Question about Xerox WorkCentre XE80 Laser Printer
Xerox workcentre XE 80 Printing with too much toner in the middle of the page.
Well, like the title says, When I print a page it prints with a big black line in the middle of the page. I have taken out the toner cartridge, and the roller thing, and have cleaned them both, but it continues to do this. Please help as I have a ton to copy. Thanks!~
5 Suggested Answers
  • 208 Answers
SOURCE: Fuzzy Pages
In your troubleshootine menu, I think it is, on the screen, scroll until you find fix imaging problems, or something like that.
There is one for removing streaks and the other for removing smudges.
I would suggest running both and that should resolve your issue.
I doubt your maintence kit is bad, but I would pull it out and check to see if it is extremelty dirty.
Try those two procedures first.
There will be instructions on your User Guide CD on how to run those.
Posted on Nov 29, 2007
  • 184 Answers
SOURCE: Invalid Black Toner Xerox Phaser 6110 MFP
reload the driver again and if it persists, change the toner
Posted on Jun 23, 2009
  • 159 Answers
SOURCE: Xerox Phaser 6360 Black Toner prints Light Grey
I have had to repair a few of these. Take off the sides and back of the 6360. You'll see the hoses that feed into the laser. The black one becomes unplugged from the laser. All you have to do is plug it back in. The next step can be kinda messy. Take out the black toner cartridge, and spin the motor backwards. You'll know you're going the right way because it won't turn the other way. Cycle the gear where the toner sits for about 2 revolutions. Reassemble and you should be good to go!
This thing took me 6 days to figure out the first time. Haha!
Please vote on my solution! Thanks!
Posted on Oct 26, 2009
SOURCE: Have Xerox workcentre 5225/5230 and keeps beeping
error 010-327
Posted on Jun 20, 2010
  • 165 Answers
SOURCE: xerox workcentre 3119 canon toner
Take the tonner catridge out and shake it well. and reinstall it.
Posted on Sep 15, 2010
0 characters
1 Points
Xerox workcentre 4150 not printing test page on windows 7
Hi Cnorini ,
Check this video and solve your problem.
In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : Xerox Printer Support
Mar 04, 2014 | Xerox WorkCentre 4150 Black and White...
My workcentre pro 416 is printing all copies as all black.
It sounds to me like the High Voltage Power Supply, Biasing Ground, or Blanking Exposure Lamp may be a fault. You could also have a problem with the Digital Scanner unit. But, there is nothing that you can do yourself: EXCEPT: If the unit takes a Toner Cartridge that includes the drum, I would try replacing that first. Then if no joy, your going to have to call out the big guns. Good Luck!!
Jun 13, 2012 | Xerox WorkCentre Pro 416 All-In-One Laser...
My M15i Xerox Workcentre is printing with a vertical line down the page
Solutions for : Vertical Black Lines on Copies When the Automatic Document Feeder and Document Glass are Used Solution : Clean the Drum
  1. Make sure there is paper loaded in the paper tray.
  2. Press the [Menu / Exit] button on the Control Panel.
  3. Press the [Up] or [Down] arrow button until 'Maintenance' is displayed on the Display Screen.
  4. Press the [Enter] button. 'Clean Drum' will be displayed.
  5. Press the [Enter] button. 'Cleaning Drum Please Wait' will be displayed and a sheet of paper will be printed. Toner (Dry Ink) particles on the Drum will be affixed to the paper.
  6. Repeat steps 1 - 5 until the page prints without any Toner particles.
Aug 13, 2011 | Xerox WorkCentre M15i Laser Printer
Xeros 3119 printer toner empty error & not printing
I'll be captain obvious for a second, is the toner empty? If not, reset the printer and see if it will print. If that does not work, try to put in a new toner cartridge.
May 04, 2011 | Xerox WorkCentre 3119 Laser Printer
I wish to read the total copy count on Xerox WorkCentre M15i
You have to print out the meter report.
  1. Press the [Reports] button on the Control Panel
  2. Press the [Up] or [Down] arrow until 'Systems Data' is displayed on the Display Screen.
  3. Press the [Enter] button.
    The System Data list will be printed with the following information:
    • Total Page Counts: Total number of pages printed
    • CRU Prints: Number of pages printed using the current Toner (Dry Ink) Cartridge
    • Replaced Toner Counts: Number of new Toner Cartridges installed in the machine
    • Replaced Drum Counts: Number of new Drum Cartridges installed in the machine
    • Current Drum Page Counts: Number of pages printed using the current Drum Cartridge
    • Platen Scan Page Counts: Number of pages scanned using the Document Glass
    • ADF Scan Page Counts: Number of pages scann
Apr 19, 2009 | Xerox WorkCentre M15i Laser Printer
Xerox xe80 workcentre prints almost black copies
Hello sir; Just replace drum cartridge, it will take care your problem. GOOD LUCK!
Oct 31, 2008 | Xerox WorkCentre XD125F All-In-One Laser...
Workcenter M20i Printing Problem
If the issue is only when you are copying, the scanner needs to be cleaned.
If the defect is on both copies and prints, and fax if you use it for that, then your problem is either the drum or toner cartridge or the laser is dirty.
I am not sure when you say you changed the print cartridge if you mean you just changed the toner cartridge or the drum cartridge.
Jun 17, 2008 | Xerox WorkCentre M20i All-In-One Laser...
Printing & copying blank pages
There is a problem with your transfer/seperation unit.
open door to the right look at the black assembly on the door it has a black spongy roller, is it in place? does it have a spring action when you push on it?
if yes for both your High Voltage Transformer ( HVT) is bad.
Dec 11, 2007 | Printers & Copiers
Xerox WorkCentre XE80 Laser Printer Logo
Top Xerox Printers & Copiers Experts
Level 1 Expert
Patrick Carmichael...
Are you a Xerox Printer and Copier Expert? Answer questions, earn points and help others
