Question about Panasonic NN-T990SA Microwave Oven
Turns off after 3 sec
After 3 sec, the microwave shuts off, when in high power. When in a lower power level, it will stay on a little longer..5-6 sec
    Problem Solver:
  • 4 Answers
Usually this indicates failure of the magnetron and/or the inverter. Neither is easy to test without specialised HV equipment. Often the cause is operating the oven without anything in it. If this has happened, it will generally be failure of the magnetron.
Replacement of the magnetron is relatively easy (about 15 minutes) and the inverter a little longer but if you do not have the knowledge/skills please do not do it - there are very dangerous (deadly) voltages associated with magnetrons even after they have been switched off.
Cost of magnetrons ranges upwards from USD25 to USD100 (from Panasonic spare parts) and inverters range upwards from USD125. The cost of parts is often the reason microwave ovens are not repaired.
Doug
Posted on Nov 08, 2008
I have a Kenmore Microwave 405.72123310. The microwave turns on and the turntable turns, but it does not heat. Is there a fuse I can check for this?
You really don't want to take them apart do to radiation. Take the screws out in back plate. Carefully and remove and look in to see if you see black burnt spots. If you see any then chances are the main board shorted out on microwave.DO NOT STICK ANY TOOL IN MICROWAVE IN BACK. Some do have a round fuse in back.If your does take it out with some heavy plastic. Make sure before you take back off unplug from wall and the push start 3 times with 5 second apart. This will allow all electric in the power reducer to discharge. then you can work on it. On sides of use it will tell you what amps it is. Good Luck
Aug 03, 2016 | Kenmore Microwave Ovens
How do i adjust power level
There are no heat levels on a microwave oven, only power levels. I am not aware of any method of checking the power level except to boil water. Boil water at each level and time how long it takes to boil. The lower the power, the longer it should take. If there are no differences in the time, the oven is not functioning as expexted.
Sep 13, 2014 | Haier Microwave Ovens
Panasonic the genius prestige problem:::: it will run for about 10 secs then shut off, turn it on again real quick it will run another 10 secs...everything else works on it, the broiler,bake, but when the...
Before spend $$ on replacement boards, make sure anything attached to it is powered off. Unplug TV for 5mn to 15min. Plug back in and it should power on. If not leave unplugged overnight before spending on a replacement board. We have to do this 2-3 times per year when someone forgets to turn off auxiliary components (receiver, DVD, cable box, etc) first. It has always come back on.
Mar 16, 2013 | Panasonic NN-SD797S Microwave Oven
Fuse keeps blowing in hotpoint microwave
The magnetron is the other issue, high voltage diode will sometimes crack causing a high level short, the capacitor developes a dead short across the 2 points, the power transformer almost never fails, "very rare"
Apr 08, 2012 | Hotpoint RVM1635 Microwave Oven
Burns my popcorn constantly. is there a different setting i can put it on?
HELLO.
Solution to your microwave problem is given as below.
* 1 Set your Daewoo microwave on a countertop near an electrical outlet and plug it in. Open the door and place the circular roller guide in the center of the oven cavity, then place the glass cooking tray over it.
* 2 Set your food on a microwave-safe dish and then put the dish on the cooking tray and close the door. Make sure that it latches properly.
* 3 Turn the upper knob to select a power level. Power levels include "Defrost," "Med-High," or "High." If your Daewoo has a touch pad, touch the "Microwave" button once to set the highest power level. Touch it consecutive times to lower the power level.
* 4 Turn the lower knob to set the cooking time. For cooking times less than two minutes, turn the knob up past the two-minute mark, then back to the correct time. For touch pad models, enter in the cooking time with the numerical keys and then press "Start."
* 5 Open the door at any time to stop the cooking and check the temperature of your food. Shut the door to automatically continue cooking, or turn the timer knob to the right to add more time. For touch pads, press the "Stop/Clear" button, then key in a new cooking time and press "Start."
* 6 Open the door when the timer reaches the "Off" position and take out your food.
Thanks.
Sep 24, 2011 | Daewoo KOC-925T Microwave Oven
GE Spacemaker 1800 XL Power trip
I'm guessing that's JVM1870SDF04. While there's a chance it may be the magnetron, but I do suspect the high voltage transformer.
The magnetron would still be covered under warranty, but you would have to pay for the home visit ($75 avg) and the labor to replace the part ($90 avg).
The transformer is just over $100 here and about $165 direct from GE.
You can save about $75 in labor by taking it to the shop yourself and for their bench fee, you can get an estimate and find out if it;s the mag or the transformer.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
GE Customer Service is here and they can point you to your nearest GE-authorized servicer.
Oct 21, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Shuts off...
It sounds like you may have a loose fuse holder or an intermittent part such as one of the thermostats, such as the one mounted on the magnetron.
One thing to try is to cook on the lowest power setting or defrost to see if it runs longer or fails more quickly.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Aug 06, 2008 | KitchenAid KHHS179LSS Convection /...
I have lost instruction book for Sharp Compact R250A microwave oven-how do I reset the clock?
May be a little late, but... 1. Press Power Level button for approx 5 seconds - you get the 12 hour clock 2. Press again for 24 hour clock 3. Set hours using the 10 min and 1 min buttons 4. Press Power level button 5. Set minutes using the 10 min and 1 min buttons 6. Press Power level button And you are done
Gert
Aug 05, 2008 | Sharp Microwave Ovens
Changing Power level on Westinghouse microwave
If it won't cook at the lower power level then it probably has a stuck relay on the control panel circuit board.
If it were cooking at a low power level, it would be on full power for several seconds, then when the relay opens to turn off cooking, the light gets a bit brighter, and the sound is a bit less.
Then after a few seconds you would hear the relay click on, and a little more buzzing when the magnetron energizes.
Please write back with your brand and model number if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 03, 2007 | Microwave Ovens
Panasonic NN-T990SA Microwave Oven Logo
372 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
