Question about Kenmore 659 Electric Dryer
Therostat kenmore dryer
Two red one with whit line through it supect thats the ground wire to dark small purple wires need to put this back on right so it will dry i need a diagram
  • Kelly  Smith
    Kelly Smith May 11, 2010
    could you please tell me more about your problem? did you take the wires off of the heating element and the fuse looks like a skinny white hot dog with 2 metal tabs?
  • flyingtarzan May 11, 2010
    is this on the element or the vent
  • Kenmore Master
  • 8,220 Answers
It is kinda hard to mess up because the heating element terminals are larger than the limit terminals. The 2 purple wires go to the fuse.
They have smaller terminals.
Posted on Dec 22, 2008
What is the color codes to a pioneer dxt-2266ub? putting it into a 1997 firebird.
PIONEER STEREO DXT-2266UB
----POWER---
Yellow = Radio Constant 12V Batt +
Red = Radio Switched 12V Acc +
Black = Radio Ground Neg -
Blue/wht = Remote Amp turn on or Pwr Ant
----SPEAKERS----
White = Left Front Speaker Wire (+)
White/blk = Left Front Speaker Wire (-)
Grey = Right Front Speaker Wire (+)
Grey/blk = Right Front Speaker Wire (-)
Green = Left Rear Speaker Wire (+)
Green/blk = Left Rear Speaker Wire (-)
Purple = Right Rear Speaker Wire (+)
Purple/blk = Right Rear Speaker Wire (-)
RCA = Output to Amp
Owners Manual = http://www.pioneerelectronics.com/StaticFiles/Manuals/Car/DXT-2266UB_OwnersManual0607.pdf
1997 PONTIAC FIREBIRD WIRE COLORS
Radio Constant 12V+ Wire: Orange
Radio Switched 12V+ Wire: Yellow
Radio Ground Wire: Black
Radio Illumination Wire: Gray
Radio Dimmer Wire: Brown
Radio Power Antenna Trigger Wire: Pink
Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 6 1/2′ Speakers
Front Speakers Location: Doors
Left Front Speaker Wire (+): Tan
Left Front Speaker Wire (-): Gray
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Dark Green
Rear Speakers Size: 6 1/2′ Speakers
Rear Speakers Location: Side Panels
Left Rear Speaker Wire (+): Brown
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Dark Blue
Right Rear Speaker Wire (-): Light Blue
Hope this info helps
please let me know if you need any further info
May 20, 2011 | Pioneer Car Audio & Video
Dryer has 3 prongs wall has 4. new cord has 4 color coded connections. old one does not. how do I know where to put the 4 switches
3 wires -- Outside two wires (Line 1 and Line 2) Center (Nutral).
4 wires-- Green (ground) Red (Line 1) White (Nutral) Black (Line 2).
You have a terminal block on the back of the dryer that has only space for three wires. The Red and Black go on the out side two posts or screws (does not matter which is on the right or left). The White wire goes in the center. The forth and final wire is the Green which should go under a ground screw located near the terminal block. This screw is usually indicated by the ground symbol which is three horizontal lines that decrease in size as the go down. If there is a copper "bridge" from the center of the terminal block to the ground screw remove and discard.
Cheers.
May 17, 2011 | Frigidaire GLER331A Electric Dryer
Need Wireing diagram to hook up a Wire Harness to a Kenwood BT645U to a 2000 Jeep Grand Cherokee
2000 Jeep Grand Cherokee Stereo Wiring Constant 12V+ Red/White Switched 12V+ White/Red Ground Black Illumination n/a Dimmer Orange Antenna Right Front Front Speakers 6" x 9" Doors Left Front (+) Light Green/Red Left Front (-) Light Green/Green Right Front (+) Light Blue/Red Right Front (-) Light Blue/Black Rear Speakers 6 1/2" Rear Door Left Rear (+) Dark Green/White Left Rear (-) White/Dark Green Right Rear (+) White/Purple Right Rear (-) Tan/Dark Green
Kenwood Wires:
Red: Switched 12volt
Yellow: Constant 12volt
Black: Chassis Ground
Blue: Not used
Light Blue/Yellow: Steering wheel control
Brown: Mute Control
Blue White: Power Antennae (or Amplifier remote turn on)
White - White/black: +/- left front
Gray - Gray/black: +/- right front
Green - Green/Black: Left rear
Purple - Purple/black: right rear
Dec 21, 2010 | Car Audio & Video
Im installing a JVC KD - A315 radio in a 2003 alero, when i took out old radio all the wires were cut and turned into speaker wire running all over the place the factory amp is in the back i went ahead...
