Question about Frigidaire GLTF2940E Gallery 3.5 Cu. Ft. King Size Front Loading Washer
Niose On spin the washer makes a LOUD banging noise until finished???
  • 641 Answers
Open washer's cover and look for a released or a malfunction shock absorber Good luck!
Posted on Aug 24, 2007
When spinning on highest spin make very loud noise like brick inside then heard loud bang and noise stopped washer carried on spinning
Hello that sounds like a broken spider that's blotted to the drum what hold the drum to the bearings if one is broken that will do that the banging is when it pop out on a spin it sounds like a brick hitting the back I would be very carefull as it can try and flip the machine if it catch the drum it's not bearings as you said it stopes and it was ok so it's the spider and most drums are sealed units so you can't do any thing ok hope this has helped you
Nov 13, 2015 | Washing Machines
How do I fix a ge top load washer that's making a loud banging noise while agitating?
There is either a balance issue or a damaged spring. Usually all you need to do is open the washer (make sure it is OFF) wait for it to stop spinning... then look for clothes bunching up on one side. Take some out ad move them around.
Sometimes putting in to many or too few items will make it harder to resolve. Items like large towels or several towels, sheets and such will hold more water and be heavy until the water starts to pull out.
Oct 09, 2014 | Washing Machines
When washer spins it makes a loud banging noise, washer is a front load kenmore
Thanks for choosing FixYa and welcome. Anytime loud noises are heard, it can almost always be traced back to the drive motor. That is what controls the spinning. Check that and the spin bearing. One of these two are probably your problem. Make sure the washer is level though. Check the suspension.
Apr 30, 2011 | Kenmore Washing Machines
Frigidare front load washer has loud banging on spin cycle. After much work we reallized one shock was broken of which we repaced both now it still making the loud banging shaking motion. Also the washer...
Thanks for choosing FixYa and welcome. Since the suspension is ok and it is level, check your drive motor and spin bearing. Usually, these are the trouble parts when loud noises are associated with the spinning cycle. Your drive motor controls the spinning. Since the noise is during spinning, that is probably where your problem lies.
Apr 29, 2011 | Frigidaire GLTF1670A Front Load Washer
Loud banging noise during rinse
Most noises from a washing machine occur during the rinse or spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Apr 08, 2010 | Whirlpool GHW9100L Front Load Washer
Noise during spin cycle
check the counter balance weight
Jul 26, 2009 | Maytag SAV571EEWW Washer
Very LOUD 'banging' noise.
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 20, 2009 | Kenmore 41042
Banging noise on spin cycle
most front loaders are balanced by a large: ready for this: cement block inside at the top of your machine and because spin is so fast it can sometimes hit inside your machine or it has brokin a peice off ,sorry but yours going to have to get the repair person out.adrian
Feb 15, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Model 110 washer will not go into a final high speed spin.
hi, i would suggest the timer/programmer is faultyas it is ok on the other cycles, the noises you have described may have caused some damage,
Feb 10, 2009 | Washing Machines
Loud sounding like loose parts when draining
possibly a coin or hair clip in the pump if not the propeller on the pump may be loose try locating the pump under the machine and try to romove it
Nov 11, 2008 | Kenmore 43052 Front Load Washer
Frigidaire GLTF2940E Gallery 3.5 Cu. Ft. King Size Front Loading Washer Logo
75 people viewed this question
Top Frigidaire Washing Machines Experts
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
jimorris77
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
