Convergence is off for one minute then you get a normal Picture I replaced the convergence ICs.
  • 728 Answers
It might have to warm up causing the delay in your normal picture but just to be sure, check to make sure all of your cords are connected in the right way and check them to see if they have any shorts. Then check the setting you have for the convergence and make sure those are correct and normal. That may be your problem and after that, it should be quicker.
Posted on Nov 05, 2008
    Scholar:
  • 155 Answers
It could happen if the ic is not fitted properly.check it again on the main board.
    Sergeant:
    Novelist:
  • 196 Answers
It is necessary to replace all the convergence ICs when ever you replace.not only 1 which is faulty. and also check the capacitor which supports the convergence ic on the board if that is about to blow it will show this problem. or if the ics are not fitted firmly and r loose on the board it shows this problem.
Focus Error I am getting double picture and the colors are off. When trying to auto focus the blue lines are wavy.
Replace Convergence ICs ,Big black ICs will have PN# on them example STK 392-110
Mats has ICs 1-800-628-1118
Jun 05, 2011 | Toshiba 42H82 42" Rear Projection...
Convergence is bad on left side...good on right.....where convergence is good the picture is great
Re-solder convergence output ICs pins and nearby big resistors that might solve your tv picture problem and if that does not help then replace both convergence output ICs to fix the problem.
Convergence output ICs would be available in local repair parts shop or google it.
Thanks.
Feb 25, 2011 | Sony KP-65WV700 65" Rear Projection HDTV
Wavy lines green and orange hue.While watching a fooball game the status bar is wavy and in two separate lines-Green and Orange-Tried flash focus and convergence and powered unit off for several minutes...
Flash focus button push,didn't solved pictures convergence problems.The tv convergence board is dead.The 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Sep 18, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Sony KP 51 HW 40 - in left half of screen picture has double images, right half of screen picture is normal.
This problems very common on DLP Tvs.This problems known as a convergence problems,it dead.Colors lines R,G,B mis alignment,have colors shadows or 3D pictures.The tv convergence board is dead.Require to be replaced on the tv convergence board 2 STK convergence ICS and some or all it resistors to solved the tv convergence board problems,to solved tv convergence picture problems.The shop,will cost about $300-350 for parts and labors.
Sep 18, 2010 | Sony KP-51HW40 51" Rear Projection...
Projecting double images
When convergence output ICs got failed, tv shows double image or 3D like picture. Replace convergence output ICs in tv to fix the issue. Local tv repair shop will replace it for you.
Jul 07, 2010 | JVC AV-56WP74 56" Rear Projection...
Sony KP-57WV700 Convergence Repair Failed - TV won't stay on
Sorry ur convergence ICS are shorted and dead.Because u put in solders and take out solders to many times.The heat of ur soldering iron,and the electrostatics will kill the ICS,if keep putting heat in the ICS legs alots times.Buy the convergence kit again,replaced every componnents in that kit to ur tv.Because,the kit been research and put together.What the most common componnents that burn and dead in the convergence circuits.
May 04, 2010 | Sony KP-57WV700 57" Rear Projection HDTV
My color convergence is messing up on my rca p56924 when I turn it on its normal after 10-20 mins all of the colors split
Resolders the 2 convergence ICS and all it resitsors.Well get convergence back to normal.Not than the 2 convergence ICS must replaced.Try Website Tv Repair World.com for a convergence kit to repair it ur self,if u Know how to solders?
Feb 15, 2010 | Televison & Video
I can adjust the convergence where all the crosses look good , but at the edges left and right picture is misalligned.
Convergence is dead.Know how to solders?Must replaced the 2 convergence ICS,and all those resistors.Tries Tv repair World.com,Tvrepairkits.com for the convergence kit.Replaced what in the kit,ur tv will be back to normal.
Jan 23, 2010 | Panasonic PT-47WX49 47" Rear Projection...
Still issue with convergence after replacing ICs
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 08, 2009 | Sharp 55R-WP4H 55" Rear Projection...
Televison & Video Logo
64 people viewed this question
Top Televison & Video Experts
