Question about Refrigerators
Water leaking from freezer down to refrigerator at a slow drip.
    Problem Solver:
  • 8 Answers
There is a solenoid that controls the water flowing to the ice maker in the freezer. It is usually near the bottom of the fridge on the back. It may be covered by a cardboard or metal back that is easily removed by taking off a few screws. There will be one water supply line coming into it and one or two water supplies going out. When the solenoid begins to fail it sends water to the ice maker when it doesn't need it causing an overflow in the ice tray which leaks down into the freezer giving it a kind of glacier effect. Real easy fix though. Just replace the solenoid on the back of the fridge. I bought one online for around $20 and it is very easy to do. If you have water in the door and an ice maker it will be a dual solenoid. Turn off the water supply, disconnect the water lines,  take the solenoid off the fridge to get the part number. Google it, Get it, put it back in the way you took it out, turn the water supply back on and your back in business without a costly ripoff technician.
Posted on Nov 05, 2008
Why is my freezer leaking water into the refrigerator ?
Hey Trudy Guldin, thank you for your post!
Based off the information you have provided its sounds like there could be a potential issue within your solenoid, water valve, or water filter of your Frigidaire refrigerator. When was the last time you changed your filter? I would remove and make sure there is no damage visible on your filter. If so, you would need to replace the filter. If it is any one of the other underlying issues I would recommend having a technician come out to the home and properly repair your appliance. -Matt
Aug 27, 2014 | Frigidaire Refrigerators
My frigidare fridge leaks sporadically
Check the evaporator pan underneath may be full of water. Clogged and dirty coils will not allow air circulation and slows the evaporation down so it overflows. If insied leak, check the drip cup in the center of the fresh food section just below the freezer , if its full of food water will overflow into bottom of fridge.
Aug 24, 2014 | Refrigerators
The freezer door leaks water from the water/ice dispenser. The dispenser fills up with water. Items in the freezer door almost seem as if they never freeze. All items in the door are much less frozen...
Leaky dispenser-------
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
Sep 09, 2011 | KitchenAid KSCS25FKSS Side by Side...
Hotpoint model #ctxy14epjrwh slow water drip from inside of the refrigerator. inside the top of the frig, center, there are several components that appear to come down from the freezer. the lowest one...
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the centeroldtech2332_52.jpg
Aug 24, 2011 | Refrigerators
Water leaking from freezer forms ice on bottom of the freezer needs to be removed every week or leaks onto the kitchen floor. water coming from back wall of freezer from what appears to be vent cracks in...
Hello and Welcome to FixYa!
Well, it seems like the drain pipe or the drain channel is clogged, and the defrost water from the evaporator coils is dripping through the quoted regions, down to the base. Try checking the drain hose/ channel and remove the clogging if any (Blow some moderate temperature air through the channel and check/ remove any permanent clogging If any). Feel free to ask the details, or any question relevant to the trouble..
Concerned.
Aug 11, 2011 | LG LRDC22731 Bottom Freezer Refrigerator
Ice maker leaking inside freezer compartment, water dripping down from unit
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
Sep 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Makes ice fine but the water drips down the back of the freezer running into the ice tray - help
The valve can leak because of sediment in the water preventing it from closing or low water pressure.
Jul 10, 2009 | KitchenAid Refrigerators
Water leaking from icemaker on outside
If this is your water dispenser leaking
Jul 08, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Kenmore elite - Water dripping from freezer to refrigerator
Your refrigerator has a defrost drain blockage behind the evaporator in your your freezer compartment. Some models like yours have leak in the turns as the water leaves the freezer. I recommend that you unplug and remove the cover to the evaporator and check the defrost condensate tray below the evaporator. A wet vacuum cleaner and poring a solution with clorox in the drain will help you clean locate the leak and where the blockage may be downline.. I do have the manual on yours and can help you solve this. Some times this is a factory defect and I can help you solve the freezing drain problem. Let me know, Sea Breeze
http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
http://servicepartstec.blogspot.com/
Jul 01, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Refrigerators Logo
242 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
