TV will not power on
Mitsibishi Model CS-40FX1. TV will not come on with front panel switch or remote. Flashes and clicks when front panel program timer button is pressed. Tv was working fine until left off for two months.
    Scholar:
  • 155 Answers
On the main board of the tv there are capacitors and ICs .as you said you kept the tv off for two months ane now again connected and the tv did not start.as the high current passed through the circuit board of the tv and due to that any of the small electric part on the main board got blowned off and there is no power.check on the main board.it also happens if the moisture is collected on the main board of the tv in two months and when you started the tv now due to that moisture when the current passed in to the board and some thing got short on the mainboard.or due to dust particles collected on the main board.clean the main board.
thanks.
Posted on Nov 05, 2008
    President:
  • 624 Answers
It is most likely a power supply problem, you can check the fuses if you like, but you would need to take the back off for that.
  • Dave DeGain
    Dave DeGain Nov 05, 2008
    If you are good with electronics, and have good soldering skills you could try to fix this yourself. I advise you to take it to a service center for repair. These are not easy things to fix without the proper equipment and training.
    Sergeant:
    Novelist:
  • 196 Answers
Check out the fuse on the main board if that is blowned this could happen.
  • mmechanics Nov 05, 2008
    also check out the power supply wire of the tv which you connect to the electric outlet , if that becomes loose internally this could happen as no required current is given to the tv to power ON.
Tip
Mitsubishi parental lock removal/v-lock redo
Models:
Color Televisions
CS-20EX1, CS-20301, CS-26EX1, CS-26201, CS-26301, CS-2725R, CS-27EX1,
CS-27MX1, CS-27TX1, CS-27200, CS-27201, CS-27301, CK-27304, CK-27306,
CS-27401, CS-27403, CS-3135R, CK-3136R, CS-31AX1, CS-31FX1, CS-31MX1,
CK-31MX2, CS-31301, CK-31302, CS-3525R, CK-3526R, CK-3527R, CS-3535R,
CK-3536R, CS-35X7, CS-35AX1, CS-35FX1, CK-35FX2, CS-35MX1, CK-35MX2,
CK-35MX3, CS-35201, CS-35201A, CS-35203, CS-35205A, CS-35301, CS-35401,
CK-35402, CS-40FX1
Projection Televisions
VS-40VA2, VS-4517S, VS-45VA1, VS-45VA2, VS-4561, VS-4562, VS-5016R,
VS-5017S, VS-50VA1, VS-50VA2, VS-50VF1, VS-50VF2, VS-50VX2, VS-50VX3,
VS-5061, VS-5062, VS-6017R, VS-6026R, VS-60VA2, VS-60VF1, VS-60VF2,
VS-60VX2, VS-60VX3, VS-6061, VS-7017R
This system locks only the entire TV. The TV will display a screen that
will indicate "Parental Lock ... Now the lock is on" and request the
personal four digit code when the TV is powered on.
IMPORTANT> You must use the original remote control that came with the
TV to release the Parental Lock, you cannot use a remote
that came with a VCR, Audio System or from any other
manufacturer.
1. Depending on which remote came with your TV, press the button at
the top labeled TV,OR set the TV/VCR switch in the upper left
corner of the remote to the TV position. .
2. Press the button on the remote labeled POWER.
The TV will turn on and display an information
screen that indicates "Parental Lock ... Now the
lock is on" and ask for the four digit personal code.
3. Press the #9 and the QV buttons at the same time.
The TV will turn on.
4. Press the button labeled MENU.
The "TV Main Menu" will be displayed.
5. Press the ADJUST UP or DOWN button to move the arrow next to the
"Advanced Features" selection and then press ENTER.
The "Advanced Features" menu will appear and
indicate that the lock is ON.
6. Press the ADJUST button to move the arrow next to the "Parental
Lock" option, and then press ENTER.
The screen will change to indicate "Parental Lock
... Now the lock is on" and ask for the four digit
personal code.
