Question about Samsung TXJ2067 20" TV
No power even standby LED..
Hi...please help me. My samsung 21" tv got no picture and sound at all, even standby LED also not light on...I already do some troubleshooting and found that power supply for the biggest capasitor got 350v...also at horizontal transistor B+ got 158v (is that too big supply for horizontal B+..?).... and another thing got a strange sound came out from flyback transformer..it sounds like "tick..tick..tick.....frequently" .....then, i check where the 158v came from and found it was came from 1 diode that link to horizontal B+....before diode got about 100v and after diode got 158v that link direcyly to horizontal B+. So, what in the world happened to my tv? what should i check and do?
  • azhar mohammad Oct 11, 2006
    i already check there's +5v at remote control receiver LED on board..do you mean that my system (processor) ic got problem or other component? so, what if i got 8v at pin processor and what if i dont...?? please help me..!!
    Sergeant:
  • 337 Answers
This is like a car running without a driver,the horizonatl output transistor has the voltage it needs but it does not have horizontal drive signal applied to the base of the horizonatl driver transistor,the driver transistor should have a signal coming from the signal processor where the signal is generated just to get give it to the driver this driver then it gives it to the output to energize the flyback and light up the picture tube and generate a few other supplies,158 volts are there because the output is not turn on,try measuring voltage somewere else in the set and not at the collector of the output,there is a b+supply that goes to the signal processor(8 to 12 volts),check to see if you have this voltage,I couldn't tell you the pins in the siganl processor IC without squematic,It seems you know your way around tv service but be careful when checking voltages.Let Us know if you need more information.
Posted on Oct 10, 2006
  • 2 more comments
  • Omar Urrutia
    Omar Urrutia Oct 10, 2006
    Anothe thing....The power supply generates the voltage for the signal processor but the 5 volt supply for the micro(brain)branches off of that supply.If you are missing the 5 volats the brain will be dead too.
  • Omar Urrutia
    Omar Urrutia Oct 11, 2006
    If the 8 volts is missing it will be better since you can back track to were is generated and see were you loose it,it has to be there to start the horizontal oscilator,this one exits the processor to be base of the horizontal driver the dc volts at the collector of the driver should be only about 60 volts.
    Rating the response is important to the person helping you
  • Omar Urrutia
    I hope you have the service manual for the unit.
  • Omar Urrutia
    You need to check the collector voltage of the horizontal driver transistor.It should be only about 60 volts.let me know.
Samsung has standby light, it blinks tone sounds no green light. Replaced t-con, power supply and control boards.
Hi Patrick,
have a close look at your LVDS cable and screen ribbons for signs of failure or heat damage, and you could try to pull a picture from an AV output in various formats to see if it's the screen itself is failing in some way,
regards
George
Jun 29, 2016 | Samsung UN60D6000 60 Inch 1080p Smart TV...
My Samsung TV has only a faint picture and full sound.
My LED TV has sound, but no picture. - Tom's Guide
www.tomsguide.com/answers/id-2771720/led-sound-picture.html
Dec 28, 2015 - The RCA TVs generally only have a 1 year limited warranty so that ... LG LEDLG LED TV has no picture (black screen) but still has sound TV has ... I Have SAMSUNG UA46 F6400 LED 3D TV I want TO CONNECT MY ... SolvedSamsung ledTV no picture solution; Sony vizio led tv has faint picture solution ...
TV Has Sound But No Picture Troubleshooting Guide ...
? 2:30
https://www.youtube.com/watch?v=ysHfaQKI45M
Aug 31, 2012 - Uploaded by Repair.com
Here are some steps to ease you through TV picture loss-from prevention ... But now when I turn on the tv there only sound nopicture. ... had sound etc. with very very faint picture if you look very closely (which I was). .... How To Fix Samsung LCD TV -Samsung TV Repair (Blank Screen) - Duration: 9:21.
Samsung LCD TV No Picture but has Sound - Electronics ' DSLReports ...
www.dslreports.com > ... > Electronics
DSLReports
Jan 26, 2016 | Samsung Televison & Video
Have a Samsung LED TV 5201 series with no sound or picture what could this mean?
You have to check the power supply of the tv. It has two sections the standby power and the main power. As from your description the standby power side is ok . what you have to check is the main power section. here i have added a video which will help you understand how to proceed the reaping process.
http://electro-medical.blogspot.com/
Testing LCD TV Power Supply BoardsSTEP BY STEP
Nov 08, 2015 | Samsung Televison & Video
Samsung HDTV black screen no picture no sound
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Mar 12, 2017 | Televison & Video
Samsung HDTV no picture no sound
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 13, 2014 | Samsung UN22D5000NFXZA 22 In Led Hdtv...
Blank screen led light flashing on/off manual switches do not work
hi;
when your LCD TV wont start , even if you press the power button , it has a power supply failure, maybe some capacitor has bloated or changed value, try to watch this http://www.youtube.com if you know how to solder, or even disassemble the back of LCD TV. if not try to call a repair technician. thanks ,, hope this help........
Sep 10, 2011 | Samsung LN32A330 32 in. LCD TV
Tda9380ps /n3/3/1664 using in sharp tv power supply ok ,but no EHT ,the power LED are glowing red light press program key to change green light to return in few miniutes to standby in red light position...
tda9380ps /n3/3/1664 using in sharp tv power supply ok ,but no EHT ,the power LED are glowing red light press program key to change green light to return in few miniutes to standby in red light
Aug 30, 2011 | Sharp 21" Multi System Stereo TV
My samsung 46 in. hdtv will not power up when plugged in standby light is lit turn on then it flashes lamp led it after theen goes back to standby mode repeats this process three times then all three...
Have you Check the Lamp Fan is it still running while Lamp trys to light?Ballast board is what powers Lamp on ,but if the Lamp Fan is defective Lamp will not light.
Sep 10, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung TXJ2067 20" TV Logo
158 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
