Question about Samsung LE32R72B 32 in. HD-Ready LCD Television
Samsung LE32A559P4F Hi,got problems connecting my brand new screen to my pc,it seems to load windows just fine but just before is about to load up windows it just goes black and it freezes,you can still hear the sound of windows on the background with the welcome menu sound,any suggestions,thank you.
SOURCE: No Picture - Samsung LN-S4692D 46in HDTV LCD
I had the same problem and I replaced the t-con board. My t.v. is fixed!!!! I just couldn't see spending another 700.00 dollars for a repair shop to fix it. The t-con board is located at the top of the t.v. once you remove the back cover. Be very careful removing the two plugs at the top of the board which was easy once I figured out how the clips worked. there is a black lever like connection which flips up, then grip with your fingers the tab and slide the tape like wires straight out. The bottom plug is very simple. Also to expose the t-con board you will have to remove a heat shield cover. Once removed there is foil looking tape that needs to be peeled back to expose the board. The board is very sensitive to static electricity so if you have a grounding strap that you can strap to your wrist and ground to the frame while performing your repair. Its best to lay the t.v. face down on the kitchen table with a blanket to protect the screen. Good luck!
Posted on Sep 07, 2008
SOURCE: Samsung HP-R5052 50 bottom hallf screen turns black
Tntroy1, Thank you so much ..... That was the problem
Posted on Sep 24, 2008
  • 133 Answers
SOURCE: Screen goes completely out.
when it blanks out, tuen the lights out in the room, and shine a flash light at the screen, see if you can see the picture, if you can, it is the inverter moard blamking out, thats the board that lights the back lights, if you cant, hit the input button on the remote, if the TV comes back with a picture, it is a problem with the main board, in paticular the componant input on the main board
Posted on Jan 10, 2009
SOURCE: Samsung Plasma 50" No Picture but have sound
BAD Y BOARD
Posted on Jun 08, 2009
circuitworld
  • 335 Answers
SOURCE: sound but no video HPT5054 Samsung
One of your transformers on the inverter board are failing to sustain regulated power to the florescent lamps resulting in a dark picture. Also check the SMD fuses on the inverter board(s) see if they have blown. You will need a continuity meter to check them. You can get one from radio shack and be sure to get one with audible sound....you don't have to replace boards when you can fix them.
Posted on Jul 10, 2009
ML 2240 printer not detected by Windows 7
Try installing it in safe mode.
To go to safe mode, do the following:
Restart and tap F8. Use the arrow keys to highlight safe mode with networking and hit enter. Install the driver from there and follow the on-screen instructions.
If no go, check the device manager of any question mark. There might be some outdated drivers that cause this problem. You can use RadarSync (free version) to scan your computer for outdated drivers.
After fixing all driver related issues, try installing the printer again.
I hope this helps!
David
Feb 25, 2013 | Samsung ML-2240 Laser Printer
Frozen MP3 player - MPIO HD300
Have you tried downloading the specific drivers for that MP3?
Here is the site...choose your player then download and install...reboot and see if it solves your problem.
http://www.mpio.com/downloads/index.php
Feb 29, 2008 | Mpio HD-300 MP3 Player
Hello there , i d like to express my problem here , with the hope to find a solution . I have an LG L1730s monitor for about four years . Recently i had a video card burn and i changed it with a new one ....
Hi
I've repaired a lot of these monitors and every one seemed to do something strange. In this case my first thought is that somehow he monitor firmware got zapped when the card was damaged. Although this could certainly fall into the category of an open ground in the cable. My suggestion at this point would be to take it to a reputable repair person and get their estimate or take a look at www.micromendllc.com.
Aug 18, 2010 | LG L1730S 17" LCD Monitor
Monitor won't work after computer starts up
You need to be sure that your unit is unplugged first before connecting PC. You will see all of your startup settings on your PC. In order to view the desktop on your monitor (does not work on Mac OS) press CTRL+F5. Anoption box will appear and by holding CTRL button and pressing F5 you will see your options change.
Aug 07, 2009 | Samsung ToC T220HD 22 in. LCD HDTV Monitor
SAMSUNG G600 USB CONNECTION PROBLEM
http://www.nodevice.com/driver/company/Samsung.html
this is a driver link installed it the driver and try to connect it and installed the software also from the cd
at firsst you installed the cd software after then you installed the driver
May 06, 2009 | Samsung SGH-G600 Cellular Phone
Samsung v20 display keeps going i have changed the screen cable
sounds like your new screen cable is either loose or faulty.i had same problem and was only after i had removed keyboard and ensured cable was tightly connected did i solve the problem.it seems to be a design fault in the samsung v20
Jan 24, 2009 | Samsung V20 XVC 2400 Notebook
AMD XP2400+ with K7S41GX
Hi, the only reason that comes to mind here is your version of XP. A retail version will load on almost anything, a version supplied with a brand name computer may only be suitable for that brand, Dell/HP etc. Sorry if I am not much help, don't discard your old board, you could buy an add on card for ide connection then disable the onboard one and continue with the old system. Goodluck mistyman
Sep 09, 2007 | Asrock K7S41GX Motherboard
Samsung LE32R72B 32 in. HD-Ready LCD Television Logo
64 people viewed this question
Henry  Thomas
Henry Thomas
