Question about Sony Cyber-shot DSC-W70 Digital Camera
Troubleshooter My camera is not snapping pictures. When you click the button nothing happens. The camera is now open in the zoom position. What seems to be the problem
  • 67 Answers
There are many reasons but to simplify it could be:
-camera processor is busy
-click button is damaged
-corrupted firmware (sony only can fix this)
best recommendation get a quote from sony if its too high ($300) then buy a new camera (cannon , nikion of fuji they all have quite better quality than sony), if its around 100 go for it.
Posted on Nov 14, 2008
Why does my Panasonic DMCFZ28 take pictures when I push the zoom lever?
I suspect the snap key is shot circuited, use contact cleaner spray in the click button often press it to get ride of possible carbon shot circuit between the switch. in some cases the processor will malfunction, and if moisture or water particles gone inside, you must open the cam and clean the motherboard thoroughly with PCB cleaning agent.
Apr 10, 2016 | Panasonic Lumix DMC-FZ28 Digital Camera
I push the button but it wont take a picture
Did you try it like it is said in the manual? press the button half till the camera is focused and then press the button completely down?
Don't expect the camera to shoot with the same speed as a camera with film did. Give it some time to focus and everything will be fine (I hope)
If not let me know.
Jan 02, 2014 | Sanyo vpc-s1415 - Vpc-s1415 14.0...
I cannot take a picture with I my imate ultimate 9502 mobile when i click camera button nothing happens only keypad glows some little sound and snap square window thts all but No picture----also i have to...
This problem may be due to insuffient memory. go to start, setting, system, memory, running programms and stop programs that u dont require at present moment and then u try pressing the camera key. it should work.
Jan 07, 2010 | Cell Phones
Powershot A620 Zoom Lever
Remove your batteries and look inside the battery compartment. Notice that there should be three small phillips screws at the bottom of the compartment. Tighten up all of these screws.
May 12, 2008 | Canon PowerShot A620 Digital Camera
Malfunctioning of Nikon 2100
I had the same problem.The shutter button is faulty and is always half pressed - auto focus is operational (this is the step before actually the picture is taken. Try to clean it up with some special electrical contact spray. if this does not work - need to replace it - Not a simple job for the novice. You might need to take the camera to a service center for a spare on-off-expose button. I had an old faulty camera where I took the button from it. That solved the problem.
Nov 27, 2007 | Nikon Coolpix 2100 Digital Camera
Sony DSC-P72 won't snap a picture
Have you done a "hard" reset?
Under the jack cover (below the zoom rocker on the back of the camera) there is a small "reset" button. You'll need to press it with a sharp object, and hold it down for a few seconds. If it was a setting problem, this should resolve it.
Nov 11, 2007 | Sony Cyber-Shot DSC-P72 Digital Camera
Nothing happens when I press button to snap a picture
its not a great problem. but the thing is
1>>you have been handling it in quite rough manner
2>>the camera must be a very old aged one
3>>must be a faulty piece.
the buttoon has got loose. u wont get charged much for fixing this in service centre. so u its not a big deal to spend few bugs for camera.
Oct 07, 2007 | Canon PowerShot A540 Digital Camera
Not focusing
Do you hear any unusual friction noise while the lens assembly projects out.. if so then the traction assembly of your zoom barrel has developed mechanical obstruction, in which case it has to be serviced. Take it to the service centre and the problem will be solved. If the zoom assembly does not fully extent to its homing position, the camera retracts and lens and powers itself off. Enjoy
Aug 16, 2007 | Olympus FE-230 Digital Camera
Trimming function won't work
This is Digital Zoom I take it. best to ignore it then and do all image editing in an image editor. Do get onto Panasonic Tech Support that may have an answer for you.
Jun 21, 2007 | Panasonic Lumix DMC-TZ3 Digital Camera
Camera takes pictures continuously
it is normal on the camera. just avoid pressing the snap button at the upper part near the zoom control.
Nov 05, 2006 | Canon ZR200 Mini DV Digital Camcorder
Sony Cyber-shot DSC-W70 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
