I have a packard bell imedia mc1539 and have done a complete recovery on the system. Now the system will not boot. It keeps saying boot from CD and if I go to the BIOS and change the order it then will only give me a black screen with a flashing cursor. Help !
  • yellowhawk Nov 06, 2008
    thank you very much I will try this when I get home from work ! :-)
    Scholar:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 89 Answers
You'l have to make sure that the HDD is detected as the pc posts. Or, you can verify by going into the BIOS and see if the HDD is detected. Also try and check if the HDD is receiving power. When a computer is first started, the HDD will make this certain noise and initiates when powered. That's just know that the HDD powered up and initiated. So then, if the HDD is receiving power but is not detected in the BIOS, it might be the IDE cable. But in most cases, it's probably a connection issue of either the data cable, or the molex connector. Check it and verify that the HDD is detected. Good Luck.
Posted on Nov 06, 2008
I have a Packard Bell Imedia desktop not sure of the model. It was working fine until recently, I switched on my pc and after the boot screen "NTLDR is missing Alt Ctrl Del" message appeared....
Remove the hard disk and attach it to an USB hard drive adapter and then connect it into the USB port of a working computer. This computer will detect the hard drive as an external storage device, then you can open the various folders and files to copy your files to this computer or burn your data to a CD/DVD disc or USB flash drive.
Return you hard disk back to your Packard Bell so you can reinstall Windows.
Aug 10, 2011 | Packard Bell iMedia 6826 (P481000502) PC...
Pc wont come on says it can not locate winnex
hi if you have a windows xp system you should try to boot by menu
pressing f8 at bios boot screen to select the option that fits better to your needs
since you are not giving more detail of what happened to your system..
you can try also a do a recovey thru the discs restoration or at boot thru recovery partition if you have it include in your hard drive..
sincerely:inggalaxia dont forget to give a comment a vote thanks.
Jul 11, 2011 | Packard Bell iMedia 6826 (P481000502) PC...
My pc keeps on restarting after loading the xp screen
Disconnect any new devices you may have recently added and boot the PC.
As its booting press the F8 key several times, this should bring up several boot options. Choose "Safe Mode" .
This will bring up windows in a stripped down form, once complete click on start - all programmes - accessories - system tools - system restore (This is for XP, vista and win7 are a little different)
Restore to a date prior to when all the problems started.
Jul 04, 2010 | Packard Bell iMedia 6826 (P481000502) PC...
How do I do a complete recovery on a Packard Bell imedia 1569 computer, to get it back to factory settings ??
You just boot from the Recovery cd and follow the instructions as they appear on screen.
Jun 26, 2010 | Computers & Internet
Packard bell pentium3 windows me
F1 is probably the key to enter the Bios setup utility. Press and hold the F1 key immediately after you start the machine. Go to the boot priority section, and set your CD-Rom as first boot device. Press f10 to save the settings and reboot with your recovery disk installed
Apr 29, 2009 | Packard Bell iMedia SL 9553 (P660401806)...
Packard bell i need to reboot my pc tp wipe my hard drive of virus and restore everything to factory defult
put recovery or wincd disk in drive restart when screen says boot with cd click enter follow the steps
if can't boot from cd restart while continuosly pressing f7 startup options will appear high light cd or cd/dvd option
then should boot with cd
Jan 16, 2009 | Packard Bell (190169) Power Supply
I need to reinstall windows on packard bell imedia 5106
 Because you have a packard bell, I would assume this is a much older system.  You would have to put Windows 98 on it I presume unless you have enough memory to do XP.  Either way you will need one of the Windows CDs to load the software... I ve seen Win98 on Ebay for $50. Once you have the software, you will need a boot disk.. You can download this off the Internet.  What this boot disk does, is it loads the utilities that you need like to format the hard drive and it will also load the cd rom drivers so you can use your cd rom and install windows from the cd... Load the boot disk and once its loaded you can use the format command.  At the C Prompt, type     format C:     It will erase the Hard Drive. Once completed,  Reboot the computer with the boot disk still in. When it gets done you can install Windows. Most times it will assign the cd rom drive a letter. Usually D or E.   When it comes up type    E:\Setup This should start your install.                                                              Joe < Data Miner >
Oct 30, 2008 | Computers & Internet
System won't start.
try to run in safe mode when u start your computer Press F8 key continue.
then u get menu of safe mode etc....
if u able to login go to run then type: chkdsk /r"then "y"
if u not able to login u must have win xp bootable disk or recovery setup.
then boot your susstem with first boot device as cd rom.
if u want more help i help u bye chat support to.
Oct 25, 2008 | Packard Bell iMedia 6826 (P481000502) PC...
Display problem
You don't have a display problem, you have a hard drive problem.
It is probably a file system corruption.
Insert the Windows XP install disk into your CD drive and boot to it. At the first setup screen, press R to repair windows from the recovery console. Once the recovery console loads, type
chkdsk /r and then press Enter. Once this finishes, remove the CD and reboot. With any luck, you will be able to boot successfully, if not, come back and give details about what happens.
Mar 06, 2017 | Packard Bell iMedia 6826 (P481000502) PC...
Computers & Internet Logo
77 people viewed this question
David Payne
David Payne
