Question about Pyle (Plcmtbl) Led Exhaust Tip
PLCMTBL TIP THE PRODUCT DID NOT COME WITH THE CONNECTION WIRING OR A HINT ON HOW AND WHERE TO ISTALL
  • TOMASROMAN Feb 03, 2009
    thanks for your help...
    Scholar:
  • 67 Answers
The company does not supply this wiring, or a diagram, because everyone has different ideas of what they want. Your best bet is to get a lot of matching gauge wire to extend the length you can run the wire, and then somehow get it run into the trunk of the car. Once you do this, all you will have to do is connect it to the wire you want. I am guessing you want it to light with the parking lghts, so simply splice the parking light wire, add this into the chain, and reconnect. Then, anytime you turn on your parking lights, on wil come the LED Tip. If you can't get to your trunk with the wire, find an obstruction-free area on the underbody of the car and run the wire to the engine. Then you have your choice of options for connections as well. I hope this helps.
Posted on Jan 30, 2009
205swan secura view Gw205 wiring diagram broke power plug from monitor
Look for a wiring diagram somewhere... could be glued to the back of the unit. Hopefully if you have one it will show the wires color coded and where they should be attached.. Hint: next time take an I-phone photo before you disassemble.... hint..hint .. do this on everything you attempt to repair.
Apr 27, 2014 | GE GSL25JFPBS Side by Side Refrigerator
HP Wireless Optical Mouse not connecting to MacBook Pro. Do I need a driver? If so, what kind?
visit the mouse official site look after the product number find the driver and istall it into your MacBook
Aug 23, 2013 | HP Wireless Optical Mouse
I WANT TO FORMAT AND ISTALL WINDOWS XP...BUT THE PROBLEM IS THE PRODUCT KEY IS NOT VALID..I'VE TRIED SO MANY TIMES.......PLS HELP ME ASAP....THANK YOU...IBM R40 THINKPAD
I am not sure that a product key is available anymore for XP from Windows. You may have to purchase a new copy of XP with a valid key.
Dec 27, 2010 | IBM ThinkPad R40 2723 Notebook
How do I find wiring diagram to a moultrie D 40 ? Opened up camera + found two wires off
You'll just have to borrow a good one and compare the wiring. This has proprietary issues the manufacturer doesn't want you to know.
Dec 13, 2010 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Installation help
Check the Honda Accord 1999 radio replacement procedure and wiring diagrams HERE.
Good luck (remember rated this help).
Feb 24, 2010 | 1999 Honda Accord
Cant connect the viewty to laptop to transfer files
download LG Mobile Update from http://www.lge.com/nz/support/product/support-product.jsp then use that to download the LG PC suite, install and it should be fine.
Feb 15, 2010 | LG KU990 Viewty
Oven not working
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Below is a link to common solutions that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
It provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Once you access the site you will be able to navigate numerous pages of information on your product. You will need to enter your model number to access your product information.
http://www.repairclinic.com/0088_13_1.asp#Level1_1
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint. I will post the most common solutions to your complaint. For more specific information please refer to the tip and/or link provided. Here are some things to look for:
If your range/oven doesn't seem to work at all, check these:
Fuse/circuit breaker
Main wiring
Range/oven wiring
Fuse/circuit breaker Check to see if power is getting to the range/oven. Does anything turn on--even a light? If not, check for a blown fuse or tripped circuit breaker.
Main wiring Often the main wiring connection from the house, at the range/oven, gets burned and so breaks the connection. Then you may have to replace the power cord to the range/oven, and the terminal block that the wire is attached to.
Range/oven wiring There may be a broken or burned wire at the back of the range/oven. If you repair any of the wires, use only proper appliance-grade wire and wire connectors.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jul 05, 2008 | Kitchen Ranges
Duel monitor
Which connector are you currently using? They should be white and blue.(hint: the blue is VGA, the white is DVI). If you're using the VGA connector on both monitors, you will need to purchase an DVI to VGA adapter. Fairly common and can be found online for less than $5 here: http://www.newegg.com/Product/Product.aspx?Item=N82E16814998101
Now, if you're wanting to use two DVI monitors, you'll need to buy a video card that has two DVI connectors already on it, as you cannot convert VGA to DVI.
Mar 16, 2008 | Gateway FPD2275W LCD Monitor
Pyle (Plcmtbl) Led Exhaust Tip Logo
103 people viewed this question
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
