Question about RCA Thomson Digital Cable Modem (DCM305R)
Speedtouch Wireless Router
I can connect to the internet but not by a wireless connection.
Signal Strength = Excellent but by status is limited or no connectivity.
my other laptop can connect to the wireless network but this laptop can't?
can you help?
i have reset the ip address but this doesnt work.
  • 113 Answers
Delete the wireless profile and recreate with correct wireless key. try to diable the wireless adapter and enable it again
Posted on Nov 05, 2008
Computers have limited connection to linksys wrt54g although signal is full strength
Limited connectivity
If you get a 'Limited connectivity" on you wireless connection on your laptop, it means that the wireless card on your laptop probably did not get an IP address from the wireless router.
To fix this problem, right click on the wireless icon on the Task bar and then click Repair.
This will force the wireless router to issue a IP address to the wireless card on the laptop.
Also try resetting the wireless router by turning off the power to the wireless router for a few minutes and the boot up your computers.
Oct 28, 2012 | Linksys Wireless-G WRT54G Router
Connected wireless to router, excellent signal, but unable to connect to internet.
connected to wireless router with excellent signal may not means you are connected to internet. make sure your modem provided by internet service provider has signal! connect your computer to modem directly bypassing router. If you are online that means your internet is functional. Then connect modem to your Linksys router and use your wireless to log on to internet.
Your router wireless signal active and excellent means you are connected to router not necessarily the internet. The modem supplied by your internet service provider with active internet should be connected to you router on WAN port!
good luck!!
Oct 07, 2011 | Linksys Wireless-G WRT54G Router
I can't connect the wireless network even it shows that the wireless connection status shows as follows: connection status: connected network duration: going on signal strength: excellent However, the...
Your router's wireless encryption setting (WEP) has been changed.
Theencryption key secures your data from unauthorized access. The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, configure the router'swireless settings ie SSID, plus the WPAor WPA2 encryption key and then configure wireless cards in the laptops and orcomputers with these router's wireless settings. Then the laptops and desktopcomputers can communicate with your wireless router.
May 02, 2011 | Computers & Internet
Installed Trendnet wireless adapter. Connection shows excellent but can't browse internet
The "excellent" is the signal-strength between your wireless adapter
and your wireless router.
You still need to select the SSID ("network name") that you configured into the router, and enter the password for your network, before you can connect to the Internet.
Compare it to having a brand-new mobile telephone. Until you dial a friend's number, and the friend answers, all you have is an "excellent" telephone.
Feb 21, 2011 | Trendware TEW-423PI (ASKU44090) Wireless...
Connects and drops when using wpa will not stay connected has great signal
Please check for the wireless signal strength of the wireless router.
Try to access the internet in an area where the signal is excellent.
Oct 30, 2010 | OTC ACR201-G (00CSPP000122) 802.11b/g...
Wireless connection connectivity
If you connect the computer to the router , does it works? If the wired is on line that means the wired connection is OK.
Open the set up page of the router check the
wireless settings of the router.
I think your network is secured and you are not
typing the correct network key.
just open the router set up page and check the wireless settings.
Click Here for step by step solution
Feb 28, 2010 | B&G Computers & Internet
Wireless network problem with Dell Inspiron 600m.
Your wireless router is acting as the mechanism to hand out IP addresses using DHCP.
Sometimes glitches occur and I would recommend unplugging your wireless router from its power surce, letting it sit for a minute or two and replug it back in.
It will come back to life , reset itself and start handing out IP addresses to all computers and peripherals that normally connect to the router.
Nov 27, 2009 | Dell Inspiron 600M Notebook
Laptop shows good connection, but cannot connect.
May I recommend you download Network Magic (a Cisco Product - same as Linksys) and NM run its routine on your connection. Google it.
Free top download and use for eval period. read the deal at the web site
I use the paid pro version and I love it.
Oct 22, 2009 | Linksys Wireless-G WRT54G Router
Samsung NC10 will not connect to any network
If WLAN and Wireless cards are enabled, then you may have to unplug your router for 10 seconds to reset it. They tend to build up a static charge. Unplug wireless router for 10 seconds, plug back in and you should be fine in a minute or two with full connectivity
Aug 20, 2009 | Samsung NC10-14GW Notebook
Limited or no connectvity
you can use the WinSock XP Fix tool to reset TCP/IP protocol to original state:
Jan 01, 2009 | Linksys Wireless-G WRT54G Router
RCA Thomson Digital Cable Modem (DCM305R) Logo
407 people viewed this question
Top RCA Computers & Internet Experts
Julie Endres
David Payne
David Payne
Are you a RCA Computer and Internet Expert? Answer questions, earn points and help others
