Question about Stanton C.304
No sound going through inputs on Stanton RM-3s mixer
Yesterday the adaptor for my mixer blew and I bought an Eagle switchable power supply adaptor to replace it. When I plug it in to my mixer, power is clearly running through it and I have the adaptor set to 12 volts, however there is no sound from my decks running through the mixer - I can hear nothing through the headphones and the channel level guages are not lighting up!
I have not unplugged my decks or headphones from the mixer - the only change has been the new power supply adaptor. Is there an explanation for this?
  • Anonymous Feb 07, 2009
    Same exact problem with my Stanton SA12 mixer.  Worked fine before.  Same set up.  Original power supply.  All lights come on.  BUT... no sound output at all...not even in the headphones.  Not even a hiss...  Still looking for a solution....
2 Suggested Answers
SOURCE: Stanton rm-3s
make sujre, it is a 1amp power supply
Posted on Sep 22, 2011
I HAVE AN AC ADAPTOR,… CLASS 2 TRANFORMER FOR OUTDOOR USE THAT NEEDS TO BE REPLACED.. MODEL: KMUA - 240 - 05000- 66UL INPUT: 120V - 60Hz 570mA OUTUT: 24V - 50VA
Amazon has it.
AC Power Adapter 120V input 24V 50W (50VA) output, UL listed
www.amazon.com › ... › AC Adapters
Mobile-friendly - AC 24V Power Adapter; 50W Output (50VA); 120V AC Input; UL Listed; Ivory Color item in OEM box ... 24V20AC 24V AC 20VA Transformer Input: AC 110V / 120V 60Hz Output: AC 24V 880mA
Dec 09, 2015 | Computers & Internet
Help behringer xenyx 1002fx !!
If you registered your mixer there will be a three year warranty so get it back to your local Behringer service depot. If not check the output from the PSU, if that's OK then I'm afraid it is very unlikey to be economical to repair. Sell it as spares and repairs on eBay.
May 25, 2014 | Behringer Xenyx 1002fx Mixer 10 Input 2...
Put wrong power supply into unit
You probably blew it. It sounds like the power supply put out more voltage then needed. Also they come in AC/DC, putting AC into a DC input usually blows things, dC into an AC normally does not hurt it assuming the voltages are in range in all cases.
Jan 12, 2013 | American Audio VMS2 VMS702 Table Top MIDI...
Hello I have a JBL on stage 2 that I bought in the
Congratulations. You are among the first to approach us after having done a lot of the research up front instead of considering us a proxy Search Engine secretary.
I'm going with OS200ID as the unit's model number.
The DC input and physical fit are the only considerations for the dock's power - 12V/1.25A.
Item 190555626796 IS indeed a universal voltage (100-240 vac) sourced supply. The seller, DIGIDAVE, http://www.digidave.co.uk/help invites queries, too.
I'd say this is exactly what you need to use the the OS anywhere on the planet with a plug adapter.
Jul 18, 2011 | JBL On Stage Speaker Dock for Apple iPod...
I have a T62 Stanton and I want to play it like a normal turntable. I conected it in the Behringer mixer using L/R cable. I cannot hear the bass sounds with my headphones. What is happening?
Is it connected to a "PHONO" input or something not labeled explicitly for PHONO?
"PHONO" is the only designated connection on an audio device that is literal and exclusive.Nothing but PHONO will work right on it and old-school turntables would require it to preamplify the tiny current produced by a Phono cartridge.
If your unit doesn't have a PHONO connection you will have to get a Phono Preamp to connect between the TT and any Line Level input, like Aux.
eBay always has some... http://shop.ebay.com/?_from=R40&_trksid=p3984.m570.l1311&_nkw=phono+preamp&_sacat=See-All-Categories
Apr 17, 2011 | Stanton T62 Turntable
Xenyx 1002fx Mixer 10 Input 2 Bus with Efx: behringer mixer power goes off after running about...
Problem is likely thermal. Open unit carefully and use freeze mist (circuit cooler) to find bad component.
With that long a time period, it is possibly a component mounted on a heatsink.
May 18, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
Stanton rm-3s
Sep 26, 2009 | Stanton C.304
Hooking up sound system
The RSQ player goes into the input section of the mixer.
The mixer effect send goes to the Quadraverb input and the output of the Quadraverb goes back to the effect in on the mixer. Now the Main out on the mixer goes to the EQ then the EQ goes to the compressor/limitor to power amp to speakers.
Apr 02, 2009 | Stanton Sa3 DJ Mixer With Eq System
STANTON STR8-150 Sound levels
try different rca leads to amp
Jun 01, 2008 | Stanton STR8-150 Turntable
STANTON SK-FIVE MIXER HOOK UP
are the gnds connected(earths) you get a buzzin noise if not earthed
May 15, 2008 | Stanton Sk2f DJ Scratch Mixer - Good...
Stanton C.304 Logo
360 people viewed this question
Top Stanton Audio Players & Recorders Experts
 Grubhead
Grubhead
da surgen
Are you a Stanton Audio Player and Recorder Expert? Answer questions, earn points and help others
