A couple of weeks ago I started having a problem with my monitor F1703. I would move the mouse and the screen would go blank. I rebooted several times and it finally stopped. Last night the screen will not stay on - it keep going black and if I turn the monitor off and then back on I get my screen - dark for about 3 second and then goes black. Any suggestions as to what the problem is?
My HP f1703 is almost 3 years old and started having this same problem. My fix got the display to stay on. Don't know how long this fix will work. I set the monitor brightness to 51 and contrast to 41. You may have to adjust to your levels to your appropriate enviroment. Levels may determine how long the monitor stay operational. Do NOT set your monitor brightness to factory levels it will just start to recreate the problem again. Solution: The monitor should be on with the blue button lighted. If the screen is acting up (you turn it on and the display lights up and then it turns off within 2 to 5 seconds) Try decreasing the brightness level down as much as possible. Wait 15 to 30 seconds and see if the display comes back to life. If not, turn the monitor off and on again and try the procedure again, if necessary. Cause: I believe the monitor brightness level, set at 100 by the factory setting, is over driving the display and causing the protection circuit to cut off the flouresent lamps that light the display. HP had an issue with this display, and had a notice to replace them if the problem occurred during the warranty period. They extended the warranty period from Jun 04 to Feb 06. Check with HP Technical Support to determine if your monitor is cover.
Everytime i restart my computer, it falls into sleep mode. It is not getting a signal from the video card. I tried multiple cold boots. It eventually just kicks back on...The monitor works on other computers. The video card is seated properly. All the drivers are updated. The cables work properly. I am using the HP Pavilion f1903. Any help would be appreciated.
Thanks,
Eric
Sounds like cold soider joints on your video board. If you take apart the lcd screen and get to the video board, theres 4 capasitors with cooper coils around it. you can add soider to it. theres 2 pins for each. I fixed 15 or more for that same model. Its a known problem with that model. Hope it wworks for ya
SOURCE: Monitor going black
HP's are known for bad capacitors in the power supply.
Replacing them is simple if you know how..not so simple if you don't.
Try your local TV repair centre. It should not cost alot to have the capacitors replaced.
Hope it helps =)
screen comes on a few seconds then goes black
i have hp pavilion f1903... i don't know wat gone wrong i downloaded a movie THE NUMBER 23.the movie started after 10 minutes the screen gone black... i thought that might had happen due to screensaver and i clicked the mouse.. but nothing happened...after that it's blank...the power button lits to blue..when i turn off c.p.u..the button light turns to yellow..my computer works with other monitor..i checked........cause off this problem i am unable access net......can anyone suggest me a solution to this problem....i am even willing to open the panel and get it fixed...... if anything that i can do on it's board to fix it....let me know...that would be a great help...........
i have checked the power cable and the other connection cable.... nothings wrong with cable......
my f1903 monitor goes black after a couple seconds. Any ideas?
I need help with my monitor. The blue light stays on (no flashing) but the monitor goes black after just a couple of seconds. I can press the blue button twice and will then get a couple of seconds to move my mouse around to locate what I need but then the monitor goes off again. Last night I spent an entire hour pressing the blue button on and off just to be able to get to locate one file and then to print it! Everything is fine except for the monitor. The computer is working and so is the mouse and the printer. Could it be that something in the control panel just needs to be reset? Please help! Thank you.
