 337 Answers
Remove the power from the wall and plug it back in after 15 minutes,this will reset the microprocessor and it might get back to normal,let Us know how it goes and if you need more information.
Posted on Oct 10, 2006
  • Omar Urrutia
    Omar Urrutia Oct 11, 2006
    Rating the response is important to the person helping you
  • Omar Urrutia
    Omar Urrutia Oct 12, 2006
    I gave it a shot since you did not mention it was unplug for 24 hours,you can get the service manual from www.servicemanuals.net with the model number.
It plays 20 min shuts off does it have a timer if so how to shut it off
Yes, this system does have a timer to shut off after so many minutes of inactivity, meaning that yes, your player is playing a movie, but there has not been any input actions made on the player being volume, or any buttons pushed on the remote. You can change the amount of time it takes to shut off, but starting up your player and going to the settings menu, and you can fine and adjust the time there!
Dec 25, 2010 | RCA RTB1100 Theater System
On vcr there is a red light on it and it will not play movies
The most common use of a red light on VCR is the timer record indicatation. With this on most VCR will shut down and allow no playback. Try looking for a timer button, or go into the record menu with the remote then clear any timer settings.
Sep 13, 2009 | Panasonic Televison & Video
Can not shut entire timer off.
To disconnect a box timer so it does not run or control the circuit, then remove wires from terminals.
If you simply want to override timer now and then, then remove trippers from timer dial. Then use manual override switch to set timer ON or OFF.
If you remove wires from terminals, and want circuit to operate, then as a general rule, you connect black wires together and connect white wire together. However you did not specify which timer you have and timers and circuits vary, so it would be wise to test the wires.
May 10, 2009 | Paragon 4001-00 24-hr Timer Control 120v...
Disney pixar cars tv/dvd combo turn on but shuts off in minutes
Ours did the exact same thing.. I Decided the remote thing was worth a try. I turned the TV to DVD (without a DVD in the player) pressed the set up button (on remote) and Restored the Default option. (Highlighted Default; highlighted Restore then pressed OK) Then exited the set up. I did this twice just to make sure, LoL well.. it's been on over 4hrs now with no problem.. seems like this fixed it.. hope it helps!!
Mar 10, 2009 | Disney Electronics Single Disc Boombox,...
I have a sony wega
Generally speaking whent he set shuts itself down, the standby light will blink a code. This will be a count followed by a short pause and then the count again etc.
When teh set shuts down, count the blinks and post it here. That will indicate the circuit that has the problem.
Dan
Dec 05, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Remote was hit, shut set off, and can't get it back on. Sounds like timer is on.
First try turning the TV on from the Power button the set itself (assuming it has one).
If not, unplug the TV from the wall, wait a half hour, then plug it back in. It should come back on.
Also check that none of the buttons on the remote are stuck down, and that the batteries in the remote are OK. The toy might've stuck a repeating button down (like volume) which may have then drained the remote's batteries.
Apr 07, 2008 | Televison & Video
Program timer light blinking
The timer light blinks when the AC power has been disconnected and the clock is not set. This is how the set warns you that it can no longer do timer recordings. Setting the clock and doing an autoprogram will fix it, but both the remote and the remote receiver must be working. If the original remote is not damaged and has good batteries in it but does not work on that set and you cannot get any other universal remote to work, then the remote receiver (the IR "eye") inside the set has failed and needs to be replaced. I have seen many of those little receivers failing recently. If you do not have experience changing electronic parts on small PC boards then have a qualified tech change it for you.
Jul 26, 2007 | Panasonic PV-DM2093 Triple Play 20 in....
Lost setup booklet
try this one: http://www.emersonaudiovideo.com/pdf/om/EWD2202.pdf
May 19, 2007 | Emerson EWD2202 DVD Player/VCR
Remote problem
your emote control needs to be replaceit is not sending signal to the componet
Jan 21, 2007 | Panasonic PV-Q920 VHS VCR
Televison & Video Logo
89 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
