Question about Dewalt DW056 18 Volt Cordless Impact Driver - 1/4" Drive Hex Shank (Battery Charger and Case Not Included) - Tool Only
Clicking, little tork
There is very little tork, and clicks.
  • yadayada
    yadayada May 11, 2010
    This sounds like you need another battery, have you changed the battery?
  • 23 Answers
Low toque and a clicking sound usually indicates a problem with the clutch, or a problem with the anvil. unfortunately with this impact driver, dewalt only sells the "mechanism" as a whole piece for $88 US.
if it is just a worn anvil then it should only cost around $18 US
Posted on Nov 19, 2008
I have a new Tork 1102 timer 240V. It works dial rotates clicks on and off but loses four hours in a 24 hour period what is wrong.
The timer motor is syncronous and meant to run on 208-277 Volt, 60 cycles per second. It appears that you have 50 cycle current running it, which would result in a 4 hour loss in every 24 hour period. There is no adjustment for this.
Sep 13, 2016 | TORK Hardware & Accessories
Tork Timer 1101 Noisey!!
Spray gears with WD40. And blow out timer with air. Turn off power: WD40 vapor is highly flammable accelerant.
Do not spray WD40 on live electric connections or hot surface.
Install timer on non-wood surface so sound does not resonate sound like a wood violin.
You can also buy replacement clock motor #101 for about $48.
Or buy the T1101M replacement mechanism for $59 and screw into current box, or buy whole new T1101 with the box for about $53 and just use the new mechanism.
Or replace with new Intermatic T101 timer for $45 at Smarthome.
Crossover wiring:
Tork L&1 to Intermatic 1
Tork 2 to Intermatic 2
Tork x to Intermatic A
Sep 03, 2012 | TORK Hardware & Accessories
I have a Tork 1101 timer and up until now has worked fine. Now it won't shut off. The mechanical on/off tabs are set correctly. It turns on and as the timing wheel comes around, the shut off tab...
If clock is rotating on time, next suspect is P47 trippers have worn down. Trippers are made of softer metal so they wear down instead wearing down the on-off lever, and that way the timer lasts longer.,Photo.Cells...Time.Controls,Replacement.Trippers
New replacement Tork 1101 120Volt timer can be purchased on-line at Amazon etc.
Home Depot sells the 120V GE 15306 indoor-outdoor version of Tork 1101 timer.
Replacement timer in Intermatic is T101
Jul 24, 2011 | Kitchen Ranges
I have a Tork 1101. Please advise how to set the OFF time.
Tork 1101 is 24-hour 120Volt mechanical dial timer
ON-OFF trippers are placed on outer edge of dial to set on-off times.
These tripper click on-off lever back and forth.
Trippers wear out since they are intentionally made of softer metal than on-off lever
Frontier lighting carries P47 tork 1101 replacement trippers
Make sure these trippers match yours before ordering
Dec 09, 2010 | TORK Hardware & Accessories
I have a w100 tork timer and i would like to know how to repair it and how to position the time pointer.
How to position time pointer
Rotate disk counterclockwise until current time lines up with silver pointer
Place trippers on outer edge of dial > trippers are reversible so one side of tripper in ON > flip tripper over and it is OFF.
Disk rotates with passing time, trippers click lever ON and OFF at set times
How to repair W100:
If dial is not rotating, then clock motor is bad >> W100 uses 120V clock > check markings on clock. Internet shows Tork T101M and T201M clock motors, but unclear if either clock matches W100 timer.
If dial rotates but trippers do not turn Load on-off then buy P-69 trippers
If manual override turns Loan on-off then electric circuit is working
If manual override does not operate Load, then check electric circuit or Load (light bulbs burned out)
If manual override is sluggish or stuck, and doesn't click crisp and clean, then timer is worn out or needs to be cleaned.
Product Manual:
Link above shows manuals
Manual for W100 does not show specific clock-motor model
To buy parts or another timer
P-69 trippers available on web
Tork T101M and T201M clock motors available on web but unclear if they match W100
Page above sell W-series time dial part #70159 for 72$.
Page does not include photo, so unclear if dial includes clock-motor, or if voltage is 120V
Tork accessories pdf shows part #70159 as dial for W, with no other information
Same seller shows new W100 sells for $148.
Replace Tork with Intermatic, buy T7401B
Website sells T7401B for $114
T7401B is 120V timer and has 120V clock motor
Manual for T7401B
Nov 16, 2010 | TORK Hardware & Accessories
I have a noisy TORK model1101 24hrtime switch there is a broken spring in there and it won't switch OFF is it repairable or do I scrap it and Hunt for a new one? If you cant give me and answer with...
Fixya answers questions.
NSI is responsible for Tork.
Electro-mechanical timers make audible click noise when timer turns on-off.
T1101 spring is the time-carryover for power outage.
Buy another Tork T1101 and swap out insides without changing box:
Take photo of wiring before making changeover.
Replace Tork with Intermatic T-101 120V timer
T101R for weathertight
Amazon for T101
Aplus sells T101R
For help wiring T101
Nov 13, 2010 | Hardware & Accessories
My Tork 1103 timer is used at my office building to set the lights outside for security. My maintence person sets them, then all of a sudden they are wacky and come on at the wrong time. I would like to...
This is probably very similar to your timer.
The Tork 1100 series is electro-mechanical timer.
Lift and rotate dial to set current time.
Line up current time with the word Time located to lower right of dial.
The trippers are black and silver.
I think the black is OFF and silver is ON
Clock motor rotates dial as time passes.
Trippers contact a lever.
Off tripper pushes lever one way.
On tripper pushes lever other way.
The manual override clicks back and forth as trippers move lever.
To check function of timer, click manual override
Common problems:
1) Clock motor is not rotating dial
2) Trippers get stuck on lever and can't move lever because timer is dirty or worn out, or clock motor is bad.
3) Trippers are worn down and won't trip the lever.
Replacement of these timers is simple
Check out the functions and problems and then answer this post and I will help more if needed
Oct 21, 2010 | TORK Hardware & Accessories
I have a TORK 1103.. I have read and re read all wiring problem is.. it now turns on.. but doesnt click off.. unless i manually do it myself.. Im pretty sure i have all the wires connected to...
Tork 1103 controls 2 loads
Your wiring is OK ... if the dial rotates and the tripper turns ON the load, then your wiring is correct
It sounds like you forgot to put the OFF trippers on dial?? Or the OFF trippers are worn out.
Dark trippers = OFF
Light trippers ON
Look at the trippers up close ... as they arrive at the manual override, they make contact with a mechanical lever ... the motor then pushes the dial forward and the trippers flip the manual override lever on-and-off.
Is the manual override broken? I doubt it.
Are the OFF trippers worn down?
Oct 06, 2010 | TORK Variable Cycling Timer 8601
Lost programming instructions, need help to reset or copy of programming manuel
Go to and you will see your model and then click on it for your wiring diagram
Oct 01, 2010 | TORK SS720A 7 Day In Wall Digital Timer
Dewalt DW056 18 Volt Cordless Impact Driver - 1/4" Drive Hex Shank (Battery Charger and Case Not Included) - Tool Only Logo
181 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
