Question about Radio Communications
Information on how to use DX 45MP radio
I am buying this radio from someone I work with's friend, but the inbetween guy does not no how to operate it. Is there somewhere I can get an instruction booklet for this radio? I found an owenrs manual online but it did not tell how to use the different band's and channels.
Thank's
Jeff
  • 37 Answers
The DX 45mp is a 10 meter radio meaning you need a license to use any other band other than the normal 1- 40 cb channels, its capable of going beyond the normal cb range.Ask if it has been converted to 11 meter. Channel E should be the normal if it has been converted from 10 meter to 11 meter. Im sure its been converted if its been used for a mobile cb application. Normal cb band is called 11 meter 26.965 mhz to 27.405 thats 1- 40 . Your not supposed to talk on the other bands unless you have an amature radio license but everyone does anyway . I have several galaxys and by far in my opinion are the best on the market. Go to www.cbtricks.com on the home page go to Radio Informaion click it go to G and follow it to Galaxy DX radios youll find all the info for this radio you can even print out the channel chart to see where everything is. Good luck and if you have any more questions just ask. Thank you Chia
Posted on Nov 17, 2008
My dx 959 won't unkey when it get warm it'll unkey when you first turn it on. What could be the problem?
did you or someone else wire another mic to it? Try the original mic to see if it still happens. you could buy some canned mr.freeze and give it a squirt around the mic connector and its circuits to the final and the Intergrated circuit. do it in steps until you find out where the problem is then replace that part.
Feb 13, 2014 | Galaxy Radios DX-959 40-Channels Base CB...
Will not tranmitt
need more information but it could be a number of things.someone could have clipped the wrong diode to give it more modulation.Does it recieve at all? How about your antenna SWR , is it resonably low ? Is your power level low due to the tx problem?
Dec 25, 2013 | Cobra 150 GTL DX Base CB Radio
How do I add channels to the Galaxy DX 2547
you have to buy a switch at radio shack that will let you add channels I think its a # 275-1386A .Then the fun begins . Heres where to go to get the rest of the information so if I print one thing wrong you can't yell that I told you to do it. These are the correct directions @ www.cbtricks.com look for galaxy 2547 and then look for freq conv and it all yours.
Jun 15, 2012 | Galaxy Radios DX-2547 40-Channels Base CB...
I have a 6300 f25 does not transmit
will it transmit to a radio next to it. if so your RF final transistors are bad. other things could be a bad mic. with a broken wire.. ie..
Sep 21, 2010 | Galaxy Radios DX 45MP Base CB Radio
Hi, does anyone know how to connect an LED to replace the original meter lamp on a Galaxy DX 959?, or please refer me to a site where to find this information. Thank you so much. Osvaldo
LED are diodes that operate around 2volts DC. A resistor must be soldered in series with anode or cathod side of diode if connecting to 12 volts DC. Anode to ground....if unsure start with 10k resistor and check voltage and work your way down to around 1.8 volts is ideal
Jan 24, 2010 | Galaxy Radios DX-959 40-Channels Base CB...
Hey guys i have a galaxy 44v, i had two radio checks, on guy said it sounded like i had a pin on my nose and one said i was a little distorted, so what is going on the radio, is dead keying 0.5 watt and...
That radio is clipped and producing as much audio it can and in the process it is also a big splatter box. If you produce 4 watt of carrier and swing 6-7 it will be kinder one everyone ears around you.In other words make sure tr 32 is intact, r49 is not clipped and the amc is not turned wide open.should be marked am mod.I am a Ham Radio Operator that has 15 years of motorola experience. Hope this helps.
kf4gyp
Ray
73
Dec 28, 2009 | Galaxy Radios DX-44V 40-Channels Base CB...
How can i boost my galaxy dx 959
You will have to take this radio to a tune and peak shop for this upgrade. most audio store tech can do this upgrade or, just locate a truck stop near your location and im sure there is a radio guy on the premises that will assist in this upgrade as well. great radio by the way:)
Jan 28, 2009 | Galaxy Radios DX-959 40-Channels Base CB...
Droped channel to 17 and frequency counter don't work?
sounds like a connection is coming loose inside. take it to a CB shop and see if they can spot it. Should be an easy fix, no more than 20 or 30 dollars
Jan 10, 2009 | Galaxy Radios DX- 88HL Base CB Radio
Super Star 3900 GHP
Can't help you there. It's most likely that you screwed the modulator up by extending the frequency range. I used to work for Galaxy and I know what happens to a radio when amateurs try to modify them (no offense). If you modify a high power radio such as your Super Star, you're bound to have modulation and SWR problems. In expert advice, never do amateur radio modifications to a high power radio. If you want a more versatile radio, get a Galaxy DX 2517 CB base station. The DX 2517 has PA/FM/AM/SSB/USB/LSB/CW modes, and bands A-F, and a frequency range from 25.615 to 29.205 MHz. The Galaxy DX 2517 has modifications that can be done right at the factory, they are optional however. The only thing I find annoying with the DX 2517 is that it's bulky, it leaves no room for any competition. When it was designed, the engineers left space saving out of the question.
Anyway, Good luck
and
Best Regards,
Gavin93
Aug 07, 2008 | Galaxy Radios DX- 88HL Base CB Radio
Help me my radio died
not a good radio once its tuned up they turn up the audio to hi thats makes it clip when talking..the radio is at factory setting when you get it,95%modulation..any more will cause problems.all you can do it have it set back to thr org. setting and then check the driver buffer and final transistors one may have blown due to improper tuning...good luck doc's cb shop ny
Aug 01, 2008 | Cobra 150 GTL DX Base CB Radio
Radio Communications Logo
111 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
