i have acer laptop acer aspire 1350. i cleared the bios password and could not reset the bios because i cant enter in bios because it is asking for password. what should i do to reset the bios and to enter in bios. any command to enter in bios. Only it is displaying f2 option to enter in bios but when i press f2 or leave it , it just shows system disabled after 3 trials. i need a command to enter in bios. I will be grateful for this help.
-   i have the optiplex gx280 and it shows the set up option but will go straight to password required-   casybaby
Jan 15, 2009
-   I need to update my motherboard bios on a Optiplex GX150 from version a01 to A11 but the password is keeping me from doing so, HELP-   mdstrable
Nov 20, 2008
-   my system BIOS password will be blocked how to open the BIOS
-   Guest
Jan 08, 2008
-   i cannot enter the cmos bios setup because i forgot my password-   Guest
When you say you cleared the bios password, did you actually remove the cmos battery for about 15 minutes or did you just delete the old password, as acer normally protect the password and sections of the bios, removing the battery or shorting it is normally the only way.
As another option you could try resetting the jumper. Some boards save the password regardless unless the reset the BIOS by using the resetting jumper. Refer to the motherboard's manual for further information on how to do this.
hello, first of all I need know where the serial number for an iwill motherboard is usually located....
(More)
hello, first of all I need know where the serial number for an iwill motherboard is usually located. and my main problem is when i plug the pc in i get a power light but nothing happens when i press the power button
this acer Aspire 3100 does not recognize ther internal or external keyboard and mouse each time that...
(More)
this acer Aspire 3100 does not recognize ther internal or external keyboard and mouse each time that turns on go directly to start windows and i can not do nothing. I already try several external usb mouse and keyboard and nothing happend what could be the problem ? thank you
I have an ACER laptop, when I press the ON switch the machine just goes from ON to OFF continually. ...
(More)
I have an ACER laptop, when I press the ON switch the machine just goes from ON to OFF continually. This occurs whether driven by mains or battery power. The only way to stop the laptop is to 'pull the plug' and disconnect the battery! Any ideas? (someone mentioned it could be the motherboard?). Many thanksDavy
