Question about Philips 6P5430W 54" Rear Projection Television
Phillips tv CRT
When we turn it on, no picture, on light flashes then goes off
We gave the tv to Goodwill.
Posted on Nov 06, 2008
Toshiba theaterwide hd
replace the lamp on your TV, but only replace it with PHILLIPS brand. Anything other than that, will not last. We just replaced ours with Phillips and the picture is much brighter. It really shows the HD quality of the tv.
Mar 24, 2014 | Televison & Video
Phillips tv picture priblem
does your tv's lcd tv? damaged lcd panel .. (broken screen
May 12, 2013 | Televison & Video
We have an older Phillips Magnavox tv. The tv will turn on & we will see the picture for a short time but then the screen turns grey. We still have sound, just no picture. Also, the green power light...
Hello, the grey screen could be due to a missing 220Volt source which feeds the color (RBG cathodes)inside the CRT(picture tube). When this happens the beam current inside the CRT goes high in a matter of second, thus triggering the beam current protection circuit(blinking green light)shutting down the TV. Repairing the secondary voltage source is necessary to get the TV working normal, a good technician should be able to repair it for between 80 to 100 dollars parts included, except a picture tube, which could be also the cause of the problem(K-A shorts).
Nov 06, 2010 | Philips Magnavox 27MS343S 27" TV
A red light comes on where you turn on my Phillips hdtv, and then the picture goes out. The sound stays on. You can cut tv off and the picure will come back. But after a few minutes the red light comes...
Ur CRT video board long neck connected holes to long neck,must resolders,cold solder.
Or this a LCD TV?Must change ur LCD inverter board it dead,replaced it to get picture back.
Nov 26, 2009 | Televison & Video
When I turn the power on the the green light flashes, the set attempts to turn on,goes off,green light goes on attempts to turn on and goes off. This is a 36 inch picture in picture, about the first year...
You most likely have a horizontal and/or a high voltage issue. These sets are famous for this problem. If the picture was still good before it went out, it is probably worth getting checked out. Thanks
Oct 28, 2009 | Proscan PS36700 36" TV
Watching tv when the picture went black and now the green on light flashes for 30 times and turns off
A green flashing light for this model of TV indicates that the lamp cover is open on the TV.
  1. Unplug the power cable to the TV.
  2. Remove the 2 retaining screws on the lamp cover with a Phillips type screwdriver.
  3. Remove the lamp door completely from the TV.
  4. Remove the two retaining screws on the lamp case.
  5. Lift up the fixed wire handle of the lamp.
  6. Pull out the handle slowly and remove the lamp case.
  7. Insert the new lamp gently into the correct position. Make sure it is inserted correctly.
  8. Using a manual Phillips screwdriver (Do Not use an electric screwdiver), tighten the screws you removed in
    step 3.
  9. Replace the lamp cover and tighten the cover screws.
  10. Plug in the power cord and turn on the TV. After the initial warmup period (which may take up to several
    seconds for full picture brightness), the TV should operate normally.
If any of the following conditions exist, turn off the TV, unplug the power cord, and repeat steps 1–9 to ensure that the lamp unit and lamp unit
door are installed correctly:
  • The lamp indicator flashes green.
  • No picture
  • Dark picture
  • TV will not turn on
If, after repeating steps 1–10, the problem still exists, call Customer Service at 1-800-631-3811.
Source
Aug 31, 2009 | Toshiba 44NHM84 44" TV
Phillips 32" HDTV power light blinks green but wont turn on
the problem in the main power supply it depends of the kind of faillure but normaly to repair it not very expensive
good luck
Aug 23, 2009 | RCA F32650 32" TV
MY problem with Sony KP-53S35 53 in. Rear Projection Television. When the TV powers on, the red light blinks until the picture comes on, then the red light blinks go off. I had to wait more than 5 minutes...
the number of flashes of the red indicator lamp points to the possible cause of the delay of the raster or picture, but usually it's an indicator of an emission unbalance between crt(picture tube) guns. the picture will take longer to show up as the emission on either of the picture tubes goes down.
Jul 27, 2009 | Sony KP-53S35 53" Rear Projection...
Sony Trinitron TV. No picture; red standby/timer light flashes.
My Sony trinitron has the stero lite on steady and standby lite flashes four times then pauses and repeats. Can you tell me the circuit/condition causing the set to not turn on.
Jul 15, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
TV SREEN GOES BLANK, BUT AUDIO CONTINUES NORMAL,
Try unplugging for 36 hours. I had the same problem but with no sound and picture
Mar 03, 2009 | Sony KP-53HS10 TV
Televison & Video Logo
297 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
