Cameras Logo
Anonymous Posted on Mar 20, 2012
My new panasonic lumixDMC-ZS8 14.1MP Digital camera gives me system error (zoom) when I turn it on.the lens will not open?
When I turn my camera on a message System Error (Zoom) appears and the lens does not open ..camera does not function?
Anonymous
Level 3:
  • Panasonic Master 6,771 Answers
  • Posted on Mar 21, 2012
Anonymous
Panasonic Master
Level 3:
Answers
6771
Questions
0
Helped
1779260
Points
21413
The systems control board has detected a fault wth the lens, over time dirt and grime collect in the len causing havoc, the other concern is the gears have jammed or got damaged, either way it is a major dis-assembly and it will be expensive.
Testimonial: "Thank you ..the camera has been returned to the panasonic centre for review.. it is only 3 month old.. just suddenly locked."
  • Anonymous Mar 21, 2012
    Thank you for keeping me informed, you should have no trouble with warranty, this clearly is a manufacture issue.
5 Related Answers
Anonymous
  • 919 Answers
  • Posted on Apr 29, 2009
SOURCE: Zoom Error message
The problem you are describing is a problem with a sensor in the lens assembly of the camera. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $167.85 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
Anonymous
  • 11967 Answers
  • Posted on Jul 17, 2010
SOURCE: I have a DMC-ZR1 camera. Having problems with
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Anonymous
  • 18 Answers
  • Posted on Mar 16, 2010
SOURCE: panasonic lumix dmc-fx37. Two error messages are
sounds like the focus and (Optical Image Stabilization)drive motors are bound or broken, sadly this normaly means new camera, unless there are no marks on the case and they wouldn't think that it had been dropped or gotten wet, well ya know, they will normaly repair or replace it as long as it is due to manufacture defect.
Testimonial: "thanks for your help. "
Anonymous
  • Posted on Feb 19, 2008
SOURCE: fuji finepix A600 camera - Zoom error
I had the same problem turn up after a few weeks. When I used the zoom button, the lens pushed out again and the camera worked normally for that time. I had to go through that procedure every time I turned the camera on.
I then sent it back on warranty and they replaced the lens assembly as well as the mode dial knob etc.
This camera has a 3 year warranty.
good luck...
Anonymous
  • 6831 Answers
  • Posted on Oct 07, 2010
SOURCE: system error (zoom) camera frozen Panasonic Lumix DMC-LZ28
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
I dropped my Panasonic LumixDMC-ZS19 and now when I turn it on, it cycles, but then says Zoom error and won't pop out the lens. Help! I need it!
Hi, it looks like you have damaged the zoom mechanism that's why it will not zoom out . The unit will have to be repaired best to get a quote for repair first.
System error Zoom
Lens errors (system error zoom on Panasonics) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
6helpful
When i turn on my panasonic lumix dmc fz28 it shows system error
HI there the camera lens guide pin is damages and thats why not zoom the image properly . You got the system error message. So you need to replaced or repair the lens guide pin. Thanks.
9helpful
Systems error (zoom)
there is a small gear on inside zoom lense that one not working chaing that part
1helpful
Nikon coolpix 775 digital camera
try these:-
  • connect it to pc and on it
  • vaccum the barrel of lens
  • changing mem. card and batt. for 2min.
  • shake it.
  • on and off in different positions
  • hit the part near lens softly with palm (trust me this made mine work)
1helpful
Lens stuck
It sound like a problem with the zooming mechanism (lens would not retract or extended) Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Top Panasonic Cameras Experts
ZJ Limited
ZJ Limited
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
