Epsom stylus c40 sx head cleaning sponge is leaking black ink needs new sponge
Washed sponge and re-used it
Many thanks for your help
Posted on Nov 06, 2008
  • 66 Answers
you can wash that sponge and you can used it again instantly..
Replaced black ink but will not print in black epsom CX5500
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Mar 29, 2013 | Epson Stylus CX5000 InkJet Photo Printer
How can I remove the print head for cleaning on a epson sx 405? thanks
Epson Status Monitor has a facility for cleaning print heads:
If your prints are still streaking, try changing cartridges.
generally the print head cannot be removed on this type of printer, but if you plug the unit out and unscrew the outer casing, you will probably be able to get at the cleaning mechanism - usually a series of sponges used to wipe the printheads. the sponges may be full of ink - wear gloves! remove the sponges and clean them.
hope this helps
Jul 21, 2011 | Office Equipment & Supplies
Brother MFC-290C not printing black
The nozzle may be blocked. So take out the colour cartridge and place its nozzle in a bit of water for about 10 mins. Bring it out and dab the nozzle with folded paper. If the tissue is blotted with the three colour it means you have unblocked the nozzle. Try now to print after returning the colour cartridge. You may need to repeat to get good results.
Thank you!!
Jun 25, 2010 | Brother MFC 420CN All-In-One InkJet...
I have got epson stylus r230. I have a problem with black ink.when i printed in paper we can see there overflow of black ink. plz help me
I think you should replace the sponge that are right side of the printer head parking station.or wash the sponge clearly. you will be relive from your problem if uou follow the above tecnique. thanks.
Jan 17, 2010 | Epson STYLUS R230 InkJet Photo Printer
Epson Stylus C40 Plus printer cartridge replacement instructions
It sounds more like the printhead is blocked as if it either hasnt been used much or if the cartridges where taken out and the air has got to the nozzles, this would cause it to dry out and prevent the ink from flowing from the cartridge itself.
The C40 is pretty dated, so would probably cost more to repair than its worth. The S20 is about the closest match and is about £35 so might be worth looking at replacing.
Oct 24, 2009 | Office Equipment & Supplies
I have tried everything from head cleaning, nozzle checks, print head alignments to changing the printing setups to everything and anything I can think to help but no matter what I do, my pages keep...
I had the same problem. What you need to do is manually clean it. Take the ink cartridges out and clean the bottom of the ink loading bay with a Q-tip. Than, inside the printer, there is a black sponge that lines the area below the printing heads, take it out (gently). Clean it with water over a sink by squeezing it, but be gentle. A lot of ink should come out of the sponge. Once it is thoroughly cleaned, let it dry (I used a hairdryer than let it air dry for a little bit). Reinsert the sponge (make sure it is dry!) and ink cartridges. Do one head cleaning on the computer and now it should print like new.
Jul 16, 2009 | Epson Stylus CX3810 All-In-One InkJet...
Epson Stylus C88 won't print black ink
You have tried almost all the steps. You have to consult Epson Service Support. Don't try more the head can damage.
Mar 06, 2009 | Epson Stylus C88 InkJet Photo Printer
Deep Cleaning an Epsom Stylus DX5050
check the black ink level may be its already used up. It needs to be replaced. Ink is consumed during cleaning. Try to replace with a new one. all in one printers does nit print if 1 ink is lacking.
Nov 28, 2008 | Epson Stylus 830U InkJet Photo Printer
Epson stylus cx3600
If you took out the sponge pad that runs left to right under the head and didn't put it back right the chances are the print head is catching on it and passing ink back and forth. Check the pas is sat correctly and clean under the print head with a light solvent cleaner like windowlene/windex liquid
Jul 25, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Epsom stylus all in one dx7450
press 'Control' + 'P' on a page (as tho you want to print)
click 'Maintenance'
there you'll find various options to clean heads etc, that should do it. tho it does deplete your inks considerably each attempt. & you'll probably find it needs more than one clean.Good luck!
Jun 08, 2008 | Epson Stylus Multifunction Inkjet Printer/...
134 people viewed this question
