Question about Kenmore 3.8 cu. ft. HE3t Front Load Washer
FO2 Error Msg
I followed your previous fix and I'm still getting the FO2 error message. Any advice?
    President:
  • 878 Answers
Hamish, F02 is long drain. Check that the drain hose is not kinked or plugged. Check the drain pump filter for lint and debris. Check the electrical connections at the pump and the fact the the pump is running. Make sure you are using HE detergent and that you are not over sudsing. Check the drain itself is not backing up. If all of the above are good, replace the pump...Catriver..post back.
Posted on Oct 11, 2006
Dear sir , i have a dell inspiron 1464 laptop.i have a problem during window installation.in a diagnostic test there are a error generate. the error code is, Error code 0146 Msg:Error...
Dear questioner after going through couple of posts on dell support forum I found that this problem occurs if your hard drive is not functioning well
If you laptop has warranty please visit the nearest dell store
Aug 06, 2011 | Computers & Internet
When I started my DELL Inspiron 1525 running Win 7 Ultimate, I got a white-on-black screen which questioned the voltage from power adapter. Diagnostic program run.. Stopped with the following msg: Error...
2000-0142 and 2000-0146 are hard drive SMART errors, indicating the HDD will fail.
To boot message about the AC adapter was a BIOS level message that normally appears when a Auto/air ac adapter or other 65 watt ac adapter is used to power the system.
Jul 16, 2011 | Dell Inspiron 1525 Laptop
Error Code: 0146 Msg: Error code 2000-0146 Msg : Unit 1:DST log contains previous error (s) please help me, how i can solve this problem
I am assuming that this is a problem on a dell computer? If so that error message is an indicator that your hard drive is probably going bad and you need to back up you data and get a new one ASAP. I believe that laptop takes 2.5" 9.5 mm sata laptop drives
May 17, 2011 | Computers & Internet
Hello, I have a laptop Dell Inspiron 1501. A two days ago I reinstalled Windows Vista, because I've had some problems wih my internet connection and some other. So I installed it and everything is ok,...
Hi!
It is not yet the end for your machine. The error codes refers to a faulty hard drive. You'll need a new hard drive for replacement and that will fix the problem.
Should you have any other questions just leave a message.
All the best!
Musicaddict
Sep 15, 2010 | Computers & Internet
Dell studio windows failed to start. error code 2000-0146
the Error code was sited below as the (Disk Self Test) DST Log contains previous error(s)
in case of your error DST log contains previous error(s) doing a
chkdsk /r or a repair reinstall of xp might resolve the issue.
to resolve issue...
Error Code Error Message 1000-0141
or
2000-0141 No Drive Detected 1000-0142
or
2000-0142 Drive Self Test Failed Status Byte=XXh 1000-0143
or
2000-0143 Drive Smart Read Command Failed 1000-0144
or
2000-0144 No Support for Drive Self Test Error Code Error Message 1000-0145
or
2000-0145 Timeout waiting for Drive Self Test to complete 1000-0146
or
2000-0146 DST Log contains previous error(s) 1000-0147
or
2000-0147 Unit (x): IDE status failed. Status byte = (x) Control Code = (x) Msg = (s) 1000-0148
or
2000-0148 IDE ERROR: status (x) (s)
Aug 07, 2010 | Dell Studio 17 Laptop
System error on plotter screen
Follow-up to previous message... ended unexpectedly.
Enter the test mode and run the ELECTRONICS test. The plotter will tell you in plain English what the problem is. If it hangs up, power down.
Jul 06, 2010 | HP DesignJet 1050c plus InkJet Printer
Error Code: 1000-0146; MSG: Unit 0:DST Log contains previous erro
Code 0146 is hard drive read/write failure.
Replace the hard disk drive
Jan 27, 2010 | Dell Inspiron 6000 Notebook
Error when try to print from computer
Check what the error message is? Normally this problem comes if the printer is installed and either has not been calibrated or has one or more driver files corrupted.Try to tighten all the wires again. Than uninstall and reinstall. And try to use any disk cleanup utility before reinstalling because some times it can have previous corrupted files in the disk. you can use windows disk cleanup utility.
If my advice helped you please feel free to rate me.
Thanks
Mar 18, 2009 | Epson Stylus NX400 InkJet Printer
FO2 Error Msg
ok now ,,check why water is not leaving machine on time,,,check your drain pipe,,check the drain hose,,just blow in it and make sure a coin not stck there ,,the same with the waste pipe,,onthejob
Feb 18, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Washing Machines Logo
137 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
