Re: my brother pe150 embroidery machine does not pick up...
Try changing the needle rethread the machine--use every thread guide make sure the bobbin is not warped make sure the bobbin is inserted correctly in the case it's very possible that the timing of the machine is off & the machine would need to be checked at a sewing machine shop
Full details on how to adjust the timing appear here in my Brother PE150 blog. You will need a few basic tools including the stubby screwdriver that came with your machine.
Hi. This may sound silly, but the most likely reason the upper thread doesn't pick up the bobbin thread is that the needle is in backwards. (Sounds silly, but it's true!)
Needle shanks have a flat side and that flat side has to go in a particular way for your machine. With most modern machines, the flat side goes to the rear, facing away from you. Check your manual to be sure.
The second most likely reason is that your needle may be bent. Check that your needle is straight (or just use a new one).
Make sure that your needle is put in the correct way, there is a groove in the front of the needle, check with your finger nail, this is usually to be facing you, and make sure the thread is going through the tension holder correctly do not have the foot down when you are threading the machine,as this stops the thread from going through the needle tension holder.
If you tighten up your needle thread, reduce the tension of the needle thread.
For embroidery, and zig-zag, and because the needle makes side movements, it needs more needle thread. So try to keep you needle thread not very tight, and tight up your bobbin case tension more, so that the two threads meet under the meterial.
You need to adjust your top tension and maybe your bottom tension ( the little screw on the bobbin cover) Also check your needle and make sure it's straight.
