Question about Brother Office Equipment & Supplies
Fax machine will not stop sending same fax ovr and over
  • 2,120 Answers
When it starts to dial the number, press stop/cancel.
Posted on Nov 07, 2008
Using a brother MFC-J415W printer, what are the steps in sending a fax?
How to fax :
1. Entering fax mode To enter fax mode press (Fax), and the key will glow green.
2. Sending a fax from the ADF (Automatic Document Feeder): Using the ADF to send your faxes is the easiest way. To cancel a fax in progress press Stop/Exit.
a. Make sure you are in Fax mode . b. Place your document face up in the ADF. c. Dial the fax number. d. Press Start.
The machine scans the pages into memory and then sends the document.
3. Sending a fax from the scanner glass : You can use the scanner glass to fax the pages of a book, or a single page at a time. The documents can be up to Letter or A4 size. Press Stop/Exit to cancel a fax in progress.
a. Make sure you are in Fax mode . b. Place your document face down on the scanner glass. c. Dial the fax number. d. Press Start.The machine starts scanning the first page.
For more detailed instructions, you can go directly to Section 4 - page 22 of the manual in Brother's site. Hope this helps.
Apr 14, 2011 | Office Equipment & Supplies
Fax does try and send but then stops and prints an error page err 388 each time?
The remote fax machine might be defective.
  • Try to verify this by sending the same fax to other fax machines. If these transmissions are successful, then notify the user of the remote machine to make them aware of the issue.
  • If the fax fails when sending to other machines, turn it off for 10 seconds, turn back on, and then try sending again.
If you need more help come back.
Post / thumbs / testimonial are welcome!
Jan 05, 2011 | HP Officejet 6500 Wireless All-in-One...
The fax machine will not send a fax. What should I check to fix this problem.
The only thing that could stop you from sending a fax or not get a dial tone, would be the connection to the phone line. Make sure the telephone wire is plugged into the line jack (not ext jack) and should go straight to the wall, without splitters or extensions. If you still cannot send a fax, try another wire or jack
Apr 08, 2010 | Brother IntelliFAX 2800 Laser Fax
When we start to send a fax the machine shows "memory" in the window and the fax will not go through. If we continue to try, after 3-4 times the fax will finally go through. Any idea what we can do to stop...
If this is a newer style machine...most units scan the pages into memory before they send it. What are you trying to send???? is it a complex color brochure..????
Try sending a simple page of type and see if the machine does the same thing. This may be a limitation of the memory capacity of your machine.
Apr 07, 2010 | Office Equipment & Supplies
Our HP Officejet 5600 won't receive faxes.
Here is the answer to your question.
Error code 244 can mean any of the following things: :
1. You or the person sending the fax pressed the STOP key , causing the session to stop before completion.
2. The fax machine on the other end determined that there is an incompatibility with your machine and the one you are sending to and stopped the fax session.
To fix this you can try the following things. Try them one at a time, and if they don't work, place them back the way they where before you changed it.
  • Make sure the fax machine you are sending to can accept and use polling.
  • Select a slower "receive" speed.
  • Enable or disable the ECM setting.
Error Code: 232
1. Can mean that a communication failure has happened between the two machines.
2. It may also mean that the user of the FAX machine you are sending to has pressed the STOP key
3. If call waiting is enabled, it may cause this error. Disable call waiting on your phone line, if you have a fax machine connected to it. The click or beep on the line that indicates you have a incoming call, can STOP a fax session.
4. Another cause of this error code is that the power was interrupted to the machine you are attempting to send a fax to.
Things you can do to solve this problem: Try them one at a time, and if they don't work, place them back the way they where before you changed it.
  • Try disableing ECM. However, this may reduce the quality of your faxes.
  • Ask the person you are sending the fax to to set the machine to receive at a slower speed.
  • Try the fax again at a different time, incase it is a problem with the phone line.
  • If you phone lines are old, or there is static on the line it may cause trouble sending a fax.If this is the case you will need to contact your local phone company or whoever is responsible for servicing your phone lines.
Jun 22, 2009 | HP Officejet 5610 All-In-One InkJet...
I cannot re-set my Brother 575 fax machine to send a fax. What are the steps to reset it? I do not have the correct manual to seek out the steps to re-set this machine. It was working a few days ago but I...
No settings you could have changed would keep it from "sending"...."receiving", yes. If you are sure it is plugged into the proper jack on the machine (line), and the phone line has a dial tone, you're problem is more serious
Mar 08, 2009 | Brother Office Equipment & Supplies
Sending fax
If you sending the fax over the memory, fax can scann doc. while dialing, or in the same time, but if you sending directly (on-hook dial) fax is sending the document while beeing reeded.
You may try to check the phone lines, browse the documents before sending,clean the original document feed rollers,...
if fax sudenly stops and wrinkle the orig. documents there is problem in scanner area
Jan 16, 2009 | Canon FAX-JX200
Fax not printing
Where can I find the solution?
Jun 25, 2008 | Samsung SF-5100 Plain Paper Laser Fax
Fax wont send
try sending to another machine and also from a different telephone line if possible.Also does this machine receive a fax.Noise on telephone line can cause such problems.
Feb 27, 2008 | Panasonic KX-FPG376 Plain Paper Thermal...
When sending faxes, error pages always follows fax
go into menu -initial setup- look for the option that says tx report or com journal and set that to incomplete only or off, sounds like it is set to always. if the setting is not in the menu i mentioned keep scrolling through youll find it
Feb 26, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
35 people viewed this question
James Cagle
James Cagle
Jim Keysor
