Question about Magellan Maestro 4040 GPS Receiver
Broken-off power connector
The yellow power connector detached from the solder points on my 4040. It is intact but I don't know what to use to reconnect it.
Odinsailor
  • 3 more comments
  • scottydepot Nov 08, 2008
    exact same problem for me. simple fix-open gps, 4 screw to open. solder the 4 contact points on the yellow power connector and then close unit and put back the 4 screws. it must be a bad solder like mine and broke with the vibrations when driving.
  • hot_50 Nov 17, 2008
    My charger plug wouldn't go all the way in and the power kept going on and off. When I push hard to plug it in the power connector broke off.
    It seems this may be a defect in this unit.
    Is there a trick to get the case apart. I unscrewed the 4 screws but it doesn't want to budge and don't want to force it.
  • HalSchmidt Dec 10, 2008
    I had the same problem, when I resoldered them (I only found 2), it will charge, but the connection is flakey and I have to keep moving it, so it it is not very usable.
  • john23452734 Dec 27, 2008
    i have the same problem but with the magellan roadmate 1430
    should i do the same thing to fix it?
    President:
  • 1,111 Answers
Most likely the power port is damaged and needs replaced.i repair those magellan gps if you need help. if i cant fix it there isno charge. wmetz@comcast.netto open the case on a 4040 you must start on the power button side, otherwise youll break the unit
Posted on Jun 12, 2009
Plug in for the auto power plug is broken inside
if your able to replace that power port yourself, you can get one HERE, if not, ask the fellow that sells them for help
bill
Apr 20, 2010 | Magellan Maestro 4040 GPS Receiver
Magellan maestro 5310. when pluging in th power
yes it can be fixed
you can go here for help
the following magellan 2000, 2200t, 2500, 3000, 3100, 3140, 4000, 4040, 4050, 5310 and the 6000 are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc power port...
you can get it repaired, here
or buy the port here
if you need further help, just let me know.
Oct 15, 2009 | GPS
Loose part at the power input point.
it comes apart take out the 4 screws in the back. you'll need something to pry the back off .start on the side with something thin to unsnap the 2 halfs then use your fingers. after openning you'll need to resolder the powerport back on with a soldering iron and new solder. 4 spots hold the powerport on. it will be stronger than before. mine worked fine after.
May 03, 2009 | Magellan Maestro 4040 GPS Receiver
Magellan Maestro 4040 power connector has is loose how do I open
Remove the four very small screws from the corners of the black case. Carefully with a thin screwdriver or similar tool, pry the silver frame off the black back. This will expose the circuit board. You must also detach a small cable connecting the screen to the circuuit board.
Mar 23, 2009 | Magellan Maestro 4040 GPS Receiver
Meastro 4040 wont charge reliably
I had the same trouble exactly. The yellow power input socket has a pin and shield connection that must be contacting the center and side of the power input plug. I opened the Magellan and found that one side of the shield contact had never been soldered to the PC board. It was only a matter of time and use, before the piece moved up and away from the outer part of the power socket. A dot of solder solved the problem. The case for the Magellan is easily opened by removing four very small screws from the four corners of the black back and then prying the silver framed screen from the back exposing the printed circuit board. I am sure this completely voids the warranty with Magellan, but they will not repair out of warranty units anyway. Be aware there is a connector from the screen that is plugged into the circuit board. This is easily pulled apart with a pair of fine needle nose pliers and replaced the same way after the repair. The soldering should be done by someone with PC board assembly experiance.
Handy John
Feb 21, 2009 | Magellan Maestro 4040 GPS Receiver
I have the Magellan Maestro 4040. The yellow power connecter has come lose/off and is inside unit. I can't seem to figure out how to open unit
You have to use small screw drivers to open unit and re-align the yellow connector. Maku sure that when all screws are undone. Pry it open carefully not to misplace or misalign any other parts. If the connectore is really broken from the connector board, we need service technician to either solder it for you or replace some parts on the connectore board itself.
Jan 17, 2009 | Magellan Maestro 4040 GPS Receiver
Problems with Magellan Maestro? 4040 GPS power connection
Wow if you opened the unit Magellan can tell. If your unit was under warranty You might have talked them into a repair (if your very very very persistent with you can get thin done , eventually ) but now you talk to them to see what they can do but it may be cheaper to go get another unit
Jan 12, 2009 | Magellan Maestro 4040 GPS Receiver
I also have the same problem - the yellow power jack has broken connections. I fixed it by soldering it back. In my unit, the connection pads under the external power jack were intact and I was able to solder the jack easily. The audio out jack nearby has also come-off the PC board, along with the pads. I am not able to re-solder these back. Since the audio jack is part of the speaker circuit I have lost the text-to-speech function!
Hope you are able to fix yours.
Dec 17, 2008 | Magellan Maestro 4040 GPS Receiver
this is a very common problem with these magellan 3140 and als the 3100,2000,2200t,2500,4000,4040 and the 4050most likely the power port is damaged and needs replaced.i have these power ports but often they just need re soldered..i can repair these magellan gps if you need help. if i cant fix it there is no charge.wmetz@comcast.net ...to open the case on a 4040 you must start on the power button side, otherwise youll break the unit
Dec 16, 2008 | Magellan Maestro 4040 GPS Receiver
hi ,
I understand from your mail that the power pin in the unit has been broken.
contact the Technical Support at 1-800-707-9971 so that they will give you a RA number and the address for the repair center.
Mar 07, 2008 | Magellan Maestro 4040 GPS Receiver
Magellan Maestro 4040 GPS Receiver Logo
116 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Mike Cairns
Mike Cairns
Are you a Magellan GPS Expert? Answer questions, earn points and help others
