Question about MPC Computers AOC 7F 17" CRT Monitor
There is power but no display
Hi my computer is ok but am having problems with the monitor and the problem is that the monitors power is on but there is no display. the first time i noticed it, i tried turning it off and on agian and i came but the next day when turned on, there was no display, i've tried this for more than five times thinking it would come as it came the first time but to no avail. please help me. but can it be the cuase of a power failure? . because here in my country there is alot of electrical power failure.
  • 12 more comments
  • myhunt Nov 18, 2007
    no screen, just a floating box that says check signal cable
  • debbierey Dec 16, 2007
    How can I tell if my monitor is fried? It is a Hyundai L91A flat screen and the green light flashes on and off but there is no display, it doesny go on.
  • Paul McNally Dec 31, 2007
    Unit Samsung Syncmaster 741MP
    My screen also does not show a display, yet if I keep pressing the menu to seek another input the display will flash up for a couple of seconds and then go blank.
  • Anonymous Jan 03, 2008
    My LG Monitor (500g) display goes off during any operation and then then i hv to push on / off switch continuously to get back my display.. sometime its on and after couple of mintues later same thing happend again.. sometime i hv to keep the monitor for 2/3 hours to get back its display.. sometime this problem appear very frequently .i.e. between 10-5 mints.. sometime for a long period it doesnt create a problem say 3/4 hours... during display off time when i try the on/ off switch i heard a less tick sound and when i heard a big tick noise i know that display is going to back.. sorry for my worng english... If any one had same problem and solved the same.. then plz help me .. thanks in advance
  • Alanski Jan 07, 2008
    I have same problem as :myhunt" do.
    No display on the monitor.
    At first,the pilot light is green,
    then after a while it turned orange.
    What shall I do ?
    I've got blank display to work with.
  • scamb66 Feb 28, 2008
    I have 4 monitors all the same age (Oct06) which have all failed within 2 months of each other. If it is unplugged for a day or two it will fire up again. These monitors run 24 hours a day. When replaced with other monitors it is no problems.
  • Njso Feb 29, 2008
    Hi, I've got a ProView flat screen that became like that after a power surge.
    Basically, it turned on when I pushed the On button. Yellow LED switched to green. Then, after 2 or 3 seconds it went blank.
    So, suspected from the backlight inverter board: a Sampo QPWBGL8981DG PCB. Replaced the two 330pF / 3kV capacitors after the small transformers.
    I then thought I had repaired it for good.
    After switch ON, I can now get an image for 1 or 2 minutes. But then it goes blank (no image) again. LED keeps green. If I switch it OFF and ON again, image comes back on for a shorter time, say 5 seconds, and OFF it goes again. If I keep doing this Off and On switching, it keeps showing an image for 3 seconds each of the times. But I can't seem to keep the image on forever!
    Does anyone know what else could be damaged (besides the capacitors) on that Sampo Backlight inverter board?
    Regards,
    Njso
  • Redlizzie Mar 22, 2008
    My 17 inch Dell monitor powers up with no image. It flickers , but will not hold the image.
    We have suffered power outages and brown outs this winter. Is this repairable?
    It is not the video card as we have hooked up an old monitor.
  • Anonymous Mar 26, 2008
    aoc crt monitor
  • matsrul Apr 28, 2008
    power is ok but no display on the screen
  • dipankarbd Jun 17, 2008
    I have the same problem. Some times display comes. ut it is uncertain.
  • Anonymous Sep 30, 2008
    Monitor power green light is on and monitor is connected to computer but iam geting no picture.
  • midnightmayf Jan 16, 2009
    i am haveing the same problem monitoris on but the screen is black and i have a orange light. any info on how i can solve this. i have tried umplugging it and pluggingit backin,themonitor is only 2 months old
  • Anonymous Jan 26, 2009
    I've had my monitor for a couple of years, and today, after I turned on the PC< the screen went blank. Recycling power, the display would return, but only for a second before going blank again. Problem remained after several iterations of this.
