Question about Philips Televison & Video
I have Philips 47pfl 9632d connected to my pc having geforce 9600gt video card. connection is hdmi to dvi-adaptor. having high rezolution like 1920x1080 tv is flickering, espiacially if I use a mouse. any ideas what could be an issue? thanks a mill
  • 3 more comments
  • striogiux Nov 05, 2008
    My resolution now is as low as 1600x900 and I checked mouse and it's fine
    I installed new drivers for my geforce9600gt and I think connection is fine. and flickering as I said starts when I start using mouse.
    is that a common problem with nvidia video cards and philips 9632d lcd television? Anybody had the same problem?
  • striogiux Nov 06, 2008
    my tv and monitors are on different resolutions and on different refresh rates. I'm kinda a bit affraid to use that recomended software as it was mentioned that it could f... my tv up
    well I can't see where is that sample rate option in control panel/mouse but my refresh rate is at available max which 60hz
  • 905 Answers
Your better off if you don't do the tv that way as this way does cause the tv's to malfunction with this type off connection , I have had mine hooked up with the s-video for three years watching movies on one while on the internet on another screen and I haven't had any problems with the card( nvida ) or my tv
but the resolution is the issue for that type of video transfer 720p is more appropriate for fast action as it uses progressive scan frames, as opposed to 1080i which uses interlaced fields and thus can have a degradation of image quality with fast motion.
In addition, 720p is used more often with Internet distribution of HD video, as all computer monitors are progressive, and most graphics cards do a poor job of de-interlacing video in real time. 720p video also has lower storage and decoding requirements than 1080i or 1080p.
Posted on Nov 06, 2008
    President:
  • 2,712 Answers
See if you can increase the refresh rate of the LCD Tv, and also the sample rate of the mouse (Control Panel > Mouse properties)
Posted on Nov 05, 2008
    Genius:
  • 1,124 Answers
Seem to be a resolution problem. Be sure to set the resolution to one that is compatible with your HDTV. If your computer monitor and your HDTV only share one common resolution, set it to that until after you get a picture on the HDTV, then change it to the desired resolution. When possible, always try to use the displays native resolution. For example on some HDTVs the native resolution is 1280x768.
You can use a great piece of software called Powerstrip to do this. Install it and then add the desired resolutions. To add a custom From here you can add a preset or user defined resolution. If your TV only accepts 1080i then use "1920x1080i 60hz" resolution, in PowerStrip go into display profiles, then "Advanced timing options", then choose "Custom Resolutions".
It is important to keep in mind that it is possible to break your TV by sending it the wrong resolution.
    Scholar:
  • 155 Answers
Check the screen by changing all the resolutions 1 by 1 .as 1 of them will suit the screen.or it could be the card problem in your pc thats not supporting as it should be.
  • fixexpert Nov 05, 2008
    also check out this link for the connections and proper adjustment.
    http://www.inspectmygadget.com/2007/06/1...
    thanks.
  • fixexpert Nov 06, 2008
    technician at your place is much advisable as its risky to take any steps without proper idea.if the tv get bursted it will cost you much more to get it repaired.and the technician will have all the required parts to exchange and locate the problem.as he will be onsite it will be much easy for the tech to come to the required conclusion.
    thanks.
    bet of luck before taking any further steps.
  • 113 Answers
Try to increase the color quality highest in computer, try to update the software for the video card, if the adapter cable is connecteted properly
    Sergeant:
    Novelist:
  • 196 Answers
Change the resolution settings to little low from what you have set.and also check that the wire of mouse is poroperly connected.if its loose it flickers.
  • mmechanics Nov 05, 2008
    many a times if the card is not supporting several different ----different problem occurs on the screen.it flickers or goes totally black for a minute then again come up automatically.etc   etc  ....
    remove the card and reisert back.
    thanks.
How to connect hdmi audio cable from video card Geforce 9400gt to mother board foxconn G33M02
Your Geforce 9400GT doesn't have a HDMI outlet. It only has DVI, D-sub and S video. So I'm not sure what you're asking.
Apr 18, 2010 | Dell Vostro 200 Desktop Computer
Is it possible to connect my computer with a VGA output to my HDTV with HDMI inputs?
hi there, sure it is.
either check if the video card has two output interfaces(VGA and HDMI) so use the white HDMI-otlet with a cable and your TV, else do get an VGA-to- HDMI adaptor and try connecting the VGA outlet and your TV-set.
Good luck
Sep 13, 2009 | HP COMPAQ Presario SR5410F Pentium...
I wANT TO CONNET MY LAPTOP TO MY CRT TV
What you need:
This is hard to define initially as there are so many ways to achieve this depending on what type of television you have and what video outputs your computer offers. You may also find that you only want to attach the stereo, and leave the TV disconnected, or vice versa.
