Question about Bosch Exxcel KSR34423 Refrigerator
It just starts and stops after few seconds ...
Ok, we left home for a month without unfreezing it, so after we come back, we turned it off ... and from then, it just doesnot work ... the compressor starts to work and stops in a few seconds .... what can be checked ?
  • Yaroslav Tenzer Oct 11, 2006
    One interesting thing, I left it working today for a half
    an hour, so the upper part "freezer" got cold but the bottom
    part ... is not getting any colder .... and it still works 5 seconds and rests for 10 seconds ...
  • David Sudikoff
    David Sudikoff Feb 05, 2013
    Had same problem: stopped after 5 seconds; solved by cleaning out the compressor coils at bottom of refrigerator
  • 175 Answers
It sounds like either the compressor is bad, or the overload and relay assembly mounted to the compressor is bad. The easiest way to determine which is to put an amp meter on the power wire to the compressor assembly. It should only read a few amps while running. If it reads excessive amperage, you have a bad compressor. If you do not have an amp meter, then you could just go get a start relay and overload from a parts store and try changing those parts, as they are much cheaper and eaiser than changing the compressor....just unplug it before messinfg around inside the overload cover on the side of the compressor! Good Luck!
Posted on Oct 11, 2006
Same problem; cleaning coils at btm of fridge solved the issue -- and boy, they were filthy
Posted on Feb 05, 2013
N900 freezing and turning off
My advice is to download the latest firmware from Nokia website (which is version PR1.2) and install it through the USB cable provided to you. If this is something you can not personally do, please go to an authorised nokia service point and have this done for you. They should NOT charge you but ask about that before. For the battery removal issue, there is a way to bypass this process. Please press the power on/off switch for about 10 seconds. normally the device will unfreeze and go off without having to remove the battery. wait a few seconds and then you should be able to switch it on again.
thank you :-)
Jun 30, 2010 | Nokia N900 Smartphone
Nightrod stops firing a few seconds after starting
Probably fuel system has trash in it, The oil light comes on after engine dies would be right as the ignition is still on and no oil pressure.Fuel stabilizer may have caused trash to break free and stop up the system.Also vacuume to fuel shutoff could be off or stopped up too.
Apr 22, 2010 | 2008 Harley Davidson VRSCDX Night Rod...
Fail to start
I think I would change the petrol in the tank as it may have become a bit stale. Also I would replace the battery.Make certain the replacement battery in fully charged before you try again.
Mar 17, 2010 | 2003 Triumph TT 600
P/s very hard to turn to right from stop..ok turning left
i have a 2000 chevrolet silverado truck that the tow/haul light keeps coming on and going off and the tow haul engages without starting it.
Feb 26, 2010 | 2000 Chevrolet Silverado
Resetting sony 350 bd with no picture
This is button config for master reset without picture:
Home Left button x 3 Down button x 7 ok (centre button) ok Down button x 6 ok Left button x 1 ok ok wait a couple of seconds for settings to complete, when you switch back on you should have a picture and be back at language set up screen.
Hope this helps.
Please note I am from the UK and I am assuming your menus are the same as mine
Jun 14, 2009 | Sony BDP-S350 Blu-Ray Player
Freezes up while operating
I have found that my aiptek digital camcorder also freezes like this sometimes after I have pressed the button to stop recording a movie. You are right that sometimes you must remove the battery to unfreeze it, but I have found a couple of other tricks that work sometimes.
1. You can hold down the menu button for a few seconds (like 6). Sometimes this kicks it into the menu and unfreezes it.
2. Sometimes using the power button inside of where the screen stores to turn it on and then off again often helps.
3. Popping the digital card out (push in so it unlocks, then push it right back in) also helps unfreeze it for me.
If those don't work, pop the battery out again.
I do find that every few months I need to clean the connection points on both my battery and the camera where the battery clicks in. After I do this it behaves much better for a couple months. Good luck.
Mar 28, 2009 | Aiptek MPVR Digital Camera
Freezing screen
remove the battery for few minute if it still dont work look in the manuel how to reset normally they put it in the back small push it with a pen hope it work cheers
Jan 18, 2008 | Samsung SGH-d807 Cellular Phone
Bosch Exxcel KSR34423 Refrigerator Logo
1,451 people viewed this question
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
