Colour fades and comes back to normal on and off all the time goes black green and red
It's getting fix, thank you for your help.
Posted on Nov 06, 2008
I disconnected the pump and need to know where the red black aND WHITE wires go
Hi, this is John the Hayward tech. You say the wire colors are Red, Black and White. Does not seem that the wires colors were correct from the start. Not knowing your voltage let me clarify some things. Normally if you have 115volts coming into the pump you wire colors should be Red or Black to L1 White to L2 and a green ground to the green ground screw. If you have 230volts coming into the pump the two hot leads are normally red and black with a green ground. The red and black wires go to L1 and L2 does not matter red or black. The green goes to the green ground screw.
Sep 03, 2014 | Pool & Spa
I have a 2002 Suzuki Swift 1.3 and I need the colour coding for the car stereo. This is how it looks like looking from the back of the connector. The top colour is the main colour and the bottom is the...
why post non usa cars to USA forum>????
hint, we dont have M13 here. (EPA ******* here)
then not telliny your county.
why"?
my guess is you think all cars same, all suzuki same world wide and all suzuki have 1 radio.
sorry that don't fly.
but most posts here are just like this, hopeless.
wild guess 1:
here is our last swift, sold USA.,(not a m13 for sure)
wires
MAin set; and speakers last.
wht/blk, = ign. on. power 12v
white = memory , hot all time to battery via fuse, station memory
black = ground
red-green = illumination
red-yell = park lamps on, lighting,.
and below is speaker.
this is year 2000 last car sold here,
Mar 13, 2017 | 2001 Suzuki Swift
My Samsung LCD TV slowly flahses colours, each about 2-4 seconds
hi,
your lcd is in test mode. you may try off the power. press and hold menu + source + power on.
this should go back to normal mode.
Apr 01, 2010 | Samsung LA40M81/BDX 40 in. LCD TV
All colours and black print faded. Black is a
ANSER #1
Assuming that you are using original Canon cartridges or a brand of Compatibles that you have used before.
If print results are blurred, colors are faded or not printed correctly, the pint head nozzles are probably clogged.
Follow the procedure below to print the nozzle check pattern, check the print head nozzle condition, then clean the Print Head. You may have to do this 2 or 3 times.
If printed ruled lines are misaligned or print results are otherwise unsatisfactory, aligning the Print Head may improve print quality.
Caution Do not rinse or wipe the Print Head and ink tanks. This can cause trouble with the Print Head and ink
tanks.
Note Before performing maintenance
Open the Top Cover and make sure that all lamps on the ink tanks are lit red.
If not, see Checking the Ink Status and take an appropriate action.
Increasing the print quality in the printer driver settings may improve the print result.
Sep 30, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
My monitor displays bright green pixcells in the black areas of text and pictures .I have tried a different monitor (lcd also, no problem ) to isolate the fault back to the monitor.
some time we can see that of problem as screen convert in to voilat and green colour. it is called colour fade. assambaling parts is lose of bord and other. it can be correct by soilding by expert tech. it is more seen in old crt monitor. thanks
Jun 14, 2009 | ASUS LCD Monitor
Screen Goes Green TV goes to stand by blinking 8 times
try adjusting your color tuners located inside tv behind speakers.
Nov 25, 2008 | Sony KP-57WS500 57" Rear Projection...
What coloured wires go where on the main oven thermostat
If you are speaking of the 240v connection to hook up the oven to the electrical source, then white is the neutral(white to white), black is one of the 240v hot wires(black to black), and red is the other 240v hot wire(red to red).
Finally there is a bare or green color ground wire that goes to the bare or green wire form your source.
normally, the two outside wires on a terminal strip are the hot wires and the middle onif the neutral(white). It does not matter which wire(red or black) goes to what hot terminal at the appliance.
If you are talking about the internal wiring, I can get you a schematic of that.
Mar 13, 2008 | Ovens
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
Electro Med Services...
