I have a Toshiba L300D, brand new, and i cant get it to connect to the internet via the in build wireless, but it will connect with a wireless dongle. The switch for wireless is on but it just doesnt locate any networks in range.
    President:
  • 1,111 Answers
Run the wireless setup wizard in the communications section..
Posted on Nov 05, 2008
My Toshiba r15-s822 isn't connecting to a wireless network and the router I already installed the router to my pc even connected an internet cable to it but Internet Explorer wont open it keeps...
Try connecting to the Internet through the ethernet port (via a cable). If Internet Explorer loads the target page then you have a configuration problem with WI-Fi access : The wireless security settings are not allowing the computer to access the Internet.
If Internet Explorer does not connect with the cable then the problem resides with Internet Explorer. Try to reset the defaults. To confirm that download FireFox and use it. Besides you need two browsers just in case one acts up.
Jul 02, 2011 | Toshiba Satellite R15-S822 Tablet PC
I had to replace my harddrive on a toshiba laptop. I put the recovery disk in everything went good until I try to connect to the wireless internet. If I plug the usb cable in the laptop it works fine but...
A "Diagnostics" can identify the cause of the problem, or (errors) and try to correct, the "Internet" connection. Go, to: Control Panel, select "Network and Internet." Select, (“view network and task status”),choose a task”, to performed, from the (left) pane. You can start a quick diagnostic by clicking on the connection "diagram", Computer---WNC---Internet. “You can (setup) personal computer, internet settings.” I hope this Fix it.
Jan 20, 2010 | Toshiba Satellite L300D-ST3501 Notebook
Toshiba Satellite L355D wont connect to the wireless internet
i am having the same problem and its not software related as i have my laptop dual booting with sabayon 5.0 and im getting the same result in that OS so this tells me that the hardware is failing
if your problem is the same as mine have you exposed your computer to cold or humid atmosphere?
mine sat in my trunk for a week this newyears
Apr 21, 2009 | Toshiba Satellite L355D-S7809 Notebook
Unable to connect to wireless router . its has a built in wi-fi
go to the start menu..
right click on my computer..
go to properties...
look for device manager..
then look for network adapters..
then they might be something with a yellow exclamation point
press it then install...finished
hope i helped you..
take care..
Apr 20, 2009 | Computers & Internet
Wi fi
Check to see if you have the wireless network switch turned on. If that isn't the problem, let me know.
Jan 06, 2009 | Toshiba SATP L300D Notebook
Wireless device disabled
Go into setup routine and enable wi-fi.Save and exit. Usuall you have to press delete or some other key when first turned on,to get into the setup screens and BIOS.
Dec 27, 2008 | Toshiba SATP L300D Notebook
Type of wireless
http://explore.toshiba.com/laptops/satellite-pro/L300
this shows all the l300d models at the bottom and what the card is in it. I would get the newest available for speed, and reliability. it is N. an N router will be backward compatible with B, G, and A
Dec 22, 2008 | Computers & Internet
Cant find own wireless
Set the SSID on at the router side. Alternately you can enter the SSID information manually at the computer side.
Nov 23, 2008 | Belkin (F5D7050) 802.11a/g/b Wireless...
Cant connect new toshbia l300d to wireless says no hardware installed
press f8when the toshiba name comes on screen at start up.on the menu that appears click on restore HDD.it takes about 25 mins to complete.should be installed then
Oct 17, 2008 | Toshiba SATP L300D Notebook
I cant connect to wireless on my brand new laptop :(
you need to make sure that your laptop has a wireless card in it and if it's working properly. if it has a wireless card already, the wireless card should automatically detect your wireless router (the wireless icon is usually located at the bottom right hand corner of your screen) and you just need to connect using the correct wireless settings (ssid and wireless security).you need to also check if the wireless capability of the router is enabled. make sure to check if the wireless light on the router is on.
here are the steps on how to check the wireless settings of the router
- open a web browser using a computer connected to the router via cable. enter http://192.168.1.1 on the address bar.
- it will prompt you to enter a username and password, use "admin"
- it will now promt you with your router's screen, go to the wireless section
- check the wireless settings like the wireless name/ssid that are listed there since that would be settings that you need to use on your laptop (note: you can change the wireless name/ssid to something that you can remember easily and just saev the settings)
- check also the wireless security if it's enabled
hope this'll help you
ciao!
Aug 28, 2008 | Gateway Wireless-B Router (wbr-100)
Computers & Internet Logo
57 people viewed this question
David Payne
David Payne