.HDMI - High Definition Multimedia Interface: Ideally we will all have an HDMI connection on both our television and video card, but most likely don’t have it on either. Many new LCD screen and Plasma displays offer this mother of connections. They are also becoming a little more popular on Video cards. This will give you the highest quality signal. This format can also carry audio. This is very easy to connect from one device to another. It offers the same video quality as a DVI.
here are some tips that will help
Computer has HDMI and TV has HDMI – Use HDMI
Computer has DVI and TV has DVI – Use DVI
Computer has DVI and TV has VGA – Use VGA + Adaptor
Computer has VGA and TV has VGA – Use VGA
Computer has S-Video and TV has S-Video – Use S-Video
Computer has RCA and TV has RCA – Use RCA
Computer has S-Video and TV has RCA – Use RCA with adaptor
Computer has RCA and TV has S-Video – Use RCA with adaptor
Sep 10, 2009 | Gateway CX200S Tablet PC
What graphic card is compatible for my pc?? i have HP PAVILION, g3660d, 2 GB RAM, WINDOW VISTA home basic.I want to play games like Left 4 dead, COD 4....
Well... Windows Vista can be installed on anything. I'm not familiar with your particular PC, but there are two ends to the problem. A) Plug in to PC end. Here there are the PCI-bus, and PCI-E standards. PCI-E comes in many flavors, a tiny tiny connection (1 lane), and a wide connection (>1 lanes? don't remember 8?). Open your PC box and look at the slot closest to the CPU, that is typically the graphics card expansion slot. Take a picture (if you have a camera), note if this slot is "different" from the other slots... it is likey to be. Then you can google PCI-E and PCI connectors to see if you can match them up. If you have a *NEW* pc it's likely you have a PCI-E bus. This is the *faster* solution.
2) Card to monitor. There are multiple ports on many of the new PC graphics cards... from oldest to newest VGA - This is a DB-9 type connector... looks like a oval but is longer on one side than the other. (i.e. not a rectangle). This is the oldest standard. DVI - This is an oval connection.. You can get DVI to VGA adaptors, and some video cards come with them. This will have a series of pins and a "+" cross pin connection on it. HDMI -- The coolest and typically includes sound for direct connection to HDTV. But your monitor may not have this type of port.
So if your looking for a card, look for one that is either PCI-E or PCI based on how old your PC is, and also look at what types of video output connectors it has.. VGA/DVI or HDMI. Most of the newer cards will have HDMI and DVI output with a VGA adaptor. But some don't.
Then... there is the case of a particular card having "issues" with the game you want. If you have time... pick a particular card, then google for "my favorite game" [replace the game with your game name" and the video card with the word problems... to see if anyone has had problems with that particular combo. (I never do that... :()
Jul 07, 2009 | HP GeForce 8400GS Graphics Card - nVIDIA...
Video card not installing
Did you make sure you uninstalled the original 9600gt driver, other than that you could try safe mode with networking and download/install the driver.
May 26, 2009 | SPARKLE Computer Sparkle GeForce 8500 GT /...
Hdmi connection problem
it does do dvi-d for computer, but does not handle high-definition video. it does not have the same resolution.
Mar 14, 2009 | InFocus Proxima DP6155 Multimedia...
How to set my audio to hdmi while connecting my tv to my pc. my graphic card is Gforce 9600
I am pretty sure that the nVidia GeForce 9600 series of video cards use a DVI connector, not an HDMI connector.
While the HDMI connector has the ability to transfer digital and analog audio across it, the DVI cable does not.
You can connect a DVI video card to an HDMI display, and it is compatible for the VIDEO portion, but again, the DVI connector does not output audio at all.
You will need to connect the audio outputs of your audio card or motherboard to your TV by using a 3.5mm headphone jack to RCA jack adapter.
Dec 08, 2008 | Sharp Audio Players & Recorders
No signal on HDTV
Your graphics card is probably too old to support HDTV signal (720p, 1080p)
Dec 04, 2008 | Nvidia GeForce FX 5200 Video Card Graphic
Choosing a GPU
SAPPHIRE 100256L Radeon HD 4670 1GB
  • Chipset Manufacturer: ATI
  • Core clock: 750MHz
  • Stream Processors: 320 Stream Processing Units
  • Memory Clock: 2000MHz
  • DirectX: DirectX 10.1
  • OpenGL: OpenGL 2.0
  • HDMI: 1 via Adapter
  • DVI: 2
Although it only has a 128bit memory interface it makes up for this by the large amount of stream processors and the high core clock. It's cheaper than the 9600 and better.
Nov 02, 2008 | Computers & Internet
Choosing Graphics card.
NVidia Geforce series, i have found is the most reliable and less likely to screw with your system in a negative way like Radeon.
I have used all forms of video cards in the past. the GeForce series is stable. I have a Dual HDMI output card myself, its only a 512mb DDR2 but it does the work load of MMORPG's with ease and my system very rarely has issues unless i am trying to run more than i rightly should. So my suggestion is the GF9600T. It is powerful beyond beleif and will make resolution and texture ratio through the roof.
Thats my professional opinion on this.
Televison & Video Logo
110 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
