Ive just created a computer and put all the staff together. the problem is that it beeps one time before showing the screen and i cant press anything as it sais to press the delete button go into boor menu. motherboard p5b
  • mixalis00000 Nov 05, 2008
    how do i troubleshoot the motherboard if i cant do anything when it startes?
  • 4,338 Answers
The system is having a problem accessing the system memory to refresh it. Refreshing is done on all system memory to keep its contents active. Diagnosis: This code usually means a problem either with the system memory or with the motherboard itself.
Recommendation:
Troubleshoot the motherboard.
Treat as an apparent memory failure.
Make sure the the memory DIMM is compatible with the motherboard.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 05, 2008
Hey who ever this is im having bad problems with my motherboard or my bios ive tried everything i got ECS C51GM motherboard with the 6100 nvidia video display. icant run any full screen programs cause it...
Its not a bios problem but on insertion of video card your ram got some tampered. Just reinsert the video card and your ram properly and now start your system. It might solve your problem.
May 20, 2010 | ECS C51GM-M Motherboard
Sansa fuze 4g isn't recognized by computer...won't charge, screen only shows "writing" screen when body of mp3 player is pressed together...any ideas?
When i plug my Fuze in the pc, it turns on, but doesnt charge, and isnt even recongnized by my pc. So i cant put anything on it and it doesnt even show up in device manager.
Dec 26, 2009 | SanDisk Sansa Fuze MP3 Player
Everything is connected, i can hear it, but cant see it
The previous answer is partly right. Are you both using HDMI, or are you changing connection method. If you change method, you must reset the graphics settings, which can be a bit tricky without a screen. Turn off your PS3, then Press AND HOLD on the Power Symbol for some time, or until you hear the beeps, and the flight flashes green, then, it should work.
Sep 24, 2009 | Sony Playstation 3 (PS3) Console
My playstation console will turn on, but it is not showing a picture and not allowing my wireless controller to connect
ive had 3 problems with my ps3s and this was one of them, theres not a lot you can do, u cant reset it or try anything because u cant see the screen menu or anything probably yeh? sony will send you an exchange for cheap or nothing if under warranty.
Jul 31, 2009 | Sony Playstation 3 (PS3) Console
Tried everthing just cant get this thing to boot up
Sounds like you may need your screen replaced.
Upon turning on your laptop,
Keep pressing F8, until you hear a beep. This will give you the option to boot to safe mode. When you hear a beep, and NOTHING comes on your screen within 20 seconds, you need to have your LCD screen replaced.
Typically if its a hardware problem such as RAM, you'll hear 2 beeps or a POST message will display on your screen, letting you know that a certain piece of hardware failed.
Ive seen problems occur when people change a setting such as :
Right click on your desktop --> Properties --> Settings --> Advanced Button
And changing your DPI. This can cause your screen to go out (Not display anything). If its up to high chances are your LCD screen can not handle it. If you boot to safe mode, then you can fix this. Again if you cant boot to safe mode, then you have a mad LCD.
Give this a try and let me know what happens.
Oh one more things.
One thing i have also seen, more than once, and till this day i can not explain it, but a USB device plugged in. Remove ANY USB device plugged to your computer. Printer, FLASH Drive, Mouse, etc. Then turn on your computer.
If you have a floppy drive, remove the floppy.
If you have a CD/DVD in your tray, turn the computer on to take it out.
May 21, 2009 | HP Compaq Presario 2200 Notebook
Shows to connect to itunes on the screen
The ipod should let you do a restore in itunes with the computer that last synced the ipod. This is the only way to remove the passcode.
If it wont simply show up on the computer, plug the ipod in, hold the power button and then slide to power off. Press the power button, as soon as the apple logo appears press and hold both the top power button and the home button together until the orange triangle appears. This should put the iPhone into restore mode, open itunes and restore.
Nathan.
Apr 09, 2009 | Apple iPod touch
Bios Password Screen has popped up out of nowhere
I see theres been a reply but this is the first time Ive seen this thread.
so first off when you got the pc did you need a password because thread say password screen just appeared...assuming you didnt need password I assume youve installed either wireless package or a wireless client utility.for some odd reason installing wireless client also installs password utility which then appears the next time you boot with no fields filled in .you simply press enter without typing anything in.if that isnt your case and cant access os.
download a program (free) called spotmau.unpack/unzip read the txt instructions .create a bootdisk and copy the files to it.restart pc with created bootdisk in cd tray ....when the disk boots its programs choose remove all passwords.the free version
Dec 10, 2008 | Toshiba Satellite A135-S4527 Notebook
Wont Start (brand new) Just Beeps!
make sure the bobbin winder is not engaged and thread the machine over ,also check that the buttonhole switch is not down
Aug 18, 2008 | Singer 7442 Mechanical Sewing Machine
My m250 froze up and cant get anything to do anything pc nor mp3 player
LOL - It's still not working? Surprised you haven't trashed it by now. Well I have the answer - call me and I will tell you.
Jul 16, 2008 | SanDisk Sansa m200 (2 GB) MP3 Player
Help
dont waste your time is not the video card, Idont know what you put together but if you change the motherboard you have to give some info to it, and thas a technical job look for a tech....good luck
Aug 04, 2006 | Albatron PX865PE Pro Motherboard
Computers & Internet Logo
David Payne
David Payne