7. Press the #9 and QV buttons at the same time.
The screen will return to the "Advanced Features"
menu and indicate that the lock is off.
8. Press the MENU button twice to return to normal viewing.
The original lock code has now been erased and the lock canceled.
on May 16, 2010 | Audio Players & Recorders
Need the code for a sanyo tv to use a philips universal remote
Hello
Universal remote code to be cheked with Philips CL034 model remote habset to Sanyo are;
0506 0311 0612 0002
0428 0802 0412 0619
Direct Code Entry
1. Press and hold the CODE SEARCH
button until the red indicator stays
on, then release the CODE SEARCH
button.
2. Press and release the desired Mode
button (TV, VCR, etc.). The red
indicator blinks, then stays lit.
3. Enter the 4 digit code from the code
tables. Note: after a valid code entry,
the red indicator turns off. For an
invalid code, the red indicator
flashes.
4. With your device on, press
CHANNEL UP. If the device
responds, no further programming is
required. Note: If some buttons do
not operate your device, try one of
the other codes for your brand.
NB: Switch OFF and switch ON your TV with its front panel power control switch each time before trying an other code.
OK.
Feb 16, 2011 | Philips Televison & Video
Need the remote code for this model tv
Hello
Three digit universal remote code for Panasonic are:-
003/ 054/ 055/ 062/ 070/ 148/ 149/ 170/ 171
Four digit universal remote code for Panasonic are:-
0171 0148 0054 0170 0062 0374 0381 0437 0950 0003 0070
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Note: Switch OFF and switch ON your TV with its front panel power control switch [Main power control] each time before proceeding for an other code.
OK.
Jan 20, 2011 | Panasonic PV-DM2799 27 in. TV/VCR/DVD...
Dish Network Remote Coltrol and durabrand model 1304D tv 13" need to program the remote please help
Hello
Three digit remote codes for Duraband are:-
042/ 053/ 046/ 206/ 805/ 906
Four digit remote codes for Duraband are:_
0189 0135 0157 0051 0189 0053 0227 0456 0042
NB: Switch OFF and switch ON your tv, with its front panel power switch, [NOT BY REMOTE CONTROL HANDSET]; each time before trying an other code.
Direct Code Entry
ok.
Dec 25, 2010 | Durabrand DWT1304 13" TV
I need to program my remote, it is a ge universal and my mitsubishi is model cs-40505
Hello
Three digit universal remote codes for Mitsubihsi are:-
004/ 005/ 009/ 022/ 046/ 081/ 089/ 132/ 133/ 180
Four digit universal remote code for Mitsubishi are:-
0005 0151 0051 0004 0009 0254 0022 0141 0180
Switch OFF and ON your TV with its front panel power switch, [NOT BY THE REMOTE HANSET] before trying each code
Proceedings
Direct Code Entry
OK.
Dec 19, 2010 | Mitsubishi CS-40505 TV
Mtisubishi TV (CRT), Model CS-2610R
that is because you do not have the correct input connected or the set needs to have a channel program redone
May 16, 2010 | Televison & Video
Mitsubishi vs5003r troubleshoot
I found this in another website... i hope this can help you. I'll try too...
Found this on the web, hope it helps.
Thank you for contacting Mitsubishi Digital Electronics America, Inc. We
are pleased to be able to assist our customers via our website. Here is the
information that you have requested:
TV Lock #8
Models:
Color Televisions
CK-35402, CS-40FX1
manufacturer.
personal code.
Oct 26, 2008 | Televison & Video
Unlock Menu
I need a password to unlock my Mitsubishi TV Model # CS40707 Serial # 503994
Jan 02, 2008 | Mitsubishi CS-35707 35" TV
Mitsubishi CS-40FX1 won't power back on
Yes Sir, you need to read threads here or go to ctechnicians.com and it will tell you how to get set to work.
Dec 18, 2007 | Mitsubishi WS-55807 TV
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
Electro Med Services...