  • 105 Answers
Your symptom is commonly caused by failure if the inverter circuit. It is made by Sampo. The inverter powers the backlights. Replacing the inverter is the first step to resolve the problem.
Posted on Oct 11, 2006
  • Monitor power green light is on and monitor is connected to computer but iam geting no picture. qasim972@yahoo.com
Posted on Mar 13, 2011
If there is green light on monitor.so you just check the vga card and ram.First check both are placed in the slot correctly or not.if it is so then replace new one by one .then you can catch what is the problem.and can fix by urself.
Posted on Jun 04, 2010
  • 3 Answers
As one of my "initial things to do," I unplugged the monitor and then replugged it in and it did not fix anything.  Then after reading others' solutions, I unplugged the monitor and let it sit for about 15 minutes. Once I plugged it back in, it worked just fine. My setup is a laptop with docking station - the monitor in question is attached to the docking station as a dual-screen setup.  Though this may not matter technically, it might help those searching for solutions. Thx! Jake
Posted on Feb 09, 2009
    Scholar:
  • 94 Answers
Without much information given as to the state of the monitor - Check the LED on front. If Orange, it's getting power and the has a problem. It could be: Fuse Digital Board Power Supply If Green Check the Video Card on PC If None/Off (with unit unplugged) Sniff & Check the power supply board of the display. for Fuse and Visible damage.
Posted on Oct 13, 2006
    President:
  • 2,961 Answers
Try, if you can another monitor, if same problem, check graphics card connections(connection to your monitor) and if you are able re seat graphics card. If you have frequent power failures, you probably have power surges, this can be a problem as they can fry various components on the motherboard, check that you are getting 2 beeps from your pc when starting it up, if there isn't, your pc is not booting up and your monitor will probably display an orange light (stand by) instead of green.
Posted on Oct 10, 2006
    New Friend:
When i turn it on it doesnt have beeps and the monitor is LED is orange, and when i turn on computer and i try to turn it off it dosnt work, i need to swith off the power from the back of the monitor. anybody have a solution
Posted on Dec 22, 2012
My AOC 17" monitor
during operational it will suddenly off but if i will top or move the monitor it will turns on
Posted on Apr 09, 2009
I eventually contacted Samsung support and basically it is a component failure so a new unit was supplied under warranty. Unfortunately there was no software fix they had available.
Best Regards
Paul
Posted on Apr 14, 2009
4 Suggested Answers
rosener
  • 103 Answers
SOURCE: Monitor not Display
Hi Rey,
Hope this helps you like what I did to resolve this kinda problem. If you can manage to open the chassis/cover check first if the HOT (horizontal output transistor) is good, if good check the SMPS (switching mode power supply) primary and secondary side if there are short filter capacitors, diodes, transistors and open resistors. Major faults to consider is by checking the load of SMPS, control circuit, driver circuit, feedback ckt.
Please let somebody to assist you (a certified technician) how to open the chassis safely due to electric shock. Please be guided accordingly.
Best regards,
Rosener Guyano
Posted on Jan 30, 2008
jemmyrash
  • 180 Answers
SOURCE: BenQ FP7IB LCD monitor, turn black aftr BenQ logo
Try to plug into another computer and wait to see.
If it turn up to be same it somewhere defect from the main board of the lcd.
If if not the same turn up to be, you should reinstall the OS because the software is corrupted or your display card problem.
Posted on Apr 21, 2008
pravinbhavsa
  • 348 Answers
SOURCE: panview 15" crt
yes first you open the monitor then take output of smps if present then turn the knob behind eht untill the brightness with picture will not come
Posted on Oct 30, 2008
The problem of my lg monitor sometime not working properly continues blinking only,sometime good condition
If you monitor light coming then ok, but i think RAM not proper display so you check it keyword numlock button light or not. If numlock Light coming then your PC ok. And then you change monitor power cable and change it. or some time disconnect monitor power or also disconnect cup attachment. then reconnect proper i hope solved you problem.
If not Solved then contact Good PC Technician.
Thanks.
