Question about D-Link AirPlus DI-524 Wireless Router
Status and WLAN lights
I have the WLAN and status lights flashing constantly. Unable to connect. Is there a way to fix this or am I dead in the water?
  • Jannette Amandy May 11, 2010
    1. The WLAN light on the router means it is broadcasting wireless signal.
    2. Do you have a computer connected via Ethernet to the router?
    3. Can you connect to the Internet on that computer?
    4. What is the IP address of that computer?
  • D-Link Master
  • 6,487 Answers
First thing to do here is to reset the router, to reset it Press and hold the reset button for 15 seconds while the power is ON then fater that just again the setup of the router to your computer to reconfifgure it back and hopefully everything will be back to normal....
Posted on Nov 10, 2008
Failed to connect to the internet thr wi-fi
f Active Standby is activated on your Cell, your WLAN connection status is always visible from standby mode. The bottom line of the screen shows your WLAN status. If there are no wireless networks in the area, you'll see the message 'No WLAN network found'. If you're near a WLAN that you're not connected to, you'll see the message 'WLAN name found'.
To log on to this network, simply highlight the WLAN status line and press the centre selection key. You'll see three options:
  • Start Web browsing
  • Search for WLAN
  • Switch WLAN scan off
If the WLAN has detected then cell will open, unprotected network (and needs no passcode to access) then simply highlight Start Web browsing and press the centre selection key to go to your Bookmarks page and start browsing the web.
Hope this helps
Jan 17, 2011 | Cell Phones
WTF! internet used to work perfectly and now my wireless router is on the fritz and the status light keeps flashing! i have to hook my comp up to the wall to write this message
If the status led light keeps flashing there is a problem on your ISP side. Router is trying to establish connection with internet. Please check led light status on your modem (not router). Also please try to change position of your router as it might be in a "dead spot". For more info about your router please visit: http://www.dlink.com/products/?pid=6
Oct 24, 2010 | D-Link AirPlus Xtreme G DI-624S Wireless...
I have a similar problem. I have a button to switch on the WLAN card, which has always worked before. I would press this and the WLAN status LED would come on, and off I went browsing. But all of a sudden,...
can you check on your computer whether you got the drivers of WLAN or not - give a try with these few steps please
1. device manager (right click on my computer icon on desktop and select properties - select tab hardware - select device manager ) and check in the right pane for network adapters , under network adapters ull find the wireless name , check the status by double clicking on it .
2.go control panel -network connection (for xp ), network and sharing center - manage network connections on left (vista) , network and sharing centre - change adapter settings on left (win 7) and please check for wireless adapter status -says enable or disable
make sure both are enabled and then check with the wifi switch on your machine .
Oct 04, 2010 | Systemax Neotach 3300 Notebook
Status light on printer is constantly red & USB status is not ava
Unplug printer and wait a few and then plug back in and turn on. Should reset printer.
Mar 29, 2010 | Samsung CLP 300 Laser Printer
Picture went out completely flashing red status light 4 flashes pause constant
Most likely the lamp is burnt out (indicator goes to constant red status). Replace lamp (get lamp P/N from User Manual for replacement), clean any dirt around lamp, fan, and rear filter. Do NOT get any fingerprints on new lamp.
Aug 11, 2009 | Mitsubishi WD-62825 62" Rear Projection...
Dpr-1260 onkly works when connected by ethernet cable
dpr-1260 searching for ap and connected keeps changing back and forth when I refresh.On dpr-1260 if status of wireless keeps changing from searching and connected, change wireless to WPA, instead of WPA2. even if you have WPA2 setup (as I did), if you choose WPA it will stay connected.
Jan 23, 2009 | D-Link RangeBooster G DPR-1260 (DPR1260)...
D-Link DI-534 Starting up problems
Try resetting the router . Press the reset button for 10 seconds and after 10 seconds unplug the power cable but continue pressing the reset button for another 30 seconds after 30 seconds plug in back the power cable and continue pressing the reset button for 10 seconds and release it after 10 seconds.
try to open an Internet browser and type in 192.168.0.1 on the address bar. It should give you the DLink page. Once you have that configure your connection.
Jan 08, 2009 | D-Link AirPlus DI-524 Wireless Router
What lights should be on?
Who is your internet service provider?
Jul 29, 2008 | D-Link AirPlus Xtreme G DI-624S Wireless...
D-Link AirPlus DI-524 Wireless Router Logo
744 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
