Question about Brother Multi-Function Center® MFC-215C All-In-One InkJet Printer
Paper jam My printer is giving - paper jam message. I opened the back cover and checked the paper passage but there is no paper stuck in there. I switched off the power to the printer several times but each time on restart it repeats the paper jam message.
    Novelist:
  • 188 Answers
Here is the most important thing to understand about paper jams in any printer....
The printer does not know if there is a paper jam anywhere in the printer.
What it does do, is respond to sensors ( optical sensors, either open or closed, by plastic flags). These flags are moved as paper moves through the paper path.
One example of a paper jam message when there is really no paper jam, is when the feed rollers are worn and do not pick up paper from the paper tray.
When you start printing, the printer expects that first sensor to open ( paper passes the sensor ) at a very specific point in time. If the paper did not get picked up from the tray, then the printer will ASSUME that the paper must be jammed somewhere because it did not reach it on time.
Now this will also happen if in fact the paper did get picked up and then jams prior to the sensor.
So... if you get the picture of how this works, understand then too, that if the printer is showing a paper jam message at power on, then one of the flags is open when it should be closed.
If you do not actually have a piece of paper holding this flag in the open position, then the flag is possible broken.
I usually see this kind of damage occur after a true paper jam, where the paper is removed either in the wrong direction ( pulled out back the way it was going instead of the way it should normally travel ), and this breaks the flag, or it was pulled out forcefully again, catching on and damaging the flag.
All of the above pertains to ANY printer, and not just yours. you must take care to fully inspect every inch of the paper path, from the paper tray, to the exit, use a flashlight, and look for the sensors and make sure they are not blocked or broken.
Good luck,
Cory
Posted on Nov 06, 2008
OPEN FRONT COVER MESSAGE WILL NOT GO
First check again if cover closed properly. If message does not go, Switch off the machine at the outlet and re-connect. It might re-set. If that does not work, try re-set button in the panel and lastly check troubleshoot in the manual. Good luck
Jul 19, 2013 | Brother MFC-7820N Laser Printer
I have a Samsung Printer Model SCX4100. I had a paper jam and removed the paper, however, I Have a Paper jam 2 Message and don't know how to clear it. Please tell me what I need to do to clear the...
This is a sample guide;
41093dd.jpgWell I fixed it!!! Here's what I did. You see this picture of the cover opened? Where the arrow's pointing is the home position of the printer head. Under there I found a scrap piece of paper! Here's exactly what I did. When I got home I decided to plug it in to see if it would work, but it made the same noise and showed the same error message as before. I opened the cover as shown above. This resets it, and it says "close cover". I closed it, and AS it started to go through its routine I OPENED IT again, and I could see the printer head moving back and forth. At this point I used a flashlight to see where the home position of the Head was, and that's where I found the scrap of paper!
I unplugged it for safety and was able to remove the scrap with my fingers.
By your descriptions, referring to the other users, you just might have the same problem.
Hope this may help;
Regards,
VOTIT
Aug 25, 2008 | Samsung Office Equipment & Supplies
When printing i get the paper jam message have checked for paper jam but dont see anything
Open the cover on the back of the printer sometimes paper is stuck in there and thats why you can't see it.
Sep 29, 2010 | Dell 1700n Laser Printer
I have a Epson stylus CX9400fax a piece of paper is jammed way inside the machine, I can't even see it to try and get it out! I've tried turing the machine on/off numerous time (still not expelling the...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
Jun 02, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Stylus CX9400 Photo Printer: paper jammed inside printer...
May 18, 2010 | Epson Stylus CX9400 Photo Printer
202 paperjam open rear door. My printer did have a paper jam and we removed all the paper we could find, but that message won't go away and it hasn't worked since! HELP!
Hello and Welcome to FixYa
Start by following the steps below to get the paper out from the machine.
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Advanced
If that doesn't help then you would have to start taking apart the machine to find the jammed paper and remove it, its not something a just anyone should do unless you have experience.
you may have to take the machine to a repairer to get the jammed paper bits out of the machine, if you don't see paper jammed in the machine it does not mean that there wouldn't be a paper jam somewhere in the unit along the paper path. Some of the switches or sensors might have gotten stuck.
Jan 04, 2010 | Lexmark T630 Laser Printer
Network Printer 12 paper jam
In order for a jam message to reset to READY, the printer logic is looking for an "06 COVER OPEN" message. The top cover of the machine must be opened to clear the jam message. If the top cover interlock switch is stuck closed, the printer logic never clears the jam message, even after all the paper has been removed. The printer appears hung with the paper jam message and can only be made READY by powering the printer Off and back On.
Jun 16, 2009 | IBM Network Printer 12 Laser
Hp6210 says "Paper Jam. Clear Jam and then Press OK". There is no paper stuck in it, nothing visible at all.
Open the rear clean out cover and check for a jam. Or the rear clean out cover could just be off like mine was. I was get out of paper message. So I found a the HP help manual that there was a rear clean out. I reached around back and found that i twas off, I popped it back on and it works just fine now.
May 27, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Paper jam message brother MFC-440CN
Generally theres still a small piece stuck somewhere. Remove the back where the paper feeds through and check there. Then open the top so you can see the ink head and check around there. That should do it. The printer sometimes wont remove the jam until you open that top lid.
Also try switching it on and off again just to be sure.
If it's still there, the only other way is ripping it apart to find that pesky bit of paper still stuck.
Mar 24, 2009 | Brother MultiFunction Center MFC-440CN...
Brother Multi-Function Center® MFC-215C All-In-One InkJet Printer Logo
193 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
