Question about HP LaserJet 2840 All-In-One Printer
DRUM Q3964A FOR HP 2840
  • 1 more comment
  • crv29 Nov 06, 2008
  • JDTec
    JDTec May 11, 2010
    Which error code? Did you take all the packing strips off of the new toner/drum?
  • Anonymous Mar 29, 2014
    shows a non hp supply has been installed but it is a hp Q3964a drum
  • HP Master
  • 4,338 Answers
10.000x Supply error Description E-label can’t be read or print cartridge is not properly installed. Solution
  1. Reinstall print cartridge.
  2. Power cycle device.
  3. If the problem is not solved, replace the cartridge. NOTE: The software CD-ROM that came with the HP Color LaserJet 2820/2830/2840 all-one includes an animated tutorial that shows how to replace the print cartridges.
    1. Remove any media from the ADF, and then push the scanner-release button to open the scanner assembly.
    2. Open the cartridge door.
    3. Make sure that the correct print-cartridge slot is in the access position.
      • If the correct print-cartridge slot is not in the access position, close the top cover and the scanner assembly, and then press ROTATE CAROUSEL until the correct print-cartridge slot is in the correct position. Pinch together the two large blue tabs on the first cartridge, and then lift the cartridge straight up to remove it from the carousel.
    4. Remove the new print cartridge from its packaging, remove the orange cover from the print cartridge, and then pull the orange tab straight out to remove the sealing tape.
    5. Squeeze the blue release levers on the print cartridge, holding it with the roller facing you. Lower the cartridge straight down into the carousel until it is firmly in place.
      • To replace another cartridge, close the top cover and the scanner assembly, press ROTATE CAROUSEL , and then repeat the previous steps. NOTE: If a black print cartridge was replaced, then the device prompts to have a cleaning page ran, unless the device page count is less than 100 pages.
    6. Close the top cover, and then close the scanner assembly.
You may have to copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 06, 2008
Are the Q3971A and the Q3964A imaging drums interchangeable?
Q3971A is a colour toner cartridge. Q3964A is an actual toner/drum, not toner alone. So, no, they are not interchangeable as they provide completely different functions.
Read how it works here:
How Laser Printers Work HowStuffWorks
Dec 01, 2014 | HP Color LaserJet 2840 All-in-One...
How to reset supplies on HP 2840 laserjet?
"Would like report of supplies from 2840 laserjet. How to get it to show report"
Select 'Menu" button, then select "Reports", then select "Supplies Report".
This will print the status of the four toner cartridges and the drum.
It doesn't make sense to reset toner cartridges UNLESS you refill them
first. On the HP 2840 each cartridge/drum contains a chip that measures
the life of the unit.
You can purchase toner/chip combinations online cheaper than new
cartridges. I also purchase drum chips to extend the use of my drum
until print quality actually starts to deteriorate.
I use both of these methods to save money on supplies - buy toner and
toner chips, buy drum chip to get full use of drum unit.
Hope this helps.
Mar 19, 2012 | HP LaserJet 2840 Printer
MY HP LaserJet 2840 has a brand new Toner cartridge. Now it won't print at all and we are getting a "OPC at end of life" prompt. What does this mean?
Imaging drum reach 20,000 (black only) or 5,000 (color), replace the image drum.
Supplies life
The life of the imaging drum depends on the number of black-only or color pages that print jobs
require. Imaging-drum life is also affected each time the device calibrates because calibrating causes the imaging drum to rotate. Imaging-drum life is measured in terms of number of rotations rather than number of pages printed.
The type and length of print jobs also affects drum life. A series of short print jobs uses more drum
life than an equivalent number of pages printed in a single large job. To extend drum life, print
multiple copies of a print job at one time rather than sending the same job to the device multiple times.
The life of a print cartridge depends on the amount of toner that print jobs require. When printing text at 5% coverage, black print cartridges last an average of 5,000 pages and cyan, magenta, and
yellow print cartridges last an average of 2,000 pages. High-capacity cyan, magenta, and yellow print cartridges last an average of 4,000 pages. (A typical business letter has 5% coverage.)
Aug 18, 2011 | HP LaserJet 2840 Printer
We have an HP Color Laserjet 2840 printer in our office. We were low on our black ink drum, bought a new drum and installed it. Copies are coming out perfectly but the "replace black...
The 2840 is a slightly different sort of machine when it comes to supplies. There is a main imaging drum unit which works for all four colors, and then there of course are the 4 colors. If the unit was asking for a drum unit then you should have instaled a Q3964A. It is entirely possible that your drum unit and black cartridge both expired at the same time, in which case, you need a black toner cartridge now.
Jul 28, 2011 | HP LaserJet 2840 All-In-One Printer
HP LaserJet 2840 All-In-One Printer want to replace the drum Q3964A
The drum is located in front of the ink cartridges and has a handle that you pull up and out of the printer.
Aug 26, 2010 | HP LaserJet 2840 All-In-One Printer
LaserJet 2840 Printer: I am trying to initialize a new drum. An error mes...
This means that the printer cannot read the E-Label on the cartridge, or it is not properly installed.
  1. Reinstalle the cartridge
  2. Power cycle the device
  3. If the problem is not solved, replace the cartridge. (Is the cartridge a remanufactured one? this can be a problem)
  4. Check if correct cartridge type.
May 10, 2010 | HP LaserJet 2840 Printer
Drum Q3964A chip is not working
If the drum chip is not working then you can reset it and that will resolve the problem.
Follow the below written steps to reset it:
1) Firstly, ensure that all printer cartridges and the drum are installed
2) Check the power button whether it is off or not. If ON then off it
3) Then hold the GREEN GO BUTTON
5) The 3 lights above the green go button will go ON and then OFF
6) As soon as the lights get OFF, release GREEN GO BUTTON
7) Now immediately press and hold RED CANCEL BUTTON
8) Again immediately press and hold CARTRIDGE SELECTION BUTTON
9) Now release the last two buttons once printer intitializing was completed.
May 07, 2010 | HP LaserJet 2550L Printer
Error message replace drum for printer hp laserjet
pristonero, there is no "main" button. what are you talking about?
Oct 20, 2009 | HP LaserJet 2840 All-In-One Printer
HP 2840, black ink drum q3964a
Hello, these printers tend to be finicky.
In other words, just replace the black toner. When the printer says its low, or empty, regardless of wether or not it is, just replace it.
Replacing the drum, when it says black toner needs to be replaced will do nothing to rectify the issue.
Buy only HP Toner and Drum cartridges for this printer. Do not try to refill toner cartridges, and do not reset drum. You will only end up destroying your printer in the process.
Feb 26, 2009 | HP LaserJet 2840 All-In-One Printer
Engine error HP 2840
Hi Koilada,
Switch off printer and remove the drum and cartridges. Replace the drum and close the lid. Wait for the printer to prompt for cartridges and the insert the cartridges.
Dec 23, 2008 | HP LaserJet 2840 Printer
HP LaserJet 2840 All-In-One Printer Logo
713 people viewed this question
Ben Johnson