There may be extra wires you don't need. The basic set of wires on the radio is 4 pairs of colored wires--one black-striped and one plain for each speaker. Yellow is usually accessory power, red is hot, and black is ground. Some additional wires may be one for a power antenna, one for an external amplifyer, and one for facelight (in case it will run on dimmer)
The car should have the following corresponding wires:
Radio 12v--- orange
Radio Ground--- black
Radio Ignition--- yellow
Radio Illumination--- brown
Dimmer--- gray
Power Antenna--- pink (if you have one)
LF Speaker +/- tan - grey
RF Speaker +/- lt green - dk green
LR Speaker +/- brown - yellow
RR Speaker +/- dk. blue- lt. blue
The car or radio could have additional connectors, such as for a subwoofer, CD changer, etc.
Aug 28, 2010 | 2003 Oldsmobile Alero
Wiring in a sony CDX-L600X in a 95' F150
red is B+
black is ground
dark blue with white stripe is remote for amp
blue is power antenna
yellow is ignition
white and white with black stripe is front left
gray and gray with black stripe is front right
green and green with black stripe is back left
purple and purple with black stripe is back right
this is for the deck
Mar 21, 2010 | Sony CDX-L600X CD Player
Need wiring diagram for 92 dodge caravan tryin to install cd player
Here it is
Car Radio Battery Constant 12v+ Wire: Red/Black
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Black/Yellow
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: Yellow
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 5 1/4′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Dark Green/Red
Right Front Speaker Positive Wire (+): Purple
Right Front Speaker Negative Wire (-): Purple/Yellow
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Tail Gate
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Yellow
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Feb 14, 2010 | Car Audio & Video
1996 eagle vision radio wiring
1996 Eagle Vision Car Radio Wire Diagram
Car Radio Battery Constant 12v+ Wire: Black/Yellow
Car Radio Ground Wire: Black/Light Blue
Car Radio Illumination Wire: Orange
Car Stereo Dimmer Wire: Pink
Car Stereo Antenna Trigger Wire: Orange/Red
Car Audio Front Speakers Size: 3 1/2′
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Feb 23, 2009 | 1996 Eagle Talon
I need color codes
Constant 12V+ Black/Yellow
Switched 12V+ Red/White
Ground Black/Light Blue
Illumination Orange
Dimmer Pink
Antenna Trigger Orange/Red
Antenna Right Rear
Front Speakers 4" Doors
Left Front (+) Dark Green
Left Front (-) Brown/Red
Right Front (+) Purple
Right Front (-) Dark Blue/Red
Rear Speakers 6" x 9" Rear Deck
Left Rear (+) Brown/Yellow
Left Rear (-) Brown/Light Blue
Right Rear (+) Dark Blue/White
Right Rear (-) Dark Blue/Orange
Feb 19, 2009 | 1996 Dodge Intrepid
Kenmore dryer elite
IF THE WIRES ARE RED, BLACK, WHITE, AND GREEN,
THE WHITE WIRE GOES TO THE CENTER TERMINAL.
THE GREEN WIRE ATTACHES TO A GROUND SCREW ON THE BACK OF THE DRYER. UNHOOK THE WIRE GOING FROM THE CENTER TERMINAL TO THE GROUND SCREW TO ISOLATE THE ELECTRICAL NEUTRAL FROM EARTH GROUND ( THE WHITE WIRE FROM THE GREEN ONE)
THE RED AND BLACK WIRES GO ON THE LEFT AND RIGHT OUTER TERMINALS ON THE TERMINAL BLOCK. THOSE TWO ARE INTERCHANGABLE.
Apr 10, 2008 | Kenmore 63942 Dryer
Need help with wiring a pioneer deh-5
You do not have the entire Pioneer model number listed, so I cannot provide you with the wiring info for it.
Bu here is the wiring info for your jeep.
Constant 12V+ Pink/Yellow  Switched 12V+ Red/White  Ground Black  Illumination Orange/Brown  Dimmer Black/Light Blue  Antenna Right Front  Front Speakers 6 1/2" Doors Left Front (+) Dark Green  Left Front (-) Brown/Red  Right Front (+) Purple  Right Front (-) Dark Blue/Red  Rear Speakers 5 1/4" Roof Mount Left Rear (+) Brown/Yellow  Left Rear (-) Brown/Light Blue  Right Rear (+) Dark Blue/White  Right Rear (-) Dark Blue/Orange **from the12volt.com
Best of Luck.
Oct 31, 2007 | Alpine CDM-7874 CD Player
Kenmore 659 Electric Dryer Logo
50 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
