Question about Refrigerators
Contents of crisper drawers frozen solid Jenn-Air JFI2589AES
I have had a Jenn Air JFI2589AES for about a week now and am having a problem with the temperature. It freezes everything in the vegetable and fruit drawer SOLID even though I have set the refrigerator temperature at 45 degrees. Has anyone else had this problem and have you solved it?
4 Suggested Answers
22yooper
  • 828 Answers
SOURCE: Vegetable crisper drawer problem with food freezing
Absolutely lower the setting.
Posted on May 21, 2008
SOURCE: Vegetable and fruit crisper drawers freezing foods
I had the same problem. Apparently the problem is the main control board. According to the technician that came out to fix mine there is a design flaw and these boards are very sensitive and can blow a circuit or malfunction from the slightest power surge. What happens then is that the control board doesn't "tell" the fan to turn on and off at the right time so the fridge and freezer warm up too much before the fan kicks in and then it cools everything down but since the fan isn't running at the correct intervals and circulating the air all of the cold air settles to the bottom which causes the produce in the drawers to freeze while the top shelves get warmer. I had done a fair bit of research before calling GE and came to the conclusion that this was a common problem. So I pressed them and was able to get the fee for the part waived (before I made the service call appointment) which was around $150. The part now has a 5 year waranty which I find funny, because I'm not sure why it wouldn't have that upfront as my refridgerator is only 2 years old. Whatever!! Unfortunately, unless you have indepth knowledge of refridgerator repair there is no way around the service call and labor. Anyone buying a new model of refridgerator (any company) should consider an extended waranty. The service tech also told me that all refridgerators made after 2001 are required, by law, to have an electronic mother board which in all likelyhood will fail at somepoint prior to when you are ready to buy a new fridge!
Good Lucak!
Posted on Feb 11, 2009
SOURCE: Bosch Refrigerator ice forming in vegetable drawer
Emptied drawers and cleared the drain hole. Drawers were then refilled BUT MADE SURE THAT THEY WERE NOT OVERLOADED
Posted on Jul 29, 2009
toolkits
  • 1099 Answers
SOURCE: My fruit and vegetable drawers
Hello, Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.the air deflector....
As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control I hope this will help....
Posted on Oct 31, 2010
Can I take the freezer door apart and wrap the water line with more insolation
No, you can't. The line goes into the mold of the machine with no access there.You have either an air leak in the dispenser area, around the ice shoot possibly, or the resevoir, which is located on the refrigerator side in the lower area behind the drawers is freezing, which is most likely the case. There are vents on the lower section for the crisper drawers. If you take out the drawers you'll find a roll of 1/4 " tubing which they call a resevoir that cools the water down. This is probably frozen,and you can insulate this, but I would raise the temperature in the fridge side or close the vents to the crisper area.
May 08, 2012 | Whirlpool ED2FHEXN Side by Side...
Water dispenser frozen?
You have a resevoir inside the fridge compartment that needs to be defrosted. It is frozen.
It is usually located behind the crisper drawers.
It is a small plastic tank that is white about 6 inches or so in length and bolted on to the wall behind the crispers.
A hair dryer usually does the trick in about 10 mins.
Regards
Brian
Aug 06, 2008 | Jenn-Air JFC2089HE French Door...
Water dispenser just stopped working. Ice dispenser still works and the refrigerator has a new filter
two possibilities
1) the water valve is defective it has one inlet from the house plumbing,two outlets, one for i/m one for water dispenser
2) the reservior that chills the water is frozen, it is located behind the lower crisper drawers in the ref. to see if its frozen remove crispers and shelves and tap on it , if hollow sounding it's not froze if solid sounding its froze. to thaw it turn off unit for at least a hour
Jul 21, 2011 | Kenmore Side by Side Refrigerator
I have a Jenn air side by side refrig/freezer
Hi rdiorio.
you could have one of many faults, either thermostat, compressor or if electronic maybe that have failed. If the Thermostat starts to fail it can produce eratic readings which freezer the chiller part of cabinet, then it can fail completly. What ever you do remember 240 Volts kills. Use a qualified person when dealing with electrics... Cheers
Mar 29, 2010 | Jenn-Air JCD2389G Side by Side...
Jenn-Air JCB2059ES refrigerator makes weird noise
Sounds like the plastics are just rubbing from vibration. redistribute the contents of the drawer and see what that does. Good Luck.
Nov 21, 2009 | Refrigerators
Why are my veggies freezing even thought the temp is set to 40?
Most fridges have crisper drawers that have a selection lever on either the front or side of the drawer that allows you to select eiher veggies or meat. Veggie setting is supposed to keep the crisper drawer warmer, while Meat setting makes it the coldest possible.
If you don't have the selector slide levers, I would suggest you use the highest possible crisper drawer available, as the lower in the frdge compartment you go, the colder the air will be. That should resolve the problem you're having, other than lowering the fridge temp setting slightly.
You might notice a cold air exchange vent next to your crisper, which supplies cold air from the freezer section into the fridge section, so that could be contributing to the colder temps in the crisper where you keep your veggies.
Hope you find this Very Helpful and best regards!
Aug 20, 2009 | Jenn-Air JBL2088H 20 Cu. Ft. Cabinet-Depth...
Contents of crisper drawers are frozen
may be a faulty compressor. ours went out last week, covered by 5 yr warranty though.
this might cause over-cooling and frozen water dispenser as well.
Oct 24, 2008 | Maytag MFD2560HES Bottom Freezer French...
Water on the bottom shelf of the Refridgerator
Has the refrigerator got a wet inner back?
Ff this is wet, adjust it until this solid ice 'blobs', bt not encrusted, like in a freezer
The refrigerator may not be cool enough and the natural warm moisture allowed into the cool compartment when the door is open is condensing into fluid before it is cooling sufficiently to suspend the moisture as a vapour. If the cool compartment is cool enough, any warm air admitted ill be chilled before it is allowed to condense, keeping the refridgerator dry.
However, the only drawback is that you will have to monitor it to prevent the build up of excesive ice.
Also, whether the refridgerator is either empty of full willaffe the day to day operation.
Hope this helps.
Oct 20, 2008 | Whirlpool ET1FHTXM Top Freezer...
Manuel - User's Guide
I'm not sure if this will help or not, but the manual number is 12828144A.
I recently purchased the same jen air model and have a problem with everything that is in the vegetable and fruit drawers freezing solid! Does you mother have the same issue?
Jul 24, 2008 | Jenn-Air Refrigerators
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