Tech Support Mart Computer Support
Feb 17, 2014 | Computers & Internet
Motherbord run but not dishplay
MY DEAR FRIEND
CAN you tell me the what is the display problem
OK
Apr 11, 2011 | Intel Motherboard
I have prolem in samsung LED that no display shown when i turn on....can you please advice. thanks....Peter
send me detail on jogindersingh47@yahoo.com 1) if yours LED power on and display of window not giving then problem from cpu. a. first replace yours RAM and check display. b. then display cable and check display. c. Install new Display card and check display, if not giving display it means motherboard have a problem 2) LED not giving power on then problem from monitor a. replace monitor power cable and check display b. monitor logic card have aproblem
Mar 16, 2011 | MPC Computers AOC 7F 17" CRT Monitor
Blank display on the Monitor when connected to main system
if u feel the problem with you display cable then try to replace that
May 12, 2010 | Philips 107E56 17" CRT Monitor
Will not power up. Is there an internal fuse?
Try to diagnose the problem .
Replace the monitor and see if u get the signal...if u get display with another monitor then motherboard is ok.
are you seeing a picture before it goes off?
make sure the DVI or VGA cable is securely fitted into the monitor and the computer
go to the menu and check that its power saving timer isn't set too low.
Probably not, unplug the monitor for about 5 minutes, this may reset it. You may also want to unplug the power strip to see if that resets.
Jan 29, 2010 | Acer 22" X223w LCD Monitor
Having the same problem as others, my 912n monitor is a black
The problem seems to be that the computer, do not recognize “which monitor’s connected?” Follow these steps to correct the problem: Shutdown the monitor, next shutdown the computer. Unplug” the monitor, from the power outlet. Disconnect all cables on the Monitor from the computer. Next, reconnect all cables, and power, in the reverse order. Start computer first! Turn on the monitor, (right) click on an empty area of your Desktop Screen; next click Personalize, click Display Settings, click Identify Monitor. At this point, the monitor should be present, click on monitor. To finalize the application, click Apply! Next, click (OK). To “Fix” the (Resolution): Part: (1) Click Display Settings, adjust “resolution.” Click, Advanced Settings, “click” Properties, click on Drivers, “click” Update Drivers; click “OK!” Part: (2) Right click on “Desktop”, (in the upper area) check if the Graphic ™ Control Center is visibly presents, if so, click to open. You can adjust the Graphic Settings. Click “Apply” next, “OK” when finished! Restart the computer. I hope this Fix it.
Jan 17, 2010 | Samsung SyncMaster 912N 19" Flat Panel LCD...
Acer Model AL1916W A reads no signal after being on for 1 hr
Jan 22, 2009 | Acer AL1916W 19" LCD Monitor
MONITOR
Hi ,
Log in as Administrator , Go to Control panel
Open Display -> Select Screen Saver Option -> Click on Power
There is Option Turn off Monitor select never option. and
There is other option System Stand by select Never..
Click OK click apply and again click OK....
This will definitely work for u r problem
Sep 05, 2008 | Computers & Internet
Monitor keeps blank even the power lLED is on green
Try replacin a new display card. If it is fine working.ok
If not try fixing for cold solder in the video section.
I suggest video section according your report the light green LED lighted that shows the power section is doing fine.
Apr 22, 2008 | Proview PL913S 19" Flat Panel LCD Monitor
If it's working fine in DOS, it can only be your display drivers for your operating system. What happes when you start in SAFE MODE? When you PC starts, keep pressing the F8 key, go to Safe Mode. If it works, bring the Resolution down to 800 X 600 and load the new display card drivers. Restart, should be fine.
Apr 22, 2008 | Philips Standard 104S 14" cRT Monitor
MPC Computers AOC 7F 17" CRT Monitor Logo
4,767 people viewed this question
Top MPC Computers Computers & Internet Experts
Paul Bade
Muggs01
Muggs01
Mark Gough
Are you a MPC Computers Computer and Internet Expert? Answer questions, earn points and help others
